The 76477 chip combines several functional blocks to produce a variety of sound effects. A voltage-controlled oscillator (VCO) produces a signal whose frequency depends on the control voltage. A "super low frequency" SLF oscillator generates a triangle wave. Feeding this into the VCO generates a varying pitch, useful for bird chirps, sirens, or the warbling sound of the UFO in Space Invaders. A "one-shot" produces a pulse of a fixed length to control the length of the sound. An envelope generator makes the sound more realistic by ramping its amplitude (volume) up at the start and down at the end. A digital white noise generator can be used for drums, gunshots, explosions and other similar sound effects. Finally a digital mixer combines these signals and feeds them to the output amplifier.
The diagram below indicates the functional blocks on the 76477 die. Looking under a microscope, you can see the circuitry that makes up the chip. The yellowish lines are metal traces that connect the circuits of the die. The reddish and greenish regions are the silicon of the chip, forming transistors and resistors. The black blobs around the edges of the chip show where tiny bond wires connected the die to the integrated circuit pins. Analog circuits are outlined in purple, while digital circuits are in cyan. The 76477 is primarily analog—most control signals are analog, the chip has no digital registers, and most sounds are generated from analog circuits—but about a third of the chip's area is digital logic.2
The block diagram below shows the chip's functional elements and can be compared to the die photo above. The chip is primarily controlled by resistors (red pins), capacitors (cyan pins) and voltages (violet pins). This made the chip difficult to control with a microprocessor, and more useful for hardwired sounds.
The remainder of this article will dive into the internals of the 76477 chip. First I'll show how transistors and resistors are built on an integrated circuit. Next I'll explain two key analog building blocks: the current mirror and the comparator. Finally, I'll show the reverse-engineered circuits for the 76477's analog functional modules and discuss how they operate. (I'll describe the chip's digital logic in a future article.)
Integrated circuit transistors and resistors
A bipolar integrated circuit such as the 76477 is built from two types of transistors: NPN and PNP. The diagram below shows two transistors on the 76477 die, with the emitter, base and collector labeled. The N-doped silicon appears reddish, while P-doped silicon appears green. Metal lines (yellowish) on top of the silicon connect the circuits, with outlines visible where metal is connected to the silicon layer. The transistor on the left is an NPN transistor. Internally, the transistor is built vertically, with the emitter on top, the base forming a thin layer beneath the emitter, and the collector region underneath. The transistor on the right is a PNP transistor. The collector forms a ring surrounding the central emitter. 3
Resistors are an important component of analog circuits. On a silicon chip, they can be formed from a long, narrow region of doped silicon with higher resistance. On an IC, resistors take a lot of space and are inaccurate, so they are generally avoided where possible. The die image below shows three resistors, which appear red in the photo. They are connected to the metal wiring at the contact points marked with blue arrows.
If a metal wire needs to cross another metal wire, the signal can use the silicon layer to pass under the wire. Two of these cross-unders are shown below. The silicon (green) is doped to be lower resistance than in the case of a resistor. Cross-unders are higher resistance than metal wiring, so they are only used when necessary.
By carefully examining the die photo, you can pick out the transistors and resistors and determine how they are connected. From this, you can reverse-engineer the chip's circuits.
The current mirror
A key component of most analog circuits is the current mirror, and the 76477 is no exception, containing many current mirrors. A current mirror takes one reference current and "clones" it, generating a current that matches the reference current. Either of the symbols below can be used to indicate a current mirror or current source.
The following circuit shows the circuit for a current mirror with two current source outputs. A reference current passes through the transistor on the right. (In this case, the current is set by the resistor.) Since all the transistors have the same emitter voltage and base voltage, they source the same current, so the currents on the left match the reference current on the right.4
The die segment below shows four PNP current mirror transistors providing a dozen current outputs. Each of the three pinwheel-shaped transistors has four collectors surrounding the central emitter, allowing it to produce four matched current outputs. The lower left transistor is a standard PNP transistor with a ring-shaped collector. The large green rectangle in the center is the shared base connection for the transistors.
Current mirrors are commonly used to generate bias currents instead of pull-up resistors. Since resistors inside ICs are both inconveniently large and inaccurate, a current mirror is used when possible. If you look at the die image at the beginning of the article, note the large die area dedicated to current mirrors for bias current generation. 5
Comparators
Another key building block of the 76477 is the comparator, comparing two voltages and determining which one is higher. The heart of the comparator is a differential pair, a two-transistor circuit. If both inputs are equal, the transistors will conduct equally and the current will be split equally along both branches. But if one input is lower, that transistor will conduct more, switching most of the current into that branch.
The schematic below shows a typical comparator in the 76477. If the positive input is higher than the negative input, the comparator outputs a 1. Otherwise it outputs a 0. Transistors 3 and 4 form the differential pair. The current to them is supplied by a current mirror above them, and most of the current will be directed to the side with the lower input. Transistors 1 and 2 buffer the inputs (using emitter followers) and are biased by more current mirrors. Transistors 5 and 6 form another current mirror, used as an active load to double the circuit's amplification. Finally, transistors 7 and 8 form an inverter, generating a digital output from the comparator.
