The image below shows the 8008's tiny silicon die, highly magnified. Around the outside of the die, you can see the 18 wires connecting the die to the chip's external pins. The 8008's circuitry is built from about 3500 tiny transistors (yellow) connected by a metal wiring layer (white). This article will focus on the stack circuits on the right side of the chip and how they interact with the data bus (blue).
For the 8008 processor's birthday, I'm using the date of its first public announcement, an article in Electronics on March 13, 1972 entitled "8-bit parallel processor offered on a single chip." This article described the 8008 as a complete central processing unit for use in "intelligent terminals" and stated that chips were available at $200 each.1
You might think that an intelligent terminal is a curiously specific application for the 8008 processor. There's an interesting story behind that, going back to the roots of the chip: the Datapoint 2200 "programmable terminal", introduced in June 1970. The popular Datapoint 2200 was essentially a desktop minicomputer with its processor consisting of a board full of simple TTL chips. The photo below shows the CPU board from the Datapoint 2200. The chips are gates, flip flops, decoders, and so forth, combined to build a processor, since microprocessors didn't exist at the time.
Processors typically use a stack to store addresses for subroutine calls, so they can "pop" the return address off the stack. This stack is usually stored in main memory. However, the Datapoint 2200 used slow shift-register memory2 instead of expensive RAM for its main storage, so implementing a stack in main memory would be slow and inconvenient. Instead, the Datapoint 2200's stack was stored in four i3101 RAM chips, providing a small stack of 16 entries. 3 4 The i3101 was Intel's very first product, and held just 64 bits. In the photo above, you can see the chips in their distinctive white packaging each with a large "i" for Intel. 5
To keep track of the top of the stack, the Datapoint 2200 used a 4-bit up/down counter chip to hold the stack pointer. The clever thing about this design is there's no separate program counter (PC) and stack; the PC is simply the value at the top of the stack. You don't need to explicitly push and pop the PC onto the stack; for a subroutine call you just update the counter and write the subroutine address to the stack.
The story of the 8008's origin is that Datapoint went to Intel and asked if Intel could build a chip that combined the stack memory and the stack pointer onto a single chip. Intel said not only could they do that, they could put the whole processor board onto a single chip! This was the start of Intel's 8008 project to duplicate the Datapoint 2200's processor board onto a chip, keeping the Datapoint 2200 instruction set and architecture.6 After various delays, Intel completed the 8008 microprocessor, but Datapoint rejected it. Intel decided to sell the 8008 as a general-purpose processor chip, sparking the microprocessor revolution. Intel improved the 8008 with the 8080 and then the 16-bit 8086, leading to the x86 architecture that dominates desktop and server computers today.
The consequence of the 8008's history is that it inherited its architecture and instruction set from the Datapoint 2200 intelligent terminal. One of these features was the fixed, internal stack. But the 8008's implementation of that stack is unusual.
Shift-register counter
The most unexpected part of the 8008's stack is how it keeps track of the current position. The straightforward way to implement the stack would be with a binary up/down counter to keep track of the current stack position (which is what the Datapoint 2200 did). But to save a few transistors, the 8008 uses a nonlinear feedback shift register instead of a counter. The result is the stack entries are accessed in a pseudo-random order! But since they are read and written in the same order, everything works out fine.
The shift register outputs are based on a de Bruijn sequence, a cyclic sequence in which every possible output occurs as a subsequence exactly once. The 8008's de Bruijn sequence is shown below. The first value (000) is underlined in red. Shifting to the blue position yields the second value (001). Proceeding around the circle clockwise yields all eight values in the sequence: 000, 001, 010, 101, 011, 111, 110, 100 and finally back to 000. Note that each value appears exactly once, but they are not in standard binary order.
At each step in the sequence, the last two bits are shifted to the left and a new bit is placed on the right. Counting down is the converse: the first two bits are shifted to the right and a new bit is placed one the left. This process can be implemented with a shift register, a circuit that allows a bit sequence to be shifted and an additional bit inserted.7
The diagram below shows how the 8008 implements the nonlinear feedback shift register counter. While it make look complex, it's a straightforward implementation of the de Bruijn sequence. The three latches in the middle form a shift register, with each latch holding one bit. To count up, each bit is shifted to the left and a new bit is added on the right (green arrows). To count down, each bit is shifted to the right and a new bit is added on the left (purple arrows). The logic gate on the left generate the "new" bit for counting down and the gates on the right generate the new bit for counting up.
