Why do people keep writing about the imaginary compound Cr2Gr2Te6?
I was reading the latest issue of the journal Science, and a paper mentioned the compound Cr2Gr2Te6. For a moment, I thought my knowledge of the periodic table was slipping, since I couldn't remember the element Gr. It turns out that Gr was supposed to be Ge, germanium, but that raises two issues. First, shouldn't the peer reviewers and proofreaders at a top journal catch this error? But more curiously, it appears that this formula is a mistake that has been copied around several times.
The Science paper [1] states, "Intrinsic ferromagnetism in these materials was discovered in Cr2Gr2Te6 and CrI3 down to the bilayer and monolayer thickness limit in 2017." I checked the referenced paper [2] and verified that the correct compound is Cr2Ge2Te6, with Ge for germanium.
But in the process, I found more publications that specifically mention the 2017 discovery of intrinsic ferromagnetism in both Cr2Gr2Te6 and CrI3. A 2021 paper in Nanoscale [3] says, "Since the discovery of intrinsic ferromagnetism in atomically thin Cr2Gr2Te6 and CrI3 in 2017, research on two-dimensional (2D) magnetic materials has become a highlighted topic." Then, a 2023 book chaper [4] opens with the abstract: "Since the discovery of intrinsic long-range magnetic order in two-dimensional (2D) layered magnets, e.g., Cr2Gr2Te6 and CrI3 in 2017, [...]"
This illustrates how easy it is for a random phrase to get copied around with nobody checking it. (Earlier, I found a bogus computer definition that has persisted for over 50 years.) To be sure, these could all be independent typos—it's an easy typo to make since Ge and Gr are neighbors on the keyboard and Cr2Gr2 scans better than Cr2Ge2. A few other papers [5, 6, 7] have the same typo, but in different contexts. My bigger concern is that once AI picks up the erroneous formula, it will propagate as misinformation forever. I hope that by calling out this error, I can bring an end to it. In any case, if anyone ends up here after a web search, I can at least confirm that there isn't a new element Gr and the real compound is Cr2Ge2Te6, chromium germanium telluride.
A shiny crystal of Cr2Ge2Te6, about 5mm across. Photo courtesy of 2D Semiconductors, a supplier of quantum materials.
A shiny crystal of Cr2Ge2Te6 about 5mm across. Photo courtesy of 2D Semiconductors, a supplier of quantum materials.
References
[1] He, B. et al. (2025) ‘Strain-coupled, crystalline polymer-inorganic interfaces for efficient magnetoelectric sensing’, Science, 389(6760), pp 623-631. (link)
[2] Gong, C. et al. (2017) ‘Discovery of intrinsic ferromagnetism in two-dimensional van der Waals crystals’, Nature, 546(7657), pp. 265–269. (link)
[3] Zhang, S. et al. (2021) ‘Two-dimensional magnetic materials: structures, properties and external controls’, Nanoscale, 13(3), pp. 1398–1424. (link)
[4] Yin, T. (2024) ‘Novel Light-Matter Interactions in 2D Magnets’, in D. Ranjan Sahu (ed.) Modern Permanent Magnets - Fundamentals and Applications. (link)
[5] Zhao, B. et al. (2023) ‘Strong perpendicular anisotropic ferromagnet Fe3GeTe2/graphene van der Waals heterostructure’, Journal of Physics D: Applied Physics, 56(9) 094001. (link)
[6] Ren, H. and Lan, M. (2023) ‘Progress and Prospects in Metallic FexGeTe2 (3≤x≤7) Ferromagnets’, Molecules, 28(21), p. 7244. (link)
[7] Hu, S. et al. (2019) 'Anomalous Hall effect in Cr2Gr2Te6/Pt hybride structure', Taiwan-Japan Joint Workshop on Condensed Matter Physics for Young Researchers, Saga, Japan. (link)
Here be dragons: Preventing static damage, latchup, and metastability in the 386
I've been reverse-engineering the Intel 386 processor (from 1985), and I've come across some interesting circuits for the chip's input/output (I/O) pins. Since these pins communicate with the outside world, they face special dangers: static electricity and latchup can destroy the chip, while metastability can cause serious malfunctions. These I/O circuits are completely different from the logic circuits in the 386, and I've come across a previously-undescribed flip-flop circuit, so I'm venturing into uncharted territory. In this article, I take a close look at how the I/O circuitry protects the 386 from the "dragons" that can destroy it.
The 386 die, zooming in on some of the bond pad circuits. The colors change due to the effects of different microscope lenses. Click this image (or any other) for a larger version.
The photo above shows the die of the 386 under a microscope. The dark, complex patterns arranged in rectangular regions arise from the two layers of metal that connect the circuits on the 386 chip. Not visible are the transistors, formed from silicon and polysilicon and hidden beneath the metal. Around the perimeter of this fingernail-sized silicon die, 141 square bond pads provide the connections between the chip and the outside world; tiny gold bond wires connect the bond pads to the package. Next to each I/O pad, specialized circuitry provides the electrical interface between the chip and the external components while protecting the chip. I've zoomed in on three groups of these bond pads along with the associated I/O circuits. The circuits at the top (for data pins) and the left (for address pins) are completely different from the control pin circuits at the bottom, showing how the circuitry varies with the pin's function.
Static electricity
The first dragon that threatens the 386 is static electricity, able to burn a hole in the chip. MOS transistors are constructed with a thin insulating oxide layer underneath the transistor's gate. In the 386, this fragile, glass-like oxide layer is just 250 nm thick, the thickness of a virus. Static electricity, even a small amount, can blow a hole through this oxide layer and destroy the chip. If you've ever walked across a carpet and felt a spark when you touch a doorknob, you've generated at least 3000 volts of chip-destroying static electricity. Intel recommends an anti-static mat and a grounding wrist strap when installing a processor to avoid the danger of static electricity, also known as Electrostatic Discharge or ESD.1
To reduce the risk of ESD damage, chips have protection diodes and other components in their I/O circuitry. The schematic below shows the circuit for a typical 386 input. The goal is to prevent static discharge from reaching the inverter, where it could destroy the inverter's transistors. The diodes next to the pad provide the first layer of protection; they redirect excess voltage to the +5 rail or ground. Next, the resistor reduces the current that can reach the inverter. The third diode provides a final layer of protection. (One unusual feature of this input—unrelated to ESD—is that the input has a pull-up, which is implemented with a transistor that acts like a 20kΩ resistor.2)
Schematic for the BS16# pad circuit. The BS16# signal indicates to the 386 if the external bus is 16 bits or 32 bits.
The image below shows how this circuit appears on the die. For this photo, I dissolved the metal layers with acids, stripping the die down to the silicon to make the transistors visible. The diodes and pull-up resistor are implemented with transistors.3 Large grids of transistors form the pad-side diodes, while the third diode is above. The current-limiting protection resistor is implemented with polysilicon, which provides higher resistance than metal wiring. The capacitor is implemented with a plate of polysilicon over silicon, separated by a thin oxide layer. As you can see, the protection circuitry occupies much more area than the inverters that process the signal.
The circuit for BS16# on the die. The green areas are where the oxide layer was incompletely removed.
Latchup
The transistors in the 386 are created by doping silicon with impurities to change its properties, creating regions of "N-type" and "P-type" silicon. The 386 chip, like most processors, is built from CMOS technology, so it uses two types of transistors: NMOS and PMOS. The 386 starts from a wafer of N-type silicon and PMOS transistors are formed by doping tiny regions to form P-type silicon embedded in the underlying N-type silicon. NMOS transistors are the opposite, with N-type silicon embedded in P-type silicon. To hold the NMOS transistors, "wells" of P-type silicon are formed, as shown in the cross-section diagram below. Thus, the 386 chip contains complex patterns of P-type and N-type silicon that form its 285,000 transistors.
The structure of NMOS and PMOS transistors in the 386 forms parasitic NPN and PNP transistors. This diagram is the opposite of other latchup diagrams because the 386 uses N substrate, the opposite of modern chips with P substrate.
But something dangerous lurks below the surface, the fire-breathing dragon of latchup waiting to burn up the chip. The problem is that these regions of N-type and P-type silicon form unwanted, "parasitic" transistors underneath the desired transistors. In normal circumstances, these parasitic NPN and PNP transistors are inactive and can be ignored. But if a current flows beneath the surface, through the silicon substrate, it can turn on a parasitic transistor and awaken the dreaded latchup.4 The parasitic transistors form a feedback loop, so if one transistor starts to turn on, it turns on the other transistor, and so forth, until both transistors are fully on, a state called latchup.5 Moreover, the feedback loop will maintain latchup until the chip's power is removed.6 During latchup, the chip's power and ground are shorted through the parasitic transistors, causing high current flow that can destroy the chip by overheating it or even melting bond wires.
Latchup can be triggered in many ways, from power supply overvoltage to radiation, but a chip's I/O pins are the primary risk because signals from the outside world are unpredictable. For instance, suppose a floppy drive is connected to the 386 and the drive sends a signal with a voltage higher than the 386's 5-volt supply. (This could happen due to a voltage surge in the drive, reflection in a signal line, or even connecting a cable.) Current will flow through the 386's protection diodes, the diodes that were described in the previous section.7 If this current flows through the chip's silicon substrate, it can trigger latchup and destroy the processor.
Because of this danger, the 386's I/O pads are designed to prevent latchup. One solution is to block the unwanted currents through the substrate, essentially putting fences around the transistors to keep malicious currents from escaping into the substrate. In the 386, this fence consists of "guard rings" around the I/O transistors and diodes. These rings prevent latchup by blocking unwanted current flow and safely redirecting it to power or ground.
The circuitry for the W/R# output pad. (The W/R# signal tells the computer's memory and I/O if the 386 is performing a write operation or a read operation.) I removed the metal and polysilicon to show the underlying silicon.
