The Computer History Museum has two operational IBM 1401 computers used for demos, but a few weeks ago one computer suddenly couldn't print anything. I helped track down the problem, but it was more tricky than we expected; along the way we had to investigate the printer error checking circuits, the print buffer, and even low level core memory signals. This blog post discusses our investigation and how we traced the problem to a failed germanium transistor.
The IBM 1401 computer was announced in 1959, and went on to become the best-selling computer of the mid-1960s, with more than 10,000 systems in use. The 1401 leased for $2500 a month (about $20,000 in current dollars), a low price that let even medium-sized businesses use the 1401 for payroll, accounting, invoicing, and many other tasks. The IBM 1401 computer was constructed from small circuit boards (called SMS cards) plugged into units called "gates"—these are gates in the sense of something that swings open, not logic gates. The photo below shows the 1401 with one of the gates open, revealing dozens of brown SMS cards plugged into the gate.
One key selling point of the IBM 1401 was its high-speed line printer (the IBM 1403), which could hammer out 10 lines per second. (IBM claimed this was four times as fast as competing printers, but others dispute this.) The 1403 printer had excellent print quality, said to be the best printing until laser printers were introduced in the 1970s.1 IBM claims that "Even today, it remains the standard of quality for high-speed impact printing."
The 1403 printer used a chain of type slugs (above) that rotated at high speed above the paper, with an inked ribbon between the paper and the chain. Each of the 132 print columns had a hammer and an electromagnet. At the right moment, when the desired character passed the hammer, the electromagnet drove the hammer against the back of the paper, causing the paper and ribbon to hit the type slug, printing the character.2
Unfortunately, the printer at the Computer History Museum recently had a problem: whenever a line was printed, the computer would halt due to a "print check" error. Fortunately the museum has a team of volunteers to help keep the system running; people helping with this printer problem included Ron Williams, Frank King, Marc Verdiell, Carl Claunch, Michael Marineau, Robert Garner and Alexey Toptygin. By the time I arrived to help, Ron had written a simple test program that repeatedly attempted to print a line; he toggled the program into the computer by hand, and he disabled the error check. The printer printed the characters properly, so we suspected the problem was in the error reporting circuitry inside the computer. Our strategy was to find the error signal and then trace it back through the computer to determine why it was being generated.
We started by examining the latch circuit that holds the print check error condition and sends it to the rest of the computer. To find the circuit, we consulted the documentation: binders of cryptic computer-generated wiring diagrams, called Automated Logic Diagrams (ALD). A small piece of an ALD is shown below showing the print check latch (PR CHK LAT). Each box on the ALD corresponds to a circuit on an SMS board and the lines show how the boards are wired together. Deciphering the text inside the box on the right indicates a board of type 2JMX implementing a "2+AO" function, which in modern terms is AND-OR-Invert. The text in each box also indicates the location of the card: its gate (physical swing-out gate, not logic gate), gate 01A6 in this case, and the card's position in the gate (F10). Thus, to check the output (labeled H) of the latch with the oscilloscope, we swung out gate 01A6, found card F10, and hooked the oscilloscope to pin H. We found pin H went low (error) when pins F and G went high, which was the proper behavior for the latch. Pin G (PR CK SAMPLE) was essentially a clock to sample the error state, while pin F was the error signal itself. Our next task was to determine what was triggering the error signal on pin F.
The documentation also includes logic diagrams that show the circuitry at a logical level, which is slightly easier to understand than the physical connections on the ALD diagrams. The logic diagram below shows the printer error circuitry. At the right, the print check error signal (PRT CHK ERROR) comes out of the latch (PR CHK LAT) that holds the error signal. (This is the same latch as in the ALD diagram above, and you can match up the signal names.) To the left of the latch, several different error conditions are detected and combined to form the error signal fed into the latch. (Note that IBM's logic symbols didn't match standard symbols. The semicircle is an OR gate, not an AND gate. The triangle is an AND gate. An "I" in a box is an inverter.)