The logic gates may appear complex. However, one feature of PMOS logic is it's as simple to build an AND-OR-NOR gate as a plain NOR gate, just by wiring transistors in parallel or series. Designing the logic is also straightforward: for each triple of current bits, the de Bruijn sequence specifies the next bit. If you've studied digital logic, Karnaugh maps can be used to create the logic circuits to generate the desired next bit.
Inside the stack storage
The 8008 uses dynamic RAM (DRAM) to for its stack storage and its registers. The other 1970s microprocessors that I've examined use static latches, so the 8008 is a bit unusual in this regard. Since Intel was primarily a RAM company at the time, I assume they wanted to leverage their RAM skills and save transistors by using DRAM.
Each bit of storage in the 8008 uses a cell with three transistors and one capacitors, called a 3T1C cell, similar to the cell in Intel's i1103 DRAM chip. The diagram below shows a closeup of the 8008's stack storage, with six DRAM cells visible. Each row is one 14-bit address in the stack. Each row has a read enable and write enable control line coming from the left. Each column stores one of the 14 bits; the column sense line is used to read and write the selected bit.
The transistors for the first cell are labeled T1, T2 and T3. The value is stored on the capacitor labeled C. (There is no separate physical capacitor; the capacitance of the wiring is sufficient to store the bit.)
To write a bit, the write line for the desired row is pulled low, turning on T1. The desired voltage (low or high) is fed onto the sense line, passes through T1, and is stored by the capacitor. To read the value, the appropriate read line is pulled low, turning on T3. If C has a low voltage, T2 is turned on. This connects the sense line to ground through T3 and T2. On the other hand, if C has a high voltage, T2 is turned off and the sense line is not grounded. Thus, the circuitry connected to the sense line can tell what bit value is stored on C.
The inconvenience with dynamic RAM is that values can only be stored temporarily. After a few hundred microseconds, the charge stored on capacitor C will leak away and the value will be lost. The solution is a refresh circuit that periodically reads each value and writes it back, before the bit fades away. (A similar refresh process is used by your computer's RAM.) The 8008's internal RAM is refreshed at least every 240 microseconds, ensuring that bits are not lost. (Static RAM, on the other hand, uses a larger, more complex circuit for each bit, but will preserve the bit as long as the circuit is powered up.)
In the 8008, the stack storage (and the registers) are refreshed by continuously stepping through each entry: reading it and writing it back. To accomplish this, a second 3-bit shift-register counter is used as a refresh counter, tracking the current position that is being refreshed. The circuit for this is the same as the stack counter, except it omits the logic to count down, as it only needs to count in one direction.9
Understanding the die photo
I'll briefly explain what you're looking at in the die photo above. The chip itself is made from a silicon wafer. Plain silicon is essentially an insulator, but by doping it with impurities, it becomes a semiconductor. The dark lines indicate the boundary between doped and undoped regions; the doped silicon in the first cell is indicated in red.
On top of the silicon is the polysilicon layer, which is the yellowish stripes. Polysilicon acts as a conductor and is used as internal wiring of the chip. More importantly, a transistor is created when polysilicon crosses doped silicon. A thin oxide layer separates the polysilicon from the silicon, forming the transistor's gate. A low voltage on the polysilicon gate causes the transistor to conduct, connecting the two sides (called source and drain) of the transistor. A high voltage on the gate turns the transistor off, disconnecting the two sides. Thus, the transistor acts as a switch, controlled by the gate.
The top layer of the chip is the metal layer, which is also used as wiring. For the photo above, I removed the metal layer with hydrochloric acid to make the underlying silicon more visible. The green, blue and gray lines indicate where the metal wiring was before being removed. Transistors T1 and T3 are connected to the sense line (blue), while transistor T2 is connected to ground (green). The read and write lines enter the circuit on the left as metal wiring, connected to polysilicon lines.