The diagram above shows the double guard rings for a typical I/O pad.8 Separate guard rings protect the NMOS transistors and the PMOS transistors. The NMOS transistors have an inner guard ring of P-type silicon connected to ground (blue) and an outer guard ring of N-type silicon connected to +5 (red). The rings are reversed for the PMOS transistors. The guard rings take up significant space on the die, but this space isn't wasted since the rings protect the chip from latchup.
Metastability
The final dragon is metastability: it (probably) won't destroy the chip, but it can cause serious malfunctions.9 Metastability is a peculiar problem where a digital signal can take an unbounded amount of time to settle into a zero or a one. In other words, the circuit temporarily refuses to act digitally and shows its underlying analog nature.10 Metastability was controversial in the 1960s and the 1970s, with many electrical engineers not believing it existed or considering it irrelevant. Nowadays, metastability is well understood, with special circuits to prevent it, but metastability can never be completely eliminated.
In a processor, everything is synchronized to its clock. While a modern processor has a clock speed of several gigahertz, the 386's clock ran at 12 to 33 megahertz. Inside the processor, signals are carefully organized to change according to the clock—that's why your computer runs faster with a higher clock speed. The problem is that external signals may be independent of the CPU's clock. For instance, a disk drive could send an interrupt to the computer when data is ready, which depends on the timing of the spinning disk. If this interrupt arrives at just the wrong time, it can trigger metastability.
A metastable signal settling to a high or low signal after an indefinite time. This image was used to promote a class on metastability in 1974. From My Work on All Things Metastable by Thomas Chaney.
In more detail, processors use flip-flops to hold signals under the control of the clock. An "edge-triggered" flip-flop grabs its input at the moment the clock goes high (the "rising edge") and holds this value until the next clock cycle. Everything is fine if the value is stable when the clock changes: if the input signal switches from low to high before the clock edge, the flip-flop will hold this high value. And if the input signal switches from low to high after the clock edge, the flip-flop will hold the low value, since the input was low at the clock edge. But what happens if the input changes from low to high at the exact time that the clock switches? Usually, the flip-flop will pick either low or high. But very rarely, maybe a few times out of a billion, the flip-flop will hesitate in between, neither low nor high. The flip-flop may take a few nanoseconds before it "decides" on a low or high value, and the value will be intermediate until then.
The photo above illustrates a metastable signal, spending an unpredictable time between zero and one before settling on a value. The situation is similar to a ball balanced on top of a hill, a point of unstable equilibrium.11 The smallest perturbation will knock the ball down one of the two stable positions at the bottom of the hill, but you don't know which way it will go or how long it will take.
A metaphorical view of metastability as a ball on a hill, able to roll down either side.
Metastability is serious because if a digital signal has a value that is neither 0 nor 1 then downstream circuitry may get confused. For instance, if part of the processor thinks that it received an interrupt and other parts of the processor think that no interrupt happened, chaos will reign as the processor takes contradictory actions. Moreover, waiting a few nanoseconds isn't a cure because the duration of metastability can be arbitrarily long. Waiting helps, since the chance of metastability decreases exponentially with time, but there is no guarantee.12
The obvious solution is to never change an input exactly when the clock changes. The processor is designed so that internal signals are stable when the clock changes, avoiding metastability. Specifically, the designer of a flip-flop specifies the setup time—how long the signal must be stable before the clock edge—and the hold time—how long the signal must be stable after the clock edge. As long as the input satisfies these conditions, typically a few picoseconds long, the flip-flop will function without metastability.
Unfortunately, the setup and hold times can't be guaranteed when the processor receives an external signal that isn't synchronized to its clock, known as an asynchronous signal. For instance, a processor receives interrupt signals when an I/O device has data, but the timing is unpredictable because it depends on mechanical factors such as a keypress or a spinning floppy disk. Most of the time, everything will work fine, but what about the one-in-a-billion case where the timing of the signal is unlucky? (Since modern processors run at multi-gigahertz, one-in-a-billion events are not rare; they can happen multiple times per second.)
One solution is a circuit called a synchronizer that takes an asynchronous signal and synchronizes it to the clock. A synchronizer can be implemented with two flip-flops in series: even if the first flip-flop has a metastable output, chances are that it will resolve to 0 or 1 before the second flip-flop stores the value. Each flip-flop provides an exponential reduction in the chance of metastability, so using two flip-flops drastically reduces the risk. In other words, the circuit will still fail occasionally, but if the mean time between failures (MTBF) is long enough (say, decades instead of seconds), then the risk is acceptable.
The schematic for the BUSY# pin, showing the flip-flops that synchronize the input signal.
The schematic above shows how the 386 uses two flip-flops to minimize metastability. The first flip-flop is a special flip-flop that is based on a sense amplifier. It is much more complicated than a regular flip-flop, but it responds faster, reducing the chance of metastability. It is built from two of the sense-amplifier latches below, which I haven't seen described anywhere. In a DRAM memory chip, a sense amplifier takes a weak signal from a memory cell and rapidly amplifies it into a solid 0 or 1. In this flip-flop, the sense amplifier takes a potentially ambiguous signal and rapidly amplifies it into a 0 or 1. By amplifying the signal quickly, the flip-flop reduces metastability. (See the footnote for details.14)
The sense amplifier latch circuit.
The die photo below shows how this circuitry looks on the die. Each flip-flop is built from two latches; note that the sense-amp latches are larger than the standard latches. As before, the pad has protection diodes inside guard rings. For some reason, however, these diodes have a different structure from the transistor-based diodes described earlier. The 386 has five inputs that use this circuitry to protect against metastability.13 These inputs are all located together at the bottom of the die—it probably makes the layout more compact when neighboring pad circuits are all the same size.
The circuitry for the BUSY# pin, showing the special sense-amplifier latches that reduce metastability.
In summary, the 386's I/O circuits are interesting because they are completely different from the chip's regular logic circuitry. In these circuits, the border between digital and analog breaks down; these circuits handle binary signals, but analog issues dominate the design. Moreover, hidden parasitic transistors play key roles; what you don't see can be more important than what you see. These circuits defend against three dangerous "dragons": static electricity, latchup, and metastability. Intel succeeded in warding off these dragons and the 386 was a success.
For more on the 386 and other chips, follow me on Mastodon (@[email protected]), Bluesky (@righto.com), or RSS. (I've given up on Twitter.) If you want to read more about 386 input circuits, I wrote about the clock pin here
  1. Anti-static precautions are specified in Intel's processor installation instructions. Also see Intel's Electrostatic Discharge and Electrical Overstress Guide. I couldn't find ESD ratings for the 386, but a modern Intel chip is tested to withstand 500 volts or 2000 volts, depending on the test procedure. ↩
  2. The BS16# pin is slightly unusual because it has an internal pull-up resistor. If you look at the datasheet (9.2.3 and Table 9-3 footnotes), a few input pins (ERROR#, BUSY#, and BS16#) have internal pull-up resistors of 20 kΩ, while the PEREQ input pin has an internal pull-down resistor of 20 kΩ. ↩
  3. The protection diode is probably a grounded-gate NMOS (ggNMOS), an NMOS transistor with the gate, source, and body (but not the drain) tied to ground. This forms a parasitic NPN transistor under the MOSFET that dissipates the ESD. (I think that the PMOS protection is the same, except the gate is pulled high, not grounded.) For output pins, the output driver MOSFETs have parasitic transistors that make the output driver "self-protected". One consequence is that the input pads and the output pads look similar (both have large MOS transistors), unlike other chips where the presence of large transistors indicates an output. (Even so, 386 outputs and inputs can be distinguished because outputs have large inverters inside the guard rings to drive the MOSFETs, while inputs do not.) Also see Practical ESD Protection Design. ↩
  4. The 386 uses P-wells in an N-doped substrate. The substrate is heavily doped with antimony, with a lightly doped N epitaxial layer on top. This doping helped provide immunity to latchup. (See "High performance technology, circuits and packaging for the 80386", ICCD 1986.) For the most part, modern chips use the opposite: N-wells with a P-doped substrate. Why the substrate change?
    In the earlier days of CMOS, P-well was standard due to the available doping technology, see N-well and P-well performance comparison. During the 1980s, there was controversy over which was better: P-well or N-well: "It is commonly agreed that P-well technology has a proven reliability record, reduced alpha-particle sensitivity, closer matched p- and n- channel devices, and high gain NPN structures. N-well proponents acknowledge better compatibility and performance with NMOS processing and designs, good substrate quality, availability, and cost, lower junction capacitance, and reduced body effects." (See Design of a CMOS Standard Cell Library.)
    As wafer sizes increased in the 1990s, technology shifted to P-doped substrates because it is difficult to make large N-doped wafers due to the characteristics of the dopants (link). Some chips optimize transistor characteristics by using both types of wells, called a twin-well process. For instance, the Pentium used P-doped wafers and implanted both N and P wells. (See Intel's 0.25 micron, 2.0 volts logic process technology.) ↩
  5. You can also view the parasitic transistors as forming an SCR (Silicon Controlled Rectifier), a four-layer semiconductor device. SCRs were popular in the 1970s because they could handle higher currents and voltages than transistors. But as high-power transistors were developed, SCRs fell out of favor. In particular, once an SCR is turned on, it stays on until power is removed or reversed; this makes SCRs harder to use than transistors. (This is the same characteristic that makes latchup so dangerous.) ↩
  6. Satellites and nuclear missiles have a high risk of latchup due to radiation. Since radiation-induced latchup cannot always be prevented, one technique for dealing with latchup is to detect the excessive current from latchup and then power-cycle the chip. For instance, you can buy a radiation-hardened current limiter chip that will detect excessive current due to latchup and temporarily remove power; this chip sells for the remarkable price of $1780.