Several different conditions can trigger a print check error3 and we thought the "hammer fire" check was a likely candidate. Recall that the printer uses 132 hammers, one per column, to print a line of characters. To make sure the hammers are operating correctly, the computer has two special planes in core memory. (The 1401 contains 4,000 characters of core memory4; each bit of memory is a tiny ferrite ring that is magnetized one way to store a "1" and the other way for a "0". A grid of 4000 cores forms a plane, storing a 1-bit slice of memory. Multiple planes are stacked up to form the storage unit.) Each time the computer decides to fire a hammer, it records this in core memory in the "equal check" plane. When a hammer actually fires, the current pulse from the electromagnet stores a bit in the "hammer-fire" plane.5 Each print scan cycle, the computer compares the two core planes to see if a hammer was fired when it wasn't supposed to, or if a hammer failed to fire when it should have; a mismatch triggers the "hammer fire" check error.
After some difficulty6, we determined that the problem wasn't the hammer fire check, but a different check: "print line complete" (PLC). This check ensures that for each line, either exactly one character was printed in each column or the column was blank. This check uses a third special core plane, the "print line complete" plane. Each time a character is printed in a column, the corresponding bit is set. (For a blank or unprintable character, a separate circuit sets the column's bit.) At the end of the line (during scan 49), the print line complete cores are checked; if any core is zero, the printer failed to print that column and an error is reported. (You can see the PLC CHECK signal and the logic that generates it on the earlier logic diagram.)
Oscilloscope probing (below) showed that the PLC CHECK (yellow) was triggered because the system thought a second character was being printed in the same column. The cyan signal is the (inverted) PLC bit from core (PR LINE COMP LATCH); each low pulse indicates a character has been printed in that column. The pink pulse (PRINT COMPARE) indicates a new character is being printed. The problem is that the cyan and pink signals go low at the same time, indicating both an existing character and a new character in the column. This generates the extra blue pulse (PLC CHECK), which triggers the yellow pulse (PRINT CHK ERROR from the latch). (This circuit can be seen in the earlier logic diagram, labeled "Trying to print position twice".)
Several things could cause the system to think two characters were being printed in the column. Looking at the printer's output we saw that it printed just the expected character on the paper, so the circuit to print a character seemed to be working correctly (PRINT COMPARE, the single pink pulse above), We tested the blank / unprintable circuit and it was detecting blank and non-blank columns correctly. So the most likely problem was reading a 1 from core memory (the cyan line above, PR LINE COMP LATCH) when it should be a 0. But was the problem the wrong value going in to core, or the wrong value coming out?
The logic diagram below shows the circuit that writes to the Print Line Compare core memory. At the right, PR LINE COMP INH is the (inverted) signal written to core.8 On scan 49 (the error-checking print cycle after printing all 48 characters), this line is set high, clearing the memory. If a character is being printed, the PRINT COMPARE EQUAL signal will set the core. At the left, logic gates detect a blank or unprintable character. And if a 1 bit was already in core (PR LINE COMP LATCH), the 1 bit is rewritten to core.
We detected that this circuit was writing erroneous 1 bits to core because it was reading erroneous 1 bits from core. But that put us in a circle, not knowing if the initial problem was the read or the write. To resolve this, we triggered the oscilloscope on print scan 49, which is when the PLC bits get cleared, and then looked at the next print scan, which reads the cleared bits back. We saw 0's being written (i.e. PR LINE COMP INH high), but unexpectedly saw 1's coming back (PR LINE COMP LATCH). So we knew something was going wrong at a low level in the core memory.
I should mention that in the base 1401 system, the printer check bits were stored in the main core memory module, but our system used a separate "print storage" core memory for improved performance. The performance issue is due to how the printer uses core memory: each time a hammer lines up with a type slug, the computer reads the corresponding character from core memory and fires the hammer if the character in storage matches the character under the hammer. Since core memory is constantly in use while printing a line, the computer can't do any computation while printing. The solution was the print storage feature: an additional 132-address core memory that functioned as a print buffer.7 With print storage, a line to be printed was first rapidly copied from the main core memory to the print storage core memory. Then the computer could continue doing computation using the main core memory while the print circuitry read from the print storage core memory. Each option on the IBM 1401 had a monthly charge; IBM charged an extra $386 a month for the print storage feature.