The die image below shows one of the comparators used in the 76477 with the transistors labeled to match the schematic above. Note that transistors pairs 1 and 2, 3 and 4, and 5 and 6 have similar layouts to give them matched characteristics, improving the balance of the comparator. The base and collector of transistor 5 are connected together for the current mirror. The current sources and resistors are on another part of the die, not shown below.
The one-shot
The one-shot is a simple circuit that generates one pulse of a set width , triggered when the chip's inhibit signal drops low. This pulse controls the duration of the sound. For instance, a short pulse of noise can be used for a gunshot sound, while a longer noise could be an explosion.
The one-shot charges an external capacitor via an external resistor and current mirror. The resistor sets the reference current for the current mirror, and the mirror feeds this current into the capacitor. The advantage of using this charging circuit rather than a simple R-C circuit is that the charging current remains constant, rather than decreasing as the capacitor charges.7 This "charging trick" is used several times in the 76477.
When the capacitor's voltage reaches the comparator's limit level (2.6V), the comparator output goes low and the pulse ends. Thus, the faster the capacitor charges, the shorter the pulse. Digital logic circuitry (not shown) resets the one-shot by discharging the capacitor at the end of the pulse and holds it low until the next pulse is triggered via the inhibit pin.
The super-low frequency oscillator
The next functional block of the 76477 that I'll examine is the super-low frequency (SLF) oscillator. It generates a triangle wave that can control the voltage-controlled oscillator (VCO) to generate warbling sounds by ramping the pitch up and down. The frequency is controlled by an external resistor and an external capacitor. Like the one-shot, a current mirror provides a fixed charging current. However, the SLF oscillator uses a second current mirror to discharge the capacitor at the same rate, generating the triangle wave output.
Building a current mirror from NPN transistors creates a current mirror that sinks current instead of sourcing current, as in the lower current mirror. This current mirror also uses another trick: by using a transistor with two emitters, the current mirror doubles the output current; this is indicated on the schematic with two arrows in the current mirror circle. When the lower current mirror is disabled by the transistor, the capacitor is charged by the upper current mirror, with a current (I) set by the resistor, similar to the one-shot circuit. But with the lower current mirror enabled, the lower current mirror sinks current 2I. Since the upper current mirror is still supplying I to the capacitor, the net current (-I) discharges the capacitor. Thus, by combining two current mirrors, the capacitor can either be charged or discharged with the same current I. This trick will appear again in the VCO.
The final piece of the SLF oscillator is the comparator. The + input is set to an upper limit of 2.46 volts, so the comparator will output 1 as the capacitor charges. When the capacitor reaches the limit voltage, the comparator output drops to 0. The first effect of this is to enable the lower mirror, so the capacitor starts discharging. The second effect is to pull the comparator input low (0.36V) through the hysteresis circuit.6 This keeps the comparator output low until the capacitor has discharged. Thus the circuit "remembers" if it is charging or discharging, without using a flip flop. The square wave output is used by the mixer and the triangle wave output is used by the VCO.
The diagram above shows how the SLF circuit looks on the die. Note the three transistors for the upper current mirror. Below the capacitor pin is a transistor for the lower current mirror with a doubled emitter; this causes the mirror's output current to be doubled. On the left are resistors forming the hysteresis circuit. The comparator circuit is underneath it. The Vcc power trace has been colored red and the ground trace has been colored blue.
The voltage-controlled oscillator (VCO)
The voltage-controlled oscillator generates a pitch that depends on its voltage input, as shown below. The circuit for the VCO has a lot in common with the SLF: it creates a triangle wave by charging and discharging an external capacitor. The main difference is that it charges until the capacitor reaches the control voltage (rather than a fixed voltage). Thus, the voltage input controls the pitch: with a higher control voltage, the capacitor takes longer to charge so the frequency is lower. This control voltage can be provided either from the SLF or an external pin. The "VCO select" pin selects which control voltage to use.
The VCO's output is a digital square wave that is active during the charging half of the VCO's internal triangle wave. Another pin controls the output's duty cycle, the fraction of the time it is high.8 The triangle wave is compared to the duty cycle control voltage to determine when the output switches on and off. A lower control voltage results in a shorter duty cycle while a higher control voltage results in a longer duty cycle (up to 50%). The digital logic combines the two outputs to yield the final output. The VCO has two comparators in parallel; the VCO select input enables one of them.
Envelope generation
The 76477 provides envelope generation, so the output can smoothly ramp up at the start of a sound and ramp down at the end, making it more realistic9 The diagram below (from the datasheet) shows the linear attack and decay applied to a sound waveform. (The sound below illustrates the random pulses produced by the white noise generator.)