    For more on latchup, see the Texas Instruments Latch-Up white paper, as well as Latch-Up, ESD, and Other Phenomena. ↩
  7. The 80386 Hardware Reference Manual discusses how a computer designer can prevent latchup in the 386. The designer is assured that Intel's "CHMOS III" process prevents latchup under normal operating conditions. However, exceeding the voltage limits on I/O pins can cause current surges and latchup. Intel provides three guidelines: observe the maximum ratings for input voltages, never apply power to a 386 pin before the chip is powered up, and terminate I/O signals properly to avoid overshoot and undershoot. ↩
  8. The circuit for the WR# pin is similar to many other output pins. The basic idea is that a large PMOS transistor pulls the output high, while a large NMOS transistor pulls the output low. If the enable input is low, both transistors are turned off and the output floats. (This allows other devices to take over the bus in the HOLD state.)
    Schematic for the WR# pin driver.
    The inverters that control the drive transistors have an unusual layout. These inverters are inside the guard rings, meaning that the inverters are split apart, with the NMOS transistors in one ring and PMOS transistors in the other. The extra wiring adds capacitance to the output which probably makes the inverters slightly slower.
    These inverters have a special design: one inverter is faster to go high than to go low, while the other inverter is the opposite. The motivation is that if both drive transistors are on at the same time, a large current will flow through the transistors from power to ground, producing an unwanted current spike (and potentially latchup). To avoid this, the inverters are designed to turn one drive transistor off faster than turning the other one on. Specifically, the high-side inverter has an extra transistor to quickly pull its output high, while the low-side inverter has an extra transistor to pull the output low. Moreover, the inverter's extra transistor is connected directly to the drive transistors, while the inverter's main output connects through a longer polysilicon path with more resistance, providing an RC delay. I found this layout very puzzling until I realized that the designers were carefully controlling the turn-on and turn-off speeds of these inverters. ↩
  9. In Metastability and Synchronizers: A Tutorial, there's a story of a spacecraft power supply being destroyed by metastability. Supposedly, metastability caused the logic to turn on too many units, overloading and destroying the power supply. I suspect that this is a fictional cautionary tale, rather than an actual incident.
    For more on metastability, see this presentation and this writeup by Tom Chaney, one of the early investigators of metastability. ↩
  10. One of Vonada's Engineering Maxims is "Digital circuits are made from analog parts." Another maxim is "Synchronizing circuits may take forever to make a decision." These maxims and a dozen others are from Don Vonada in DEC's 1978 book Computer Engineering. ↩
  11. Curiously, the definition of metastability in electronics doesn't match the definition in physics and chemistry. In electronics, a metastable state is an unstable equilibrium. In physics and chemistry, however, a metastable state is a stable state, just not the most stable ground state, so a moderate perturbation will knock it from the metastable state to the ground state. (In the hill analogy, it's as if the ball is caught in a small basin partway down the hill.) ↩
  12. In case you're wondering what's going on with metastability at the circuit level, I'll give a brief explanation. A typical flip-flop is based on a latch circuit like the one below, which consists of two inverters and an electronic switch controlled by the clock. When the clock goes high, the inverters are configured into a loop, latching the prior input value. If the input was high, the output from the first inverter is low and the output from the second inverter is high. The loop feeds this output back into the first inverter, so the circuit is stable. Likewise, the circuit can be stable with a low input.
    A latch circuit.
    A latch circuit.
    But what happens if the clock flips the switch as the input is changing, so the input to the first inverter is somewhere between zero and one? We need to consider that an inverter is really an analog device, not a binary device. You can describe it by a "voltage transfer curve" (purple line) that specifies the output voltage for a particular input voltage. For example, if you put in a low input, you get a high output, and vice versa. But there is an equilibrium point where the output voltage is the same as the input voltage. This is where metastability happens.
    The voltage transfer curve for a hypothetical inverter.
    Suppose the input voltage to the inverter is the equilibrium voltage. It's not going to be precisely the equilibrium voltage (because of noise if nothing else), so suppose, for example, that it is 1µV above equilibrium. Note that the transfer curve is very steep around equilibrium, say a slope of 100, so it will greatly amplify the signal away from equilibrium. Thus, if the input is 1µV above equilibrium, the output will be 100µV below equilibrium. Then the next inverter will amplify again, sending a signal 10mV above equilibrium back to the first inverter. The distance will be amplified again, now 1000mV below equilibrium. At this point, you're on the flat part of the curve, so the second inverter will output +5V and the first inverter will output 0V, and the circuit is now stable.
    The point of this is that the equilibrium voltage is an unstable equilibrium, so the circuit will eventually settle into the +5V or 0V states. But it may take an arbitrary number of loops through the inverters, depending on how close the starting point was to equilibrium. (The signal is continuous, so referring to "loops" is a simplification.) Also note that the distance from equilibrium is amplified exponentially with time. This is why the chance of metastability decreases exponentially with time. ↩
  13. Looking at the die shows that the pins with metastability protection are INTR, NMI, PEREQ, ERROR#, and BUSY#. The 80386 Hardware Reference Manual lists these same five pins as asynchronous—I like it when I spot something unusual on the die and then discover that it matches an obscure statement in the documentation. The interrupt pins INTR and NMI are asynchronous because they come from external sources that may not be using the 386's clock. But what about PEREQ, ERROR#, and BUSY#? These pins are part of the interface with an external math coprocessor (the 287 or 387 chip). In most cases, the coprocessor uses the 386's clock. However, the 387 supported a little-used asynchronous mode where the processor and the coprocessor could run at different speeds. ↩
  14. The 386's metastability flip-flop is constructed with an unusual circuit. It has two latch stages (which is normal), but instead of using two inverters in a loop, it uses a sense-amplifier circuit. The idea of the sense amplifier is that it takes a differential input. When the clock enables the sense amplifier, it drives the higher input high and the lower input low (the inputs are also the outputs). (Sense amplifiers are used in dynamic RAM chips to amplify the tiny signals from a RAM cell to form a 0 or 1. At the same time, the amplifier refreshes the DRAM cell by generating full voltages.) Note that the sense amplifier's inputs also act as outputs; inputs during clock phase 1 and outputs during phase 2.
    The schematic shows one of the latch stages; the complete flip-flop has a second stage, identical except that the clock phases are switched. This latch is much more complex than the typical 386 latch; 14 transistors versus 6 or 8. The sense amplifier is similar to two inverters in a loop, except they share a limited power current and a limited ground current. As one inverter starts to go high, it "steals" the supply current from the other. Meanwhile, the other inverter "steals" the ground current. Thus, a small difference in inputs is amplified, just as in a differential amplifier. Thus, by combining the amplification of a differential amplifier with the amplification of the inverter loop, this circuit reaches its final state faster than a regular inverter loop.
    In more detail, during the first clock phase, the two inverters at the top generate the inverted and non-inverted signals. (In a metastable situation, these will be close to the midpoint, not binary.) During the second clock phase, the sense amplifier is activated. You can think of it as a differential amplifier with cross-coupling. If one input is slightly higher than the other, the amplifier pulls that input higher and the input lower, amplifying the difference. (The point is to quickly make the difference large enough to resolve the metastability.)
    I couldn't find any latches like this in the literature. Comparative Analysis and Study of Metastability on High-Performance Flip-Flops describes eleven high-performance flip-flops. It includes two flip-flops that are based on sense amplifiers, but their circuits are very different from the 386 circuit. Perhaps the 386 circuit is an Intel design that was never publicized. In any case, let me know if this circuit has an official name. ↩
A CT scanner reveals surprises inside the 386 processor's ceramic package
Intel released the 386 processor in 1985, the first 32-bit chip in the x86 line. This chip was packaged in a ceramic square with 132 gold-plated pins protruding from the underside, fitting into a socket on the motherboard. While this package may seem boring, a lot more is going on inside it than you might expect. Lumafield performed a 3-D CT scan of the chip for me, revealing six layers of complex wiring hidden inside the ceramic package. Moreover, the chip has nearly invisible metal wires connected to the sides of the package, the spikes below. The scan also revealed that the 386 has two separate power and ground networks: one for I/O and one for the CPU's logic.
A CT scan of the 386 package. The ceramic package doesn't show up in this image, but it encloses the spiky wires.
The package, below, provides no hint of the complex wiring embedded inside the ceramic. The silicon die is normally not visible, but I removed the square metal lid that covers it.1 As a result, you can also see the two tiers of gold contacts that surround the silicon die.
The 386 package with the lid over the die removed.
Intel selected the 132-pin ceramic package to meet the requirements of a high pin count, good thermal characteristics, and low-noise power to the die.2: However, standard packages didn't provide sufficient power, so Intel designed a custom package with "single-row double shelf bonding to two signal layers and four power and ground planes." In other words, the die's bond wires are connected to the two shelves (or tiers) of pads surrounding the die. Internally, the package is like a 6-layer printed-circuit board made from ceramic.
Package cross-section. Redrawn from "High Performance Technology, Circuits and Packaging for the 80386".
The photo below shows the two tiers of pads with tiny gold bond wires attached: I measured the bond wires at 35 µm in diameter, thinner than a typical human hair. Some pads have up to five wires attached to support more current for the power and ground pads. You can consider the package to be a hierarchical interface from the tiny circuits on the die to the much larger features of the computer's motherboard. Specifically, the die has a feature size of 1 µm, while the metal wiring on top of the die has 6 µm spacing. The chip's wiring connects to the chip's bond pads, which have 0.01" spacing (.25 mm). The bond wires connect to the package's pads, which have 0.02" spacing (.5 mm); double the spacing because there are two tiers. The package connects these pads to the pin grid with 0.1" spacing (2.54 mm). Thus, the scale expands by about a factor of 2500 from the die's microscopic circuitry to the chip's pins. `
Close-up of the bond wires.