The photo above shows the gate that implements the print storage feature. The core memory module is the block on the upper right with yellow wires attached. (Individual cores can be seen in the photo below.) Core memory requires a lot of supporting circuitry. To select an address, driver cards generate X and Y signals. To write a core, the inhibit signal is combined with the clock by a gate, and then a driver card amplifies the signal and sends it through the inhibit line that passes through all the cores in the plane.8 When a core is read, it induces a pulse on a sense wire. This pulse is amplified by a sense amplifier card, and then the bit is stored in a latch. The numerous SMS cards in the print storage gate provided these support functions.
We probed the sense amplifier and latch cards on the reading side of the core memory and they seemed to be operating correctly, so we moved to the writing side. The HN inhibit driver card seemed a candidate for failure since it operates at high current, but we swapped the card with a replacement and the printer still failed. Next, I tried looking at the input to that card, but found there was no signal on that line, which seemed very suspicious.
The missing signal was generated by a card of type CHWW, a NAND gate that combines the inhibit signal with the clock before sending it to the driver card. I hooked up the oscilloscope to the inputs and output of the NAND gate, yielding the trace above. This trace was the smoking gun: the output (cyan 2) remained high even when the two inputs (pink 3 and blue 4) went high. This showed that the NAND gate had failed and its output was stuck high. This explained everything: with this output stuck high, only 1's would be written to the PLC core plane. Then, when a character was printed, the print circuitry would read the 1 from core, think a character had already been printed in this column, the PLC check would fail, and the print check error would be triggered.
We swapped this card with a spare, and the printer started printing without any errors (above). This proved that we had finally traced the problem; it was a simple NAND gate in the depths of the printer buffer core memory circuit. The failed card is shown below. It implements three NAND gates (details) using diode-transistor logic (which IBM calls CDTL—Complemented Transistor Diode Logic). Each two-input gate uses one germanium transistor (circular metal can) and two diodes (striped glass components on the right). Pull up resistors (striped) and inductors (beige) on the left complete the circuits.
I tested the card with a signal generator and found that while two of the three NAND gates worked, the other was stuck at a high output, confirming what we saw inside the 1401. Next I tested the transistors using the diode test mode on a multimeter. The good transistors had voltage drops of 0.23V. (This may seem low, but remember that these are germanium transistors not silicon transistors.) In comparison, the bad transistor had a Vbe drop of 0.95V, much higher. Finally, we removed the transistors and checked them on a vintage Tektronix 577 curve tracer. We thought the bad transistor might just be too weak to operate the gate, but it was entirely dead—totally flatlined on the curve tracer.
We opened up the transistor on a lathe and looked inside. The transistor is an IBM 083 NPN germanium alloy transistor (germanium was used before silicon transistors). The transistor consists of a tiny germanium die (the shiny metallic square below), forming the base. Two wires are attached for the emitter and collector, connected to dots of tin alloy, a larger dot on the front for the collector and a smaller dot on the back for the emitter. Under the microscope, it looked like there was some corrosion on the alloy dots and the emitter wire didn't look solidly connected, so we suspect that is the root cause of the failure.
This was a harder problem to diagnose than most of the IBM 1401 issues. But we managed to track down the problem, replace the bad card, and get the printer back in operation. One nice thing about the IBM 1401 compared to modern systems is that it's not a black box—you can look inside all the circuitry, down to the individual transistors. In this case, we were able to find the bad transistor that was causing the system failure, and even determine that it was probably corrosion that killed the transistor.
I announce my latest blog posts on Twitter, so follow me at @kenshirriff for future articles. I also have an RSS feed. The Computer History Museum in Mountain View runs demonstrations of the IBM 1401 on Wednesdays and Saturdays so if you're in the area you should definitely check it out (schedule).