The interface between the stack and the data bus
To access memory, the address in the stack must be provided to external memory via the 8 data/address pins on the chip. These pins are connected to the stack (and other parts of the 8008) via the data bus. The die photo below shows the circuitry that interfaces the 14-bit stack storage to the 8-bit data bus.11 At the top of the photo are the metal control lines and three of the data bus lines. At the bottom are the sense lines, discussed earlier, from the stack storage. In between are the transistors (orange) that connect the data bus and the stack.
The control lines select the low (L) or high (H) half of the address. These activate the appropriate read or write transistors, connecting the appropriate stack columns to the data bus.
The transistors to write an address to the data bus are much larger than typical transistors, appearing as vertical yellow bars in the die photo. The reason for this is the data bus passes through the whole chip. Due to the length of the bus, it has relatively high capacitance and larger, high-current transistors are required to drive a signal on the data bus.
Near the bottom of the photo are the inverter amplifiers. Each sense line is attached to an inverter that boosts the signal from the stack storage. During refresh, this boosted signal is written back, strengthening the bit stored on the capacitor.10
By examining die photos, it is possible to reverse-engineer the 8008 microprocessor. One unusual feature of the 8008 is that instead of using standard binary counters internally, it saves a few gates by using shift-register counters. Although these count in a pseudo-random order rather than sequentially, the 8008 still functions correctly. One counter is used for the on-chip address stack. The 8008 also uses DRAM internally for stack storage and register storage, requiring a second counter to refresh the DRAM. Since every transistor was precious at the dawn of the microprocessor age, the 8008 has these interesting design decisions that produced compact circuitry.
If you're interested in the 8008, my previous article has a detailed discussion of the architecture, more die photos and information on how to take them. This article explains the 8008's ALU.
The first announcement of the 8008 microprocessor in Electronics is shown below (click for a larger version). The announcement called the chip a "parallel processor", a term that had a different meaning back then, indicating that the processor operated on all 8 bits at the same time. This was in contrast to serial processors (such as the Datapoint 2200) that handled one bit of the word at a time.)
The 8008 chip was announced in Electronics on March 13, 1972: "8-bit parallel processor offered on a single chip." -
In 1970, RAM memory chips were extremely expensive: $99.50 for an i3101 chip with just 64 bits of storage. Shift-register memory was cheaper and denser, with 512 bits of storage in an Intel 1405 chip. The big disadvantage is the bits were circulated around and around inside the chip, with only one bit available at a time. Sequential access wasn't a problem, but if you wanted to read memory out of order, you might need to wait half a millisecond for the right bit to circle around. I wrote about shift-register memories in detail here, with detailed die photos. ↩
The i3101 memory was called the 3101 due to Intel's part numbering system at the time, described in Intel Technology Journal, Q1 2001. To summarize, the first digit indicate the product family: 1xxx is PMOS, 2xxx is NMOS, 3xxx is bipolar and so forth. The second digit indicates the product type: 1 is RAM, 2 is a controller, 3 is ROM, and so forth. The last two digits are sequence numbers typically starting with 01. Thus, the first bipolar RAM was the 3101.