The ceramic package is manufactured through a complicated process.4 The process starts with flexible ceramic "green sheets", consisting of ceramic powder mixed with a binding agent. After holes for vias are created in the sheet, tungsten paste is silk-screened onto the sheet to form the wiring. The sheets are stacked, laminated under pressure, and then sintered at high temperature (1500ºC to 1600ºC) to create the rigid ceramic. The pins are brazed onto the bottom of the chip. Next, the pins and the inner contacts for the die are electroplated with gold.3 The die is mounted, gold bond wires are attached, and a metal cap is soldered over the die to encapsulate it. Finally, the packaged chip is tested, the package is labeled, and the chip is ready to be sold.
The diagram below shows a close-up of a signal layer inside the package. The pins are connected to the package's shelf pads through metal traces, spectacularly colored in the CT scan. (These traces are surprisingly wide and free-form; I expected narrower traces to reduce capacitance.) Bond wires connect the shelf pads to the bond pads on the silicon die. (The die image is added to the diagram; it is not part of the CT scan.) The large red circles are vias from the pins. Some vias connect to this signal layer, while other vias pass through to other layers. The smaller red circles are connections to a power layer; because the shelf pads are only on the two signal layers, the six power planes have connections to the signal layers for bonding. Since bond wires are only connected on the signal layers, the power layers need connections to pads on the signal layers.
A close-up of a signal layer. The die image is pasted in.
The diagram below shows the corresponding portion of a power layer. A power layer looks completely different from a signal layer; it is a single conductive plane with holes. The grid of smaller holes allows the ceramic above and below this layer to bond, forming a solid piece of ceramic. The larger holes surround pin vias (red dots), allowing pin connections to pass through to a different layer. The red dots that contact the sheet are where power pins connect to this layer. Because the only connections to the die are from the signal layers, the power layers have connections to the signal layers; these are the smaller dots near the bond wires, either power vias passing through or vias connected to this layer.
A close-up of a power layer, specifically I/O Vss. The wavy blue regions are artifacts from neighboring layers. The die image is pasted in.
With the JavaScript tool below, you can look at the package, layer by layer. Click on a radio button to select a layer. By observing the path of a pin through the layers, you can see where it ends up. For instance, the upper left pin passes through multiple layers until the upper signals layer connects it to the die. The pin to its right passes through all the layers until it reaches the logic Vcc plane on top. (Vcc is the 5-volt supply that powers the chip, called Vcc for historical reasons.)
If you select the logic Vcc plane above, you'll see a bright blotchy square in the center. This is not the die itself, I think, but the adhesive that attaches the die to the package, epoxy filled with silver to provide thermal and electrical conductivity. Since silver blocks X-rays, it is highly visible in the image.
Side contacts for electroplating
What surprised me most about the scans was seeing wires that stick out to the sides of the package. These wires are used during manufacturing when the pins are electroplated with gold.5 In order to electroplate the pins, each pin must be connected to a negative voltage so it can function as a cathode. This is accomplished by giving each pin a separate wire that goes to the edge of the package.
This diagram below compares the CT scan (above) to a visual side view of the package (below). The wires are almost invisible, but can be seen as darker spots. The arrows show how three of these spots match with the CT scan; you can match up the other spots.6
A close-up of the side of the package compared to the CT scan, showing the edge contacts. I lightly sanded the edge of the package to make the contacts more visible. Even so, they are almost invisible.
Two power networks
According to the datasheet, the 386 has 20 pins connected to +5V power (Vcc) and 21 pins connected to ground (Vss). Studying the die, I noticed that the I/O circuitry in the 386 has separate power and ground connections from the logic circuitry. The motivation is that the output pins require high-current driver circuits. When a pin switches from 0 to 1 or vice versa, this can cause a spike on the power and ground wiring. If this spike is too large, it can interfere with the processor's logic, causing malfunctions. The solution is to use separate power wiring inside the chip for the I/O circuitry and for the logic circuitry, connected to separate pins. On the motherboard, these pins are all connected to the same power and ground, but decoupling capacitors absorb the I/O spikes before they can flow into the chip's logic.
The diagram below shows how the two power and ground networks look on the die, with separate pads and wiring. The square bond pads are at the top, with dark bond wires attached. The white lines are the two layers of metal wiring, and the darker regions are circuitry. Each I/O pin has a driver circuit below it, consisting of relatively large transistors to pull the pin high or low. This circuitry is powered by the horizontal lines for I/O Vcc (light red) and I/O ground (Vss, light blue). Underneath each I/O driver is a small logic circuit, powered by thinner Vcc (dark red) and Vss (dark blue). Thicker Vss and Vcc wiring goes to the logic in the rest of the chip. Thus, if the I/O circuitry causes power fluctuations, the logic circuit remains undisturbed, protected by its separate power wiring.
A close-up of the top of the die, showing the power wiring and the circuitry for seven data pins.
The datasheet doesn't mention the separate I/O and logic power networks, but by using the CT scans, I determined which pins power I/O, and which pins power logic. In the diagram below, the light red and blue pins are power and ground for I/O, while the dark red and blue pins are power and ground for logic. The pins are scattered across the package, allowing power to be supplied to all four sides of the die.
The pinout from the Intel386DX Microprocessor Datasheet. This is the view from the pin side.
"No Connect" pins
As the diagram above shows, the 386 has eight pins labeled "NC" (No Connect)—when the chip is installed in a computer, the motherboard must leave these pins unconnected. You might think that the 132-pin package simply has eight extra, unneeded pins, but it's more complicated than that. The photo below shows five bond pads at the bottom of the 386 die. Three of these pads have bond wires attached, but two have no bond wires: these correspond to No Connect pins. Note the black marks in the middle of the pads: the marks are from test probes that were applied to the die during testing.7 The No Connect pads presumably have a function during this testing process, providing access to an important internal signal.
A close-up of the die showing three bond pads with bond wires and two bond pads without bond wires.
Seven of the eight No Connect pads are almost connected: the package has a spot for a bond wire in the die cavity and the package has internal wiring to a No Connect pin. The only thing missing is the bond wire between the pad and the die cavity. Thus, by adding bond wires, Intel could easily create special chips with these pins connected, perhaps for debugging the test process itself.
The surprising thing is that one of the No Connect pads does have the bond wire in place, completing the connection to the external pin. (I marked this pin in green in the pinout diagram earlier.) From the circuitry on the die, this pin appears to be an output. If someone with a 386 chip hooks this pin to an oscilloscope, maybe they will see something interesting.
Labeling the pads on the die
The earlier 8086 processor, for example, is packaged in a DIP (Dual-Inline Package) with two rows of pins. This makes it straightforward to figure out which pin (and thus which function) is connected to each pad on the die. However, since the 386 has a two-dimensional grid of pins, the mapping to the pads is unclear. You can guess that pins are connected to a nearby pad, but ambiguity remains. Without knowing the function of each pad, I have a harder time reverse-engineering the die.
In fact, my primary motivation for scanning the 386 package was to determine the pin-to-pad mapping and thus the function of each pad.8 Once I had the CT data, I was able to trace out each hidden connection between the pad and the external pin. The image below shows some of the labels; click here for the full, completely labeled image. As far as I know, this information hasn't been available outside Intel until now.
A close-up of the 386 die showing the labels for some of the pins.
Intel's early processors were hampered by inferior packages, but by the time of the 386, Intel had realized the importance of packaging. In Intel's early days, management held the bizarre belief that chips should never have more than 16 pins, even though other companies used 40-pin packages. Thus, Intel's first microprocessor, the 4004 (1971), was crammed into a 16-pin package, limiting its performance. By 1972, larger memory chips forced Intel to move to 18-pin packages, extremely reluctantly.9 The eight-bit 8008 processor (1972) took advantage of this slightly larger package, but performance still suffered because signals were forced to share pins. Finally, Intel moved to the standard 40-pin package for the 8080 processor (1974), contributing to the chip's success. In the 1980s, pin-grid arrays became popular in the industry as chips required more and more pins. Intel used a ceramic pin grid array (PGA) with 68 pins for the 186 and 286 processors (1982), followed by the 132-pin package for the 386 (1985).
The main drawback of the ceramic package was its cost. According to the 386 oral history, the cost of the 386 die decreased over time to the point where the chip's package cost as much as the die. To counteract this, Intel introduced a low-cost plastic package for the 386 that cost just a dollar to manufacture, the Plastic Quad Flat Package (PQFP) (details).
In later Intel processors, the number of connections exponentially increased. A typical modern laptop processor uses a Ball Grid Array with 2049 solder balls; the chip is soldered directly onto the circuit board. Other Intel processors use a Land Grid Array (LGA): the chip has flat contacts called lands, while the socket has the pins. Some Xeon processors have 7529 contacts, a remarkable growth from the 16 pins of the Intel 4004.
From the outside, the 386's package looks like a plain chunk of ceramic. But the CT scan revealed surprising complexity inside, from numerous contacts for electroplating to six layers of wiring. Perhaps even more secrets lurk in the packages of modern processors.
Follow me on Bluesky (@righto.com), Mastodon (@[email protected]), or RSS. (I've given up on Twitter.) Thanks to Jon Bruner and Lumafield for scanning the chip. Lumafield's interactive CT scan of the 386 package is available here if you to want to examine it yourself. Lumafield also scanned a 1960s cordwood flip-flop and the Soviet Globus spacecraft navigation instrument for us. Thanks to John McMaster for taking 2D X-rays.
  1. I removed the metal lid with a chisel, as hot air failed to desolder the lid. A few pins were bent in the process, but I straightened them out, more or less. ↩
  2. The 386 package is described in "High Performance Technology, Circuits and Packaging for the 80386", Proceedings, ICCD Conference, Oct. 1986. (Also see Design and Test of the 80386 by Pat Gelsinger, former Intel CEO.)