One reason for the IBM 1403's high quality printing was its use of a type chain instead of typebars or a drum. Many earlier line printers used rows of typebars or a rotating drum of characters. Any timing imprecision would change the vertical positioning of characters, yielding ugly wavy text. The 1403, on the other hand, used a horizontally rotating chain of characters so misalignment caused a hardly-noticeable change in the spacing between characters. ↩
You might expect that the 132 hammers align with 132 type slugs, so the matching hammers all fire at once, but that's not what happens. Instead, the hammers and type slugs are spaced slightly differently, so only one hammer is aligned at a time, and a tiny movement of the chain lines up a different hammer and type slug. (Essentially they form a vernier.) Specifically, every 11.1 microseconds, the chain moves 0.001 inches. This causes a new hammer / type slug alignment. For mechanical reasons, every third hammer lines up in sequence (1, 4, 7, ...) until the end of the line is reached; this is called a "subscan" and takes 555 microseconds. Two more subscans give each hammer in the line an option to fire, forming a print scan of 1.665 milliseconds. 48 print scans give each hammer a chance to print each character, and then the 49th print scan is used for error checking. (For more details of this timing, see Manual of Instruction, page 37.)
The mechanism of scans and subscans may seem excessively complicated. But what it accomplishes is matching up the fast "electronic world" with the slower "mechanical world." Specifically, every 11.1 microseconds, a hammer and type slug line up. The computer reads the character in that column from core, compares it to the character on the type slug, and if they match, it fires the hammer. The important thing here is that a core memory cycle matches the time between hammer alignments, making it possible to read the character from core for each hammer alignment. If you want more information on how the print chain works, I have an animation here.
One subtlety is that a hammer takes 1.52 milliseconds to impact (Manual of Instruction, p32). Thus, it's not really the case that the hammer fires when it lines up with the type, but when it will be lined up 1.52 milliseconds in the future. ↩
It may seem excessive that the 1401 had multiple checks to ensure that the printer was operating properly. But for a business computer, print errors could be catastrophic: imagine if a day's payroll checks had a digit printed wrong or tax forms were printed incorrectly. IBM's scientific computers had much less error checking than the business computers, on the assumption that scientists would notice problems. ↩
The 1401 stores 4,000 characters in core memory, not 4096, because it is a decimal machine (i.e. BCD), with decimal addresses. Its memory can be expanded to 16,000 characters with a dishwasher-sized memory expansion unit; I wrote about repairing this unit here. I wrote more about the 1401's core memory here. ↩
Recording each hammer fire in core memory isn't done by the computer writing to core memory. Instead, each hammer is physically wired directly to a particular core; 132 wires from the hammer electromagnets to the cores. When a hammer fires, the current pulse from the hammer's electromagnet goes through a wire wrapped through the corresponding core, magnetizing that core. (You can see these wires in the earlier picture of the cores.) ↩
It was tricky to determine which signal was triggering the error input F, due to the 1401's use of wired-OR. Because transistors were expensive when the IBM 1401 was built, IBM used many tricks to reduce the transistor count. One trick is the wired-OR—instead of using an OR gate, signals are simply wired together so if any signal is high it will pull the line high. Thus, We couldn't simply probe the signals feeding into pin F because they were all wired together. Instead, we needed to disconnect cards so we could test one signal at a time. ↩
The print storage core memory has 12 core planes; that is, it stores 12 bits at each location. Like a regular core location, it uses 6 bits to store each BCDIC character, as well as a bit for the word mark (metadata indicating field locations), and a parity bit. In addition, the print storage has four planes for error detection: a hammer fire sense plane (recording the hammers that fired), equal check plane (recording the hammers that should fire), print line complete plane (recording columns with a character printed), and an error check plane (indicating the column that triggered an error). ↩
The process to write to core memory may seem backwards, using a high signal on the inhibit line to write a 0. This is due to how cores function. The key that makes cores work is that they require a high current pulse to flip the core's magnetic state; a pulse with half the current has no effect on the core. Cores are arranged in a grid, with X and Y address lines that are pulsed to select a core. Multiple planes are stacked, one for each bit. Each line is pulsed with half the necessary current, so only the core where both lines cross has enough current to flip to the 1 state. Each plane has an inhibit line that passes through all the cores in the plane. To write a 1 to a plane, the inhibit line gets no current, causing the addressed core to flip to 1 as described. To write a 0 to a plane, the inhibit line gets half current in the opposite direction. The result is that none of the cores get enough current to flip, and the addressed core remains in the 0 state. Thus, by setting each plane's inhibit line appropriately, the desired 0's and 1's can be written to the address in the core stack. ↩
For information on how the print checks work, see Instruction Logic, page 98. The 1403 printer is documented in IBM 1403 Printer Component Description, 1403 Printers Field Engineering Maintenance Manual and 1403 Printers Field Engineering Manual of Instruction. See also this brief article about the 1403 printer in the IEEE Spectrum. For a detailed description of the IBM 1401, see IBM 1401: a modern theory of operation. ↩
20 comments:
It is so amazing to see how stuff was done at the beginning of electronic computation -- each bit, each gate was precious! (and it could be poked with your finger) I keep that in mind when I launch yet another scientific computation on 12000 cores. You are doing great work!