The schematic below shows the circuit for envelope generation. As with the other circuits, a capacitor is charged and discharged using current mirrors, but two separate resistors are used so the charge (attack) and discharge (decay) rates can be different. The attack signal (from the digital logic) causes the envelope capacitor to charge through a current mirror at a rate controlled by an external attack resistor. The decay signal (simply the complement of the attack signal) causes the capacitor to discharge, controlled by the external decay resistor. Discharge uses a second current mirror operating as a current sink, but unlike earlier circuits it doesn't double the current. The inhibit signal rapidly discharges the capacitor, resetting the envelope.
The output circuit
The 76477's output circuit uses four separate current mirrors. The varying reference current for the first current mirror is generated from the envelope voltage and the external amplitude resistor. Unlike the other control resistors, this resistor has a varying voltage applied so it produces a varying reference current. This current controls the output's overall amplitude.
The amplitude reference current goes into the second current mirror (lower left). The inhibit signal blocks this current mirror, which is how the inhibit signal blocks the chip's output. A third current mirror (upper right) generates two output currents referenced from the current sunk by the second current mirror. The final current mirror is enabled and disabled by the output signal from the mixer. Thus, the current to the op amp alternates between positive and negative, with magnitude depending on the envelope and the control resistor.
The output op amp drives triple-Darlington emitter-follower output transistors. These transistors are not particularly large, so the 76477 has limited output power. An external feedback resistor to the op amp controls the output's amplification. The die photo below shows part of the output circuit. A capacitor helps stabilize the output so it doesn't oscillate.
The 76477 is a complex integrated circuit with hundreds of transistors, but by examining the die the operation of the chip can be reverse engineered. The chip uses interesting techniques to generate sounds by combining oscillators, a noise generator and other functional blocks. Outside of analog chips, current mirrors are fairly obscure but the 76477 makes heavy use of current mirrors, with multiple current mirrors in almost every functional unit, driving comparators, generating bias currents, and providing uniform charge/discharge currents.
The chip had several disadvantages that led to its replacement by more advanced chips. The biggest inconvenience is that most of the 76477's parameters are controlled by resistors and capacitors, rather than digitally, making it hard to control the chip with a microprocessor. A second disadvantage of the chip is the sounds were largely digital square waves which gave the sounds a harsh quality rather than a "warm" analog sound. Finally, it was difficult to produce accurate pitches with the VCO, making the chip less useful for music synthesis. For these reasons, digitally-controlled chips such as the AY-3-8910 (1978) surpassed the 76477 in popularity.
Thanks to Sean Riddle for the die photos. I'll end with his die photo of the 76477 after dissolving the metal layer in acid, making it easier to see the resistors and transistors.
The Space Invaders schematics show that the video game used seven different circuits to create its different sounds. The 76477 generated the "UFO" sound, while other sounds (saucer hit, explosion, missile, invader hit, etc.) were mostly generated by collections of op amps. ↩
The 76477's digital circuitry was built with Integrated Injection Logic (I2L), which was developed in the 1970s with the promise of building fast bipolar logic with the VLSI density of MOS logic. Spoiler: I2L lost out to CMOS, the technology used in microprocessors today. For the 76477, the most useful feature of I2L is that it used the same manufacturing process as analog bipolar transistors, allowing the analog and digital circuitry to be combined on one chip. In the 76477, digital logic is used for digitally selecting and combining audio signals, generating white noise with a nonlinear feedback shift register, and control functions. ↩
Some PNP transistors have a different structure; a PNP transistor with the collector grounded lacks the collector ring, using the grounded substrate as the collector. This makes it more similar to an NPN transistor both in appearance and construction. For details on the internal structure of bipolar IC transistors, see my earlier articles on the 555 and 741 chips. In brief, the NPN transistor is vertical in cross-section with the emitter on top and collector on the bottom. Most of the PNP transistors are lateral (i.e. horizontal) with the emitter on the inside and the collector on the outside, and the base in between (somewhat distant from the base connection). ↩
Many of the 76477's current mirrors are more complex, with a Darlington pair of transistors between the reference transistors's base and collector. This compensates for base currents and makes the mirror more accurate. See this paper for an explanation. ↩
For bias generation, you might wonder what provides the initial current to the current mirrors. The answer is an internal resistor, along with several transistors to keep the current stable. The circuit is similar to the self-biased current source described here. ↩
Note that the hysteresis circuit used by the SLF is not providing feedback like with an op amp. It provides a comparison voltage of 2.46V while charging and 0.36V while discharging. The SLF comparator's output is open collector, so it can only pull the circuit low. ↩
If you use a simple resistor-capacitor circuit instead of a current mirror, the capacitor charges more slowly as its voltage increases, resulting in an exponential charging curve. By using a current mirror, the current remains constant so the capacitor charges at a constant rate. The result is a linear triangle wave. ↩
The datasheet calls the VCO's duty cycle control a "pitch control". This is wrong, since the frequency is unaffected. ↩
Note that the envelope is the only analog part of the sound; until the envelope ramps are applied, the output is a digital square wave. ↩