    The paper gives the following requirements for the 386 package:
    1. Large pin count to handle separate 32-bit data and address buses.
    2. Thermal characteristics resulting in junction temperatures under 110°.
    3. Power supply to the chip and I/O able to supply 600mA/ns with noise levels less than 0.4V (chip) and less than 0.8V (I/O).
    The first and second criteria motivated the selection of a 132-pin ceramic pin grid array (PGA). The custom six-layer package was designed to achieve the third objective. The power network is claimed to have an inductance of 4.5 nH per power pad on the device, compared to 12-14 nH for a standard package, about a factor of 3 better.
    The paper states that logic Vcc, logic Vss, I/O Vcc, and I/O Vss each have 10 pins assigned. Curiously, the datasheet states that the 386 has 20 Vcc pins and 21 Vss pins, which doesn't add up. From my investigation, the "extra" pin is assigned to logic Vss, which has 11 pins. ↩
  3. I estimate that the 386 package contains roughly 0.16 grams of gold, currently worth about $16. It's hard to find out how much gold is in a processor since online numbers are all over the place. Many people recover the gold from chips, but the amount of gold one can recover depends on the process used. Moreover, people tend to keep accurate numbers to themselves so they can profit. But I made some estimates after searching around a bit. One person reports 9.69g of gold per kilogram of chips, and other sources seem roughly consistent. A ceramic 386 reportedly weighs 16g. This works out to 160 mg of gold per 386. ↩
  4. I don't have information on Intel's package manufacturing process specifically. This description is based on other descriptions of ceramic packages, so I don't guarantee that the details are correct for the 386. A Fujitsu patent, Package for enclosing semiconductor elements, describes in detail how ceramic packages for LSI chips are manufactured. IBM's process for ceramic multi-chip modules is described in Multi-Layer Ceramics Manufacturing, but it is probably less similar. ↩
  5. An IBM patent, Method for shorting pin grid array pins for plating, describes the prior art of electroplating pins with nickel and/or gold. In particular, it describes using leads to connect all input/output pins to a common bus at the edge of the package, leaving the long leads in the structure. This is exactly what I see in the 386 chip. The patent mentions that a drawback of this approach is that the leads can act as antennas and produce signal cross-talk. Fujitsu patent Package for enclosing semiconductor elements also describes wires that are exposed at side surfaces. This patent covers methods to avoid static electricity damage through these wires. (Picking up a 386 by the sides seems safe, but I guess there is a risk of static damage.)
    Note that each input/output pin requires a separate wire to the edge. However, the multiple pins for each power or ground plane are connected inside the package, so they do not require individual edge connections; one or two suffice. ↩
  6. To verify that the wires from pins to the edges of the chip exist and are exposed, I used a multimeter and found connectivity between pins and tiny spots on the sides of the chip. ↩
  7. To reduce costs, each die is tested while it is still part of the silicon wafer and each faulty die is marked with an ink spot. The wafer is "diced", cutting it apart into individual dies, and only the functional, unmarked dies are packaged, avoiding the cost of packaging a faulty die. Additional testing takes place after packaging, of course. ↩
  8. I tried several approaches to determine the mapping between pads and pins before using the CT scan. I tried to beep out the connections between the pins and the pads with a multimeter, but because the pads are so tiny, the process was difficult, error-prone, and caused damage to the package.
    I also looked at the pinout of the 386 in a plastic package (datasheet). Since the plastic package has the pins in a single ring around the border, the mapping to the die is straightforward. Unfortunately, the 386 die was slightly redesigned at this time, so some pads were moved around and new pins were added, such as FLT#. It turns out that the pinout for the plastic chip almost matches the die I examined, but not quite. ↩
  9. In his oral history, Federico Faggin, a designer of the 4004, 8008, and Z80 processors, describes Intel's fixation on 16-pin packages. When a memory chip required 18 pins instead of 16, it was "like the sky had dropped from heaven. I never seen so [many] long faces at Intel, over this issue, because it was a religion in Intel; everything had to be 16 pins, in those days. It was a completely silly requirements [sic] to have 16 pins." At the time, other manufacturers were using 40- and 48-pin packages, so there was no technical limitation, just a minor cost saving from the smaller package. ↩
How to reverse engineer an analog chip: the TDA7000 FM radio receiver
Have you ever wanted to reverse engineer an analog chip from a die photo? Wanted to understand what's inside the "black box" of an integrated circuit? In this article, I explain my reverse engineering process, using the Philips TDA7000 FM radio receiver chip as an example. This chip was the first FM radio receiver on a chip.1 It was designed in 1977—an era of large transistors and a single layer of metal—so it is much easier to examine than modern chips. Nonetheless, the TDA7000 is a non-trivial chip with over 100 transistors. It includes common analog circuits such as differential amplifiers and current mirrors, along with more obscure circuits such as Gilbert cell mixers.
Die photo of the TDA7000 with the main functional blocks labeled. Click this image (or any other) for a larger version. Die photo from IEEE's Microchips that Shook the World exhibit page.
The die photo above shows the silicon die of the TDA7000; I've labeled the main functional blocks and some interesting components. Arranged around the border of the chip are 18 bond pads: the pads are connected by thin gold bond wires to the pins of the integrated circuit package. In this chip, the silicon appears greenish, with slightly different colors—gray, pink, and yellow-green—where the silicon has been "doped" with impurities to change its properties. Carefully examining the doping patterns will reveal the transistors, resistors, and other microscopic components that make up the chip.
The most visible part of the die is the metal wiring, the speckled white lines that connect the silicon structures. The metal layer is separated from the silicon underneath by an insulating oxide layer, allowing metal lines to pass over other circuitry without problem. Where a metal wire connects to the underlying silicon, a small white square is visible; this square is a hole in the oxide layer, allowing the metal to contact the silicon.
A close-up of the TDA7000 die, showing metal wiring above circuitry.
This chip has a single layer of metal, so it is much easier to examine than modern chips with a dozen or more layers of metal. However, the single layer of metal made it much more difficult for the designers to route the wiring while avoiding crossing wires. In the die photo above, you can see how the wiring meanders around the circuitry in the middle, going the long way since the direct route is blocked. Later, I'll discuss some of the tricks that the designers used to make the layout successful.
NPN transistors
Transistors are the key components in a chip, acting as switches, amplifiers, and other active devices. While modern integrated circuits are fabricated from MOS transistors, earlier chips such as the TDA7000 were constructed from bipolar transistors: NPN and PNP transistors. The photo below shows an NPN transistor in the TDA7000 as it appears on the chip. The different shades are regions of silicon that have been doped with various impurities, forming N and P regions with different electrical properties. The white lines are the metal wiring connected to the transistor's collector (C), emitter (E), and base (B). Below the die photo, the cross-section diagram shows how the transistor is constructed. The region underneath the emitter forms the N-P-N sandwich that defines the NPN transistor.
An NPN transistor and cross-section, adapted from the die photo. The N+ and P+ regions have more doping than the N and P regions.
The parts of an NPN transistor can be identified by their appearance. The emitter is a compact spot, surrounded by the gray silicon of the base region. The collector is larger and separated from the emitter and base, sometimes separated by a significant distance. The colors may appear different in other chips, but the physical structures are similar. Note that although the base is in the middle conceptually, it is often not in the middle of the physical layout.
The transistor is surrounded by a yellowish-green border of P+ silicon; this border is an important part of the structure because it isolates the transistor from neighboring transistors.2 The isolation border is helpful for reverse-engineering because it indicates the boundaries between transistors.
PNP transistors
You might expect PNP transistors to be similar to NPN transistors, just swapping the roles of N and P silicon. But for a variety of reasons, PNP transistors have an entirely different construction. They consist of a circular emitter (P), surrounded by a ring-shaped base (N), which is surrounded by the collector (P). This forms a P-N-P sandwich horizontally (laterally), unlike the vertical structure of an NPN transistor. In most chips, distinguishing NPN and PNP transistors is straightforward because NPN transistors are rectangular while PNP transistors are circular.
A PNP transistor and cross-section, adapted from the die photo.
The diagram above shows one of the PNP transistors in the TDA7000. As with the NPN transistor, the emitter is a compact spot. The collector consists of gray P-type silicon; in contrast, the base of an NPN transistor consists of gray P-type silicon. Moreover, unlike the NPN transistor, the base contact of the PNP transistor is at a distance, while the collector contact is closer. (This is because most of the silicon inside the isolation boundary is N-type silicon. In a PNP transistor, this region is connected to the base, while in an NPN transistor, this region is connected to the collector.)
It turns out that PNP transistors have poorer performance than NPN transistors for semiconductor reasons3, so most analog circuits use NPN transistors except when PNP transistors are necessary. For instance, the TDA7000 has over 100 NPN transistors but just nine PNP transistors. Accordingly, I'll focus my discussion on NPN transistors.
Resistors
Resistors are a key component of analog chips. The photo below shows a zig-zagging resistor in the TDA7000, formed from gray P-type silicon. The resistance is proportional to the length,4 so large-valued resistors snake back and forth to fit into the available space. The two red arrows indicate the contacts between the ends of the resistor and the metal wiring. Note the isolation region around the resistor, the yellowish border. Without this isolation, two resistors (formed of P-silicon) embedded in N-silicon could form an unintentional PNP transistor.
A resistor on the die of the TDA7000.
Unfortunately, resistors in ICs are very inaccurate; the resistances can vary by 50% from chip to chip. As a result, analog circuits are typically designed to depend on the ratio of resistor values, which is fairly constant within a chip. Moreover, high-value resistors are inconveniently large. We'll see below some techniques to reduce the need for large resistances.
Capacitors
Capacitors are another important component in analog circuits. The capacitor below is a "junction capacitor", which uses a very large reverse-biased diode as a capacitor. The pink "fingers" are N-doped regions, embedded in the gray P-doped silicon. The fingers form a "comb capacitor"; this layout maximizes the perimeter area and thus increases the capacitance. To produce the reverse bias, the N-silicon fingers are connected to the positive voltage supply through the upper metal strip. The P silicon is connected to the circuit through the lower metal strip.