This was a very enjoyable article to read, better than some mystery novels!
You used a nice modern storage scope. How much harder would this be with an analog scope? Is that what field service used?
Regarding note 2 and the page with animation: The mechanism of scans and subscans not only matches electronic world to mechanical world, but also prevents things like someone like me trying to print a magic line of text the would fire every hammer at the same time, which would surely draw too much current or put too much drag on the system, and blow it up. Instead it spreads out the electrical and mechanical load, and thwarts such attempts. Brilliant!
I'm convinced all of these ideas will be needed again when we move to nanotech.
Dithermaster: back in the 1960s, field service had analog scopes. It was easier with a modern scope (in particular, 4 channels made it much easier to figure out what was going on), but I'm sure they did fine with analog scopes.
LOL, i came here with the same idea, how did they do it without that nice digital stuff :)
https://www.oscilloscopemuseum.com/collection-tek.html lots of scopes but don't see any multi channel so a bit more work to find the problem
Wow! A blast from the past. I learned computer maintenance using a Xerox Sigma 2 computer back in the 1970s. The computer was used in a Westinghouse Prodac-250 at a power station. I remember spending hours and hours wading through logic diagrams in large books to troubleshoot the computer. This sure brought back some of those (now fondly remembered) memories.
Have you tried turning it off and on? ;)
I was the systems programmer for a real mainframe the 7040 scientific computer back in 1965. It used a 1401 as it's card/reader/punch and printer. A little bit of commercial accounting was also run on the 1401. The 1410 which was a machine somewhat similar to the 1401 was more of a commercial main frame.
It's absolutely fascinating that this machine verified hammer actuation of the particular character being printed. That's an incredible level of fault checking. I worked on fault tolerant computers where a dual core system was really two sets of three CPUs running in lockstep and having hardware check each bus cycle for disagreement. The memory and storage system were ECC protected, as were network communications, but that level of protection certainly was not extended to laser printers! I also appreciate the fact that these vintage machines can be diagnosed and repaired with fairly available parts - even if you had to steal discrete components from spare cards.
Microgadgethacker: don't worry, we ended up fixing the bad card with a replacement transistor. So we didn't cannibalize any of the spare cards.
Excellent reading! Thanks for the article.
Solid State components should be very very expensive in the 60s but the cost of non-working hours for such machines should be far higher.
Then I think that IBM maintenance people carried a bunch of spare cards on their toolboxes, and the troubleshooting was performed by replacing suspect cards while tracking the problem along with the ALD schematics. The cards identified as faulty could be serviced later at the factory using test sets for each model of card.
Today you don't have spare cards, then using a 4 channel digital storage scope is totally fair !
Danjovic: I asked some old IBM engineers and they said engineers generally wouldn't have many spare cards (if any) due to the large number of different card types and the high cost of keeping a large inventory. Instead, engineers would usually call the nearest branch office and have someone bring the cards they needed. They would drive halfway and meet up with the person delivering the cards. If the branch office didn't have the parts, they would be sent from the area-level parts depot. For very unusual parts (e.g. a new core array), parts would be flown out from the parts depot in Mechinsburg. Apparently they'd buy two tickets: one for the person delivering the core array and a second seat for the core.