During development, the 8008 chip was called the 1201, following Intel's naming scheme: the 1 indicated the chip was built from PMOS technology, the 2 indicated a custom chip and the 01 was a serial number. Fortunately, when it came time to market microprocessors, Intel decided that marketing was more important than systematic numbering: Intel's 4-bit microprocessor became the 4004 and their 8-bit microprocessor the 8008. ↩
Intel introduced the i3101 chip in April 1969. The i3101 RAM chip was a static memory chip, rather than the dynamic RAM chips common today. It was also built from Schottky TTL technology, rather than MOS used in modern RAM chips. Other companies, such as National Semiconductor, Signetics and Fairchild, made 64-bit memory chips compatible with the Intel i3101. However, they typically used the standard 74xx numbering scheme, calling the chip the 7489. ↩
Although the Datapoint's stack could hold 16-bit values, the Datapoint 2200 only used 13 address bits, supporting a maximum of 8K of memory. The 8008 expanded the address range to 14 bits, supporting 16K of memory, which was a huge amount at that time. However, the 8008's internal stack was only 8 values, rather than the 16 of the Datapoint 2200. ↩
Texas Instruments heard that Intel was designing a processor for Datapoint and asked Datapoint if they could build a processor for Datapoint too. TI beat Intel to the finish, creating the TMC 1795 processor before Intel completed the 8008, largely because Intel put the 8008 on the back burner. After Datapoint rejected TI's microprocessor, TI tried to find a new customer for the chip. TI was unsuccessful, and the TMC 1795 was abandoned and mostly forgotten. I've written about the TI chip in more detail here. ↩
You may be familiar with linear-feedback shift registers (LFSRs), which can be used as pseudo-random number generators or noise generators. With N stages, a LFSR can generate 2N-1 output values. The de Bruijn sequence is generated from a nonlinear-feedback shift register. Nonlinear-feedback shift registers are a generalization of LFSRs; by using more complex feedback circuitry than just XOR, a nonlinear feedback shift register can generate sequences of arbitrary length. In particular, it can generate a sequence of 2N values, while a LFSR is limited to 2N-1. ↩
Nonlinear feedback shift registers seem pretty obscure. The only other use I've seen is the TMS 0100 calculator chip, which generates an internal sequence of length 11. For information on the theory, see The Synthesis of Nonlinear Feedback Shift Registers and Counting with Nonlinear Binary Feedback Shift Registers. The book Shift Register Sequences goes into great detail on linear and nonlinear sequences; Section VII:5 is probably most relevant, describing how to make a shift register cycle of any length.
The TMS 1000 microcontroller saves a few gates by using a LFSR for the program counter. Instead of incrementing, the PC goes through a pseudo-random sequence. The code is stored in the ROM in the same sequence; everything works out, but it seems like a strange way to implement a program counter. ↩
I was expecting the stack counter and refresh counter to have a regular layout on the chip, with a single shift register stage repeated three times. However, on the 8008 die, the transistors are arranged irregularly, scattered around where there was room. Presumably this made the layout more compact. ↩
Since the signal read from stack storage passes through an inverter before being written back, you might expect the bit to get flipped. The explanation is that transistor T2 in the storage cell inverts the value on C. Thus, the value read from a sense line is inverted compared to the value written on the sense line. The inverter amplifier provides a second inversion, restoring the original value. ↩
Each 8008 instruction takes multiple clock cycles to execute. An instruction is broken into one or more machine cycles; each machine cycle typically corresponds to one memory access for instruction or data. Each machine cycle consists of up to 5 states (T1 through T5). An address is transmitted to memory during state T1 and T2, and the memory location is read or written during T3. Each T state requires two clock cycles, so an 8008 instruction takes a minimum of 10 clock cycles. The Intel 8008 user's manual provides detailed timings. ↩
5 comments:
Federico Faggin's commentary on the new-for-the-time self-aligned silicon gate technology which was used for the 4004 and 8008 is interesting reading:
http://www.intel4004.com/mosgate.htm
(The previous technology being metal gate, not being self-aligned and therefore needing more margin for misalignment and so delivering lower density, and also needing an extra mask to define where the channel is to be. The new technology allowed the channel doping to be masked by the polysilicon gate itself.)
Regarding note 8, a famous use of Linear Feedback Shift Register counters was in the TIA (Television Interface Adaptor) of the Atari 2600 videogame console.
http://www.atarihq.com/danb/files/TIA_HW_Notes.txt
Any idea why Datapoint rejected both TI and intel designs ? Did they use a third entrant ?
Adrian: I've heard a variety of reasons why Datapoint rejected the TI and Intel microprocessors: they couldn't get the chips to work reliably, they had a new switching power supply that eliminated the cooling issues from TTL, the chips came too late, etc. In any case, Datapoint redesigned their circuit board to use the 74181 ALU chip, which was much faster than the microprocessors. It took several years before microprocessors were faster than TTL.
Another semi-well-known chip using a shift register as the program counter: the CIC copy protection chip used on the NES: https://hackmii.com/2010/01/the-weird-and-wonderful-cic/. It is apparently based on some 4-bit Sharp mask ROM microcontroller.
BTW, apparently there were all kinds of interesting defeats made for the CIC, such as feeding negative voltage pulses to its gpio inputs: http://www.kevtris.org/mappers/lockout/