A capacitor in the TDA7000. I've blurred the unrelated circuitry.
How does a diode junction form a capacitor? When a diode is reverse-biased, the contact region between N and P silicon becomes "depleted", forming a thin insulating region between the two conductive silicon regions. Since an insulator between two conducting surfaces forms a capacitor, the diode acts as a capacitor. One problem with a diode capacitor is that the capacitance varies with the voltage because the thickness of the depletion region changes with voltage. But as we'll see later, the TDA7000's tuning circuit turns this disadvantage into a feature.
Other chips often create a capacitor with a plate of metal over silicon, separated by a thin layer of oxide or other dielectric. However, the manufacturing process for bipolar chips generally doesn't provide thin oxide, so junction capacitors are a common alternative.5 On-chip capacitors take up a lot of space and have relatively small capacitance, so IC designers try to avoid capacitors. The TDA7000 has seven on-chip capacitors but most of the capacitors in this design are larger, external capacitors: the chip uses 12 of its 18 pins just to connect external capacitors to the necessary points in the internal circuitry.
Important analog circuits
A few circuits are very common in analog chips. In this section, I'll explain some of these circuits, but first, I'll give a highly simplified explanation of an NPN transistor, the minimum you should know for reverse engineering. (PNP transistors are similar, except the polarities of the voltages and currents are reversed. Since PNP transistors are rare in the TDA7000, I won't go into details.)
In a transistor, the base controls the current between the collector and the emitter, allowing the transistor to operate as a switch or an amplifier. Specifically, if a small current flows from the base of an NPN transistor to the emitter, a much larger current can flow from the collector to the emitter, larger, perhaps, by a factor of 100.6 To get a current to flow, the base must be about 0.6 volts higher than the emitter. As the base voltage continues to increase, the base-emitter current increases exponentially, causing the collector-emitter current to increase. (Normally, a resistor will ensure that the base doesn't get much more than 0.6V above the emitter, so the currents stay reasonable.)
A comparison of the behavior of NPN transistors and PNP transistors.
NPN transistor circuits have some general characteristics. When there is no base current, the transistor is off: the collector is high and the emitter is low. When the transistor turns on, the current through the transistor pulls the collector voltage lower and the emitter voltage higher. Thus, in a rough sense, the emitter is the non-inverting output and the collector is the inverting output.
The complete behavior of transistors is much more complicated. The nice thing about reverse engineering is that I can assume that the circuit works: the designers needed to consider factors such as the Early effect, capacitance, and beta, but I can ignore them.
Emitter follower
One of the simplest transistor circuits is the emitter follower. In this circuit, the emitter voltage follows the base voltage, staying about 0.6 volts below the base. (The 0.6 volt drop is also called a "diode drop" because the base-emitter junction acts like a diode.)
An emitter follower circuit.
This behavior can be explained by a feedback loop. If the emitter voltage is too high, the current from the base to the emitter drops, so the current through the collector drops due to the transistor's amplification. Less current through the resistor reduces the voltage across the resistor (from Ohm's Law), so the emitter voltage goes down. Conversely, if the emitter voltage is too low, the base-emitter current increases, increasing the collector current. This increases the voltage across the resistor, and the emitter voltage goes up. Thus, the emitter voltage adjusts until the circuit is stable; at this point, the emitter is 0.6 volts below the base.
You might wonder why an emitter follower is useful. Although the output voltage is lower, the transistor can supply a much higher current. That is, the emitter follower amplifies a weak input current into a stronger output current. Moreover, the circuitry on the input side is isolated from the circuitry on the output side, preventing distortion or feedback.
Current mirror
Most analog chips make extensive use of a circuit called a current mirror. The idea is you start with one known current, and then you can "clone" multiple copies of the current with a simple transistor circuit, the current mirror.
In the following circuit, a current mirror is implemented with two identical PNP transistors. A reference current passes through the transistor on the right. (In this case, the current is set by the resistor.) Since both transistors have the same emitter voltage and base voltage, they source the same current, so the current on the left matches the reference current (more or less).7
A current mirror circuit using PNP transistors.
A common use of a current mirror is to replace resistors. As mentioned earlier, resistors inside ICs are inconveniently large. It saves space to use a current mirror instead of multiple resistors whenever possible. Moreover, the current mirror is relatively insensitive to the voltages on the different branches, unlike resistors. Finally, by changing the size of the transistors (or using multiple collectors of different sizes), a current mirror can provide different currents.
A current mirror on the TDA7000 die.
The TDA7000 doesn't use current mirrors as much as I'd expect, but it has a few. The die photo above shows one of its current mirrors, constructed from PNP transistors with their distinctive round appearance. Two important features will help you recognize a current mirror. First, one transistor has its base and collector connected; this is the transistor that controls the current. In the photo, the transistor on the right has this connection. Second, the bases of the two transistors are connected. This isn't obvious above because the connection is through the silicon, rather than in the metal. The trick is that these PNP transistors are inside the same isolation region. If you look at the earlier cross-section of a PNP transistor, the whole N-silicon region is connected to the base. Thus, two PNP transistors in the same isolation region have their bases invisibly linked, even though there is just one base contact from the metal layer.
Current sources and sinks
Analog circuits frequently need a constant current. A straightforward approach is to use a resistor; if a constant voltage is applied, the resistor will produce a constant current. One disadvantage is that circuits can cause the voltage to vary, generating unwanted current fluctuations. Moreover, to produce a small current (and minimize power consumption), the resistor may need to be inconveniently large. Instead, chips often use a simple circuit to control the current: this circuit is called a "current sink" if the current flows into it and a "current source" if the current flows out of it.
Many chips use a current mirror as a current source or sink instead. However, the TDA7000 uses a different approach: a transistor, a resistor, and a reference voltage.8 The transistor acts like an emitter follower, causing a fixed voltage across the resistor. By Ohm's Law, this yields a fixed current. Thus, the circuit sinks a fixed current, controlled by the reference voltage and the size of the resistor. By using a low reference voltage, the resistor can be kept small.
The current sink circuit used in the TDA7000.
Differential pair amplifier
If you see two transistors with the emitters connected, chances are that it is a differential amplifier: the most common two-transistor subcircuit used in analog ICs.9 The idea of a differential amplifier is that it takes the difference of two inputs and amplifies the result. The differential amplifier is the basis of the operational amplifier (op amp), the comparator, and other circuits. The TDA7000 uses multiple differential pairs for amplification. For filtering, the TDA7000 uses op-amps, formed from differential amplifiers.10
The schematic below shows a simple differential pair. The current sink at the bottom provides a fixed current I, which is split between the two input transistors. If the input voltages are equal, the current will be split equally into the two branches (I1 and I2). But if one of the input voltages is a bit higher than the other, the corresponding transistor will conduct more current, so that branch gets more current and the other branch gets less. The resistors in each branch convert the current to a voltage; either side can provide the output. A small difference in the input voltages results in a large output voltage, providing the amplification. (Alternatively, both sides can be used as a differential output, which can be fed into a second differential amplifier stage to provide more amplification. Note that the two branches have opposite polarity: when one goes up, the other goes down.)
Schematic of a simple differential pair circuit.  The current sink sends a fixed current I through the differential pair.  If the two inputs are equal, the current is split equally between the two branches.  Otherwise, the branch with the higher input voltage gets most of the current.
The diagram below shows the locations of differential amps, voltage references, mixers, and current mirrors. As you can see, these circuits are extensively used in the TDA7000.
The die with key circuits labeled.
Tips on tracing out circuitry
Over the years, I've found various techniques helpful for tracing out the circuitry in an IC. In this section, I'll describe some of those techniques.
First, take a look at the datasheet if available. In the case of the TDA7000, the datasheet and application note provide a detailed block diagram and a description of the functionality.21 Sometimes datasheets include a schematic of the chip, but don't be too trusting: datasheet schematics are often simplified. Moreover, different manufacturers may use wildly different implementations for the same part number. Patents can also be helpful, but they may be significantly different from the product.
Mapping the pinout in the datasheet to the pads on the die will make reverse engineering much easier. The power and ground pads are usually distinctive, with thick traces that go to all parts of the chip, as shown in the photo below. Once you have identified the power and ground pads, you can assign the other pads in sequence from the datasheet. Make sure that these pad assignments make sense. For instance, the TDA7000 datasheet shows special circuitry between pads 5 and 6 and between pads 13 and 14; the corresponding tuning diodes and RF transistors are visible on the die. In most chips, you can distinguish output pins by the large driver transistors next to the pad, but this turns out not to help with the TDA7000. Finally, note that chips sometimes have test pads that don't show up in the datasheet. For instance, the TDA7000 has a test pad, shown below; you can tell that it is a test pad because it doesn't have a bond wire.
Ground, power, and test pads in the TDA7000.
Once I've determined the power and ground pads, I trace out all the power and ground connections on the die. This makes it much easier to understand the circuits and also avoids the annoyance of following a highly-used signal around the chip only to discover that it is simply ground. Note that NPN transistors will have many collectors connected to power and emitters connected to ground, perhaps through resistors. If you find the opposite situation, you probably have power and ground reversed.
For a small chip, a sheet of paper works fine for sketching out the transistors and their connections. But with a larger chip, I find that more structure is necessary to avoid getting mixed up in a maze of twisty little wires, all alike. My solution is to number each component and color each wire as I trace it out, as shown below. I use the program KiCad to draw the schematic, using the same transistor numbering. (The big advantage of KiCad over paper is that I can move circuits around to get a nicer layout.)
This image shows how I color the wires and number the components as I work on it. I use GIMP for drawing on the die, but any drawing program should work fine.