@Dithermaster:
I've met a couple people who claimed to have encountered a case where a student figured out the character order on a chain printer and sent the 'magic string'. The described result was having to replace the chain and that they were finding links behind various things for over a year.
When I first started working for IBM in the late '70's we used a 1401 with a homemade fixture to program EPROMs. I believe they were Intel 1701's and 1702A's...256 bytes of storage. And it took upwards of 45 minutes to program, if I remember correctly.
The animation is great to clarify how the type slugs line up with the hammers. But what I remain wondering about is how the printer knows which character is present on the slug that is currently lined up to a hammer. (It knows which character to print because it reads from core.)
My thought would be that it uses a counter that resets when it has counted all printable characters. But your animation shows that it would need to count up by 3, instead of the simpler counting by 1.
So then I thought that they would re-arrange the order of the characters on the chain, to enable counting by 1. The chain would contain something like A . . B . . C (with some other characters in between, to be used in the next 2 subscans). But speaking against this is the photo you show of the chain, which seems in normal order.
The only other thing I can think of is that they renumbered their characters in a different order than the print chain. But that would surely be really impractical in software.
What is the solution here? I'm very curious.
Rhialto: that's a good question, how the print controller steps the memory by 3 and the characters by 2. The short answer is it's complicated and uses a bunch of counters and ring counters. (A ring counter has one bit high at a time, like a shift register.)
The first counter is the PSS (Print SubScan) Ring counter, which counts the three subscans in a scan. It is synchronized with the print chain via a magnetic sensor in the printer.
Next, the PSS Counter keeps track of the first character in the subscan. It counts through the 48 characters (1 through 12 with two zone bits). Its counting is a bit unusual: it increments after the first and second subscans and decrements after the third subscan, so each scan is one character later. E.g. A, B, C for the first scan, then down to B, C, D for the next scan. The Compare Counter keeps track of the current character on the chain. It loads the value from the PSS Counter at the start of the subscan and then counts by 2.
If there is no print buffer, and characters are printed from core memory: the B address register (B star) points to the character in core memory. It is incremented by 3 via the ALU each step. With a print buffer, the memory addressing is entirely different since it uses the print buffer's separate core. The units ring counter goes from 0 to 9 and the tens ring counter goes from 0 to 13. These signals go directly to the X and Y select lines for the buffer core memory. The ring counters increment by 3, which is not too hard with a ring counter.
Schematics for the print circuitry is in the Instructional Logic Diagrams starting at sheet 70. A detailed explanation is in 1401 Instruction Logic pages 88-94.
Interesting article.
I'm pretty sure I used one of these printers (at Rutherford Lab in the UK) in the late 1980's - if not exactly the same model certainly the same family. And boy was it LOUD. The speed of scrolling blank lines or form feeds was impressive.
I had no idea it was so old.
Excellent diagnosis of a fairly difficult problem (would have been a real challenge if the problem would have been intermittent). I am really impressed the way you have researched the print buffer logic mostly by reverse engineering. I really wish I was there with you to work on this problem.
There is DFT called 'print word mark' which we found to very useful in diagnosing and isolating intermittent PC due to a particular position problem (driver card/hammer coil/cable connection etc.)
Like always, your posts are really enlightening.
All these printers are really old printer. For repairing all these printers you need the Printer technical support and to get the printing images.
Back in the late 1970's, 1980'S I was a partner in a computer leasing company. we had about 50 systems's on lease in the nyc area and 500 keypunch machines.
(2) Ibm 1440's, (2) RCA 301's(transistor computers), (10) IBM 360 MODEL 30 AND 40'S
(10) dEC PHP 11'S and pdp 8's, (3) system 3's, (20) IBM 370's all on lease.
I was lead Technician/engineer. It usually took me 2hrs to fix an IBM computer 360/370 MAINFRAME vs 4 to 8hrs for an RCA or borroughs system!! THE IBM DOCUMENTATION WAS GREAT,
THE TROUBLE SHOOTING GUIDES WERE CALLED MAPS!!