It works better to trace out the circuitry one area at a time, rather than chasing signals all over the chip. Chips are usually designed with locality, so try to avoid following signals for long distances until you've finished up one block. A transistor circuit normally needs to be connected to power (if you follow the collectors) and ground (if you follow the emitters).11 Completing the circuit between power and ground is more likely to give you a useful functional block than randomly tracing out a chain of transistors. (In other words, follow the bases last.)
Finally, I find that a circuit simulator such as LTspice is handy when trying to understand the behavior of mysterious transistor circuits. I'll often whip up a simulation of a small sub-circuit if its behavior is unclear.
How FM radio and the TDA7000 work
Before I explain how the TDA7000 chip works, I'll give some background on FM (Frequency Modulation). Suppose you're listening to a rock song on 97.3 FM. The number means that the radio station is transmitting at a carrier frequency of 97.3 megahertz. The signal, perhaps a Beyoncé song, is encoded by slightly varying the frequency, increasing the frequency when the signal is positive and decreasing the frequency when the signal is negative. The diagram below illustrates frequency modulation; the input signal (red) modulates the output. Keep in mind that the modulation is highly exaggerated in the diagram; the modulation would be invisible in an accurate diagram since a radio broadcast changes the frequency by at most ±75 kHz, less than 0.1% of the carrier frequency.
A diagram showing how a signal (red) modulates the carrier (green), yielding the frequency-modulated output (blue). Created by Gregors, CC BY-SA 2.0.
FM radio's historical competitor is AM (Amplitude Modulation), which varies the height of the signal (the amplitude) rather than the frequency.12 One advantage of FM is that it is more resistant to noise than AM; an event such as lightning will interfere with the signal amplitude but will not change the frequency. Moreover, FM radio provides stereo, while AM radio is mono, but this is due to the implementation of radio stations, not a fundamental characteristic of FM versus AM. (The TDA7000 chip doesn't implement stereo.13) Due to various factors, FM stations require more bandwidth than AM, so FM stations are spaced 200 kHz apart while AM stations are just 10 kHz apart.
An FM receiver such as the TDA7000 must demodulate the radio signal to recover the transmitted audio, converting the changing frequency into a changing signal level. FM is more difficult to demodulate than AM, which can literally be done with a piece of rock: lead sulfide in a crystal detector. There are several ways to implement an FM demodulator; this chip uses a technique called a quadrature detector. The key to a quadrature detector is a circuit that shifts the phase, with the amount of phase shift depending on the frequency. The detector shifts the signal by approximately 90º, multiplies it by the original signal, and then smooths it out with a low-pass filter. If you do this with a sine wave and a 90º phase shift, the result turns out to be 0. But since the phase shift depends on the frequency, a higher frequency gets shifted by more than 90º while a lower frequency gets shifted by less than 90º. The final result turns out to be approximately linear with the frequency, positive for higher frequencies and negative for lower frequencies. Thus, the FM signal is converted into the desired audio signal.
Like most radios, the TDA7000 uses a technique called superheterodyning that was invented around 1917. The problem is that FM radio stations use frequencies from 88.0 MHz to 108.0 MHz. These frequencies are too high to conveniently handle on a chip. Moreover, it is difficult to design a system that can process a wide range of frequencies. The solution is to shift the desired radio station's signal to a frequency that is fixed and much lower. This frequency is called the intermediate frequency. Although FM radios commonly use an intermediate frequency of 10.7 MHz, this was still too high for the TDA7000, so the designers used an intermediate frequency of just 70 kilohertz. This frequency shift is accomplished through superheterodyning.
For example, suppose you want to listen to the radio station at 97.3 MHz. When you tune to this station, you are actually tuning the local oscillator to a frequency that is 70 kHz lower, 97.23 MHz in this case. The local oscillator signal and the radio signal are mixed by multiplying them. If you multiply two sine waves, you get one sine wave at the difference of the frequencies and another sine wave at the sum of the frequencies. In this case, the two signals are at 70 kHz and 194.53 MHz. A low-pass filter (the IF filter) discards everything above 70 kHz, leaving just the desired radio station, now at a fixed and conveniently low frequency. The rest of the radio can then be optimized to work at 70 kHz.
The Gilbert cell multiplier
But how do you multiply two signals? This is accomplished with a circuit called a Gilbert cell.14 This circuit takes two differential inputs, multiplies them, and produces a differential output. The Gilbert cell is a bit tricky to understand,15 but you can think of it as a stack of differential amplifiers, with the current directed along one of four paths, depending on which transistors turn on. For instance, if the A and B inputs are both positive, current will flow through the leftmost transistor, labeled "pos×pos". Likewise, if the A and B inputs are both negative, current flows through the rightmost transistor, labeled "neg×neg". The outputs from both transistors are connected, so both cases produce a positive output. Conversely, if one input is positive and the other is negative, current flows through one of the middle transistors, producing a negative output. Since the multiplier handles all four cases of positive and negative inputs, it is called a "four-quadrant" multiplier.
Schematic of a Gilbert cell.
Although the Gilbert cell is an uncommon circuit in general, the TDA7000 uses it in multiple places. The first mixer implements the superheterodyning. A second mixer provides the FM demodulation, multiplying signals in the quadrature detector described earlier. The TDA7000 also uses a mixer for its correlator, which determines if the chip is tuned to a station or not.16 Finally, a Gilbert cell switches the audio off when the radio is not properly tuned. On the die, the Gilbert cell has a nice symmetry that reflects the schematic.
This is the Gilbert cell for the first mixer. It has capacitors on either side.
The voltage-controlled oscillator
One of the trickiest parts of the TDA7000 design is how it manages to use an intermediate frequency of just 70 kilohertz. The problem is that broadcast FM has a "modulation frequency deviation" of 75 kHz, which means that the broadcast frequency varies by up to ±75 kHz. The mixer shifts the broadcast frequency down to 70 kHz, but the shifted frequency will vary by the same amount as the received signal. How can you have a 70 kilohertz signal that varies by 75 kilohertz? What happens when the frequency goes negative?
The solution is that the local oscillator frequency (i.e., the frequency that the radio is tuned to) is continuously modified to track the variation in the broadcast frequency. Specifically, a change in the received frequency causes the local oscillator frequency to change, but only by 80% as much. For instance, if the received frequency decreases by 5 hertz, the local oscillator frequency is decreased by 4 hertz. Recall that the intermediate frequency is the difference between the two frequencies, generated by the mixer, so the intermediate frequency will decrease by just 1 hertz, not 5 hertz. The result is that as the broadcast frequency changes by ±75 kHz, the local oscillator frequency changes by just ±15 kHz, so it never goes negative.
How does the radio constantly adjust the frequency? The fundamental idea of FM is that the frequency shift corresponds to the output audio signal. Since the output signal tracks the frequency change, the output signal can be used to modify the local oscillator's frequency, using a voltage-controlled oscillator.17 Specifically, the circuit uses special "varicap" diodes that vary their capacitance based on the voltage that is applied. As described earlier, the thickness of a diode's "depletion region" depends on the voltage applied, so the diode's capacitance will vary with voltage. It's not a great capacitor, but it is good enough to adjust the frequency.
The varicap diodes allow the local oscillator frequency to be adjusted.
The image above shows how these diodes appear on the die. The diodes are relatively large and located between two bond pads. The two diodes have interdigitated "fingers"; this increases the capacitance as described earlier with the "comb capacitor". The slightly grayish "background" region is the P-type silicon, with a silicon control line extending to the right. (Changing the voltage on this line changes the capacitance.) Regions of N-type silicon are underneath the metal fingers, forming the PN junctions of the diodes.
Keep in mind that most of the radio tuning is performed with a variable capacitor that is external to the chip and adjusts the frequency from 88 MHz to 108 MHz. The capacitance of the diodes provides the much smaller adjustment of ±60 kHz. Thus, the diodes only need to provide a small capacitance shift.
The VCO and diodes will also adjust the frequency to lock onto the station if the tuning is off by a moderate amount, say, 100 kHz. However, if the tuning is off by a large amount, say, 200 kHz, the FM detector has a "sideband" and the VCO can erroneously lock onto this sideband. This is a problem because the sideband is weak and nonlinear so reception will be bad and will have harmonic distortion. To avoid this problem, the correlator will detect that the tuning is too far off (i.e. the local oscillator is way off from 70 kHz) and will replace the audio with white noise. Thus, the user will realize that they aren't on the station and adjust the tuning, rather than listening to distorted audio and blaming the radio.
Noise source
Where does the radio get the noise signal to replace distorted audio? The noise is generated from the circuit below, which uses the thermal noise from diodes, amplified by a differential amplifier. Specifically, each side of the differential amplifier is connected to two transistors that are wired as diodes (using the base-emitter junction). Random thermal fluctuations in the transistors will produce small voltage changes on either side of the amplifier. The amplifier boosts these fluctuations, creating the white noise output.
The circuit to generate white noise.
Layout tricks and unusual transistors
Because this chip has just one layer of metal, the designers had to go to considerable effort to connect all the components without wires crossing. One common technique to make routing easier is to separate a transistor's emitter, collector, and base, allowing wires to pass over the transistor. The transistor below is an example. Note that the collector, base, and emitter have been stretched apart, allowing one wire to pass between the collector and the base, while two more pass between the base and the emitter. Moreover, the transistor layout is flexible: this one has the base in the middle, while many others have the emitter in the middle. (Putting the collector in the middle won't work since the base needs to be next to the emitter.)
A transistor with gaps between the collector, base, and emitter.