THE EASIEST PART OF FIXING AN IBM MAINFRAME USUALLY CONSISTED OF PULLING A CARD
AND CLEANING THE CONTACTS AND RESEATING THE CARD!!! IBM COMPUTERS USUALLY
HAD CONTACT PROBLEMS!!!!!! IBM FINALLY SOLVED THE CONTACT PROBLEM IN THE PC
BY SCREWING ALL THE CARDS INTO THEIR SOCKETS!!! IT ONLY TOOK IBM 20 YEARS TO COME UP
WITH THAT SOLUTION!!!!! SCREW DOWN THE CARDS!!!!!!
FOR CHECKING GATES AND SIGNALS ON ALL COMPUTER I USED A LOGIC PROB(RADIO SHACK)
OR JUST A VOLT METER!!
DEC PDP 11'S AND PDP 8'S USUALLY REQUIRED REPLACEMENT BOARD, USUALLY TOOK 1/2 HR
TO TROUBLE SHOOT AND REPLACE A BOARD!!!
TROUBLE SHOOTING: ALL IBM COMPUTERS HAD SEVERAL CARDS OF THE SAME TYPE IN EACH MACHINE
SO YOU WOULD JUST SWAP THE SAME TYPE OF CARD FROM ANOTHER SECTION OF THE MACHINE AND
SEE IF THE TROUBLE DISAPPEARED!!! WE ALMOST NEVER HAD TO ORDER PARTS FROM IBM!!
IBM WAS SLOW ON PARTS DELIVERY TO LEASING CO'S TO SABOTAGE OUR MAINTENANCE OPERATION,
IBM CLAIMED WE HAD TO BUY PARTS ONLY FROM A PLACE IN INDIANA, THAT HAD NO AIR FREIGHT
SERVICE, ONLY GROUND THAT TOOK 1 WEEK FOR DELIVERY!!
SO I PURCHASED PARTS FROM RECYCLING CO'S, THEY WOULD SELL US
$400 IBM CARDS FOR $5 PER CARD( I BAUGHT 500 CARDS FROM JUNK 360 AND 370 THAT WE NEVER
HAD TO USE!!!
I WOULD USE AN OSILISCPE ONLY FOR REPLACING DISK DRIVE HEADS OTHERWISE I USED MY
LOGIC PROBE(RADIO SHACK) OR VOLT METER TO TRACE SIGNALS!!
I MUST HAVE REPLACED 100 TRANSISTORS ON THE RCA 301, I NEVER HAD TO REPLACE ANY TRANSISTORS ON THE IBM 1440.'S
AT THE NY TIMES, I WORKED FOR A CONSULTING COMPANY THAT HAD TO KEEP THE TIMES CLASSIFIED COMPUTERS GOING, AFTER THE MFG WENT OUT OF BUSINESS!!
WE HAD A POWER FAIL SHORT OUT 2 OF THE 3 SYSTEMS THAT THE TIMES USED TO ENTER
CLASSIFIEDS( CAUSED BY A TECHNICIAN MORON, THAT MY BOSS HIRED).
MY BOSS AND 3 TECHNICIANS WORKED ON THE SYSTEMS FOR 3 DAYS( TRACING SIGNALS)
THEY COULD NOT FIX THE SYSTEMS.
FINALLY HE ASK ME TO TAKE A LOOK AT THE SYSTEMS! USING MY IBM MAINFRAME EXPERIENCE
AND METHODOLOGY(PULLING CARDS), IT TOOK ME 15 MINUTES TO FIX THE SYSTEMS!!!
IF YOU WORKED ON IBM MAINFRAMES WITH THOUSANDS OF CARDS THEN A NY TIMES COMPUTER
WITH 100 CARDS IS NOTHING!!
TODAY WORKING ON SERVERS AND PC, ALL THE PROBLEMS ARE SOFTWARE AND TAKE LONGER
TO FIX THAN AN IBMNFRAME!!