The die photo below illustrates a few more routing tricks. This photo shows one collector, three emitters, and four bases, but there are three transistors. How does that work? First, these three transistors are in the same isolation region, so they share the same "tub" of N-silicon. If you look back at the cross-section of an NPN transistor, you'll see that this tub is connected to the collector contact. Thus, all three transistors share the same collector.18 Next, the two bases on the left are connected to the same gray P-silicon. Thus, the two base contacts are connected and function as a single base. In other words, this is a trick to connect the two base wires together through the silicon, passing under the four other metal wires in the way. Finally, the two transistors on the right have the emitter and base slightly separated so a wire can pass between them. When reverse-engineering a chip, be on the lookout for unusual transistor layouts such as these.
Three transistors with an unusual layout.
When all else failed, the designers could use a "cross-under" to let a wire pass under other wires. The cross-under is essentially a resistor with a relatively low resistance, formed from N-type silicon (pink in the die photo below). Because silicon has much higher resistance than metal, cross-unders are avoided unless necessary. I see just two cross-unders in the TDA7000.
A cross-under in the TDA7000.
The circuit that caused me the most difficulty is the noise generator below. The transistor highlighted in red below looks straightforward: a resistor is connected to the collector, which is connected to the base. However, the transistor turned out to be completely different: the collector (red arrow) is on the other side of the circuit and this collector is shared with five other transistors. The structure that I thought was the collector is simply the contact at the end of the resistor, connected to the base.
The transistors in the noise generator, with a tricky transistor highlighted.
The TDA7000 almost didn't become a product. It was invented in 1977 by two engineers at the Philips research labs in the Netherlands. Although Philips was an innovative consumer electronics company in the 1970s, the Philips radio group wasn't interested in an FM radio chip. However, a rogue factory manager built a few radios with the chips and sent them to Japanese companies. The Japanese companies loved the chip and ordered a million of them, convincing Philips to sell the chips.
The TDA7000 became a product in 1983—six years after its creation—and reportedly more than 5 billion have now been sold.19 Among other things, the chip allowed an FM radio to be built into a wristwatch, with the headphone serving as an antenna. Since the TDA7000 vastly simplified the construction of a radio, the chip was also popular with electronics hobbyists. Hobbyist magazines provided plans and the chip could be obtained from Radio Shack.20
A wristwatch using the TDA7010T, the Small Outline package version of the TDA7000.
From FM receivers for mono and stereo on a single chip, Philips Technical Review.
A wristwatch using the TDA7010T, the Small Outline package version of the TDA7000. From FM receivers for mono and stereo on a single chip, Philips Technical Review.
Why reverse engineer a chip such as the TDA7000? In this case, I was answering some questions for the IEEE microchips exhibit, but even when reverse engineering isn't particularly useful, I enjoy discovering the logic behind the mysterious patterns on the die. Moreover, the TDA7000 is a nice chip for reverse engineering because it has large features that are easy to follow, but it also has many different circuits. Since the chip has over 100 transistors, you might want to start with a simpler chip, but the TDA7000 is a good exercise if you want to increase your reverse-engineering skills. If you want to check your results, my schematic of the TDA7000 is here; I don't guarantee 100% accuracy :-) In any case, I hope you have enjoyed this look at reverse engineering.
Follow me on Bluesky (@righto.com), Mastodon (@[email protected]), or RSS. (I've given up on Twitter.) Thanks to Daniel Mitchell for asking me about the TDA7000 and providing the die photo; be sure to check out the IEEE Chip Hall of Fame's TDA7000 article.
  1. The first "radio-on-a-chip" was probably the Ferranti ZN414 from 1973, which implemented an AM radio. An AM radio receiver is much simpler than an FM receiver (you really just need a diode), explaining why the AM radio ZN414 was a decade earlier than the FM radio TDA7000. As a 1973 article stated, "There are so few transistors in most AM radios that set manufacturers see little profit in developing new designs around integrated circuits merely to shave already low semiconductor costs." The ZN414 has just three pins and comes in a plastic package resembling a transistor. The ZN414 contains only 10 transistors, compared to about 132 in the TDA7000. ↩
  2. The transistors are isolated by the P+ band that surrounds them. Because this band is tied to ground, it is at a lower voltage than the neighboring N regions. As a result, the PN border between transistor regions acts as a reverse-biased diode PN junction and current can't flow. (For current to flow, the P region must be positive and the N region must be negative.)
    The invention of this isolation technique was a key step in making integrated circuits practical. In earlier integrated circuits, the regions were physically separated and the gaps were filled with non-conductive epoxy. This manufacturing process was both difficult and unreliable. ↩
  3. NPN transistors perform better than PNP transistors due to semiconductor physics. Specifically, current in NPN transistors is primarily carried by electrons, while current in PNP transistors is primarily carried by "holes", the positively-charged absence of an electron. It turns out that electrons travel better in silicon than holes—their "mobility" is higher.
    Moreover, the lateral construction of a PNP transistor results in a worse transistor than the vertical construction of an NPN transistor. Why can't you just swap the P and N domains to make a vertical PNP transistor? The problem is that the doping elements aren't interchangeable: boron is used to create P-type silicon, but it diffuses too rapidly and isn't soluble enough in silicon to make a good vertical PNP transistor. (See page 280 of The Art of Analog Layout for details). Thus, ICs are designed to use NPN transistors instead of PNP transistors as much as possible. ↩
  4. The resistance of a silicon resistor is proportional to its length divided by its width. (This makes sense since increasing the length is like putting resistors in series, while increasing the width is like putting resistors in parallel.) When you divide length by width, the units cancel out, so the resistance of silicon is described with the curious unit ohms per square (Ω/□). (If a resistor is 5 mm long and 1 mm wide, you can think of it as five squares in a chain; the same if it is 5 µm by 1 µm. It has the same resistance in both cases.)
    A few resistances are mentioned on the TDA7000 schematic in the datasheet. By measuring the corresponding resistors on the die, I calculate that the resistance on the die is about 200 ohms per square (Ω/□). ↩
  5. See The Art of Analog Layout page 197 for more information on junction capacitors. ↩
  6. You might wonder about the names "emitter" and "collector"; it seems backward that current flows from the collector to the emitter. The reason is that in an NPN transistor, the emitter emits electrons, they flow to the collector, and the collector collects them. The confusion arises because Benjamin Franklin arbitrarily stated that current flows from positive to negative. Unfortunately this "conventional current" flows in the opposite direction from the actual electrons. On the other hand, a PNP transistor uses holes—the absence of electrons—to transmit current. Positively-charged holes flow from the PNP transistor's emitter to the collector, so the flow of charge carriers matches the "conventional current" and the names "emitter" and "collector" make more sense. ↩
  7. The basic current mirror circuit isn't always accurate enough. The TDA7000's current mirrors improve the accuracy by adding emitter degeneration resistors. Other chips use additional transistors for accuracy; some circuits are here. ↩
  8. The reference voltages are produced with versions of the circuit below, with the output voltage controlled by the resistor values. In more detail, the bottom transistor is wired as a diode, providing a voltage drop of 0.6V. Since the upper transistor acts as an emitter follower, its base "should" be at 1.2V. The resistors form a feedback loop with the base: the current (I) will adjust until the voltage drop across R1 yields a base voltage of 1.2V. The fixed current (I) through the circuit produces a voltage drop across R1 and R2, determining the output voltage. (This circuit isn't a voltage regulator; it assumes that the supply voltage is stable.)
    The voltage reference circuit.
    Note that this circuit will produce a reference voltage between 0.6V and 1.2V. Without the lower transistor, the voltage would be below 0.6V, which is too low for the current sink circuit. A closer examination of the circuit shows that the output voltage depends on the ratio between the resistances, not the absolute resistances. This is beneficial since, as explained earlier, resistors on integrated circuits have inaccurate absolute resistances, but the ratios are much more constant. ↩
  9. Differential pairs are also called long-tailed pairs. According to Analysis and Design of Analog Integrated Circuits, differential pairs are "perhaps the most widely used two-transistor subcircuits in monolithic analog circuits." (p214)
    Note that the transistors in the differential pair act like an emitter follower controlled by the higher input. That is, the emitters will be 0.6 volts below the higher base voltage. This is important since it shuts off the transistor with the lower base. (For example, if you put 2.1 volts in one base and 2.0 volts in the other base, you might expect that the base voltages would turn both transistors on. But the emitters are forced to 1.5 volts (2.1 - 0.6). The base-emitter voltage of the second transistor is now 0.5 volts (2.0 - 1.5), which is not enough to turn the transistor on.) ↩
  10. Filters are very important to the TDA7000 and these filters are implemented by op-amps. If you want details, take a look at the application note, which describes the "second-order low-pass Sallen-Key" filter, first-order high-pass filter, active all-pass filter, and other filters. ↩
  11. Most transistor circuits connect (eventually) to power and ground. One exception is open-collector outputs or other circuits with a pull-up resistor outside the chip. ↩
  12. Nowadays, satellite radio such as SiriusXM provides another competitor to FM radio. SiriusXM uses QPSK (Quadrature Phase-Shift Keying), which encodes a digital signal by encoding pairs of bits using one of four different phase shifts. ↩
  13. FM stereo is broadcast in a clever way that allows it to be backward-compatible with mono FM receivers. Specifically, the mono signal consists of the sum of the left and right channels, so you hear both channels combined. For stereo, the difference between the channels is also transmitted: the left channel minus the right channel. Adding this to the mono signal gives you the desired left channel, while subtracting this from the mono signal gives you the desired right channel. This stereo signal is shifted up in frequency using a somewhat tricky modulation scheme, occupying the audio frequency range from 23 kHz to 53 kHz, while the mono signal occupies the range 0 kHz to 15 kHz. (Note: these channels are combined to make an audio-frequency signal before the frequency modulation.) A mono FM receiver uses a low-pass filter to strip out the stereo signal so you hear the mono channel, while a stereo FM receiver has the circuitry to shift the stereo signal down and then add or subtract it. A later chip, the TDA7021T, supported a stereo signal, although it required a separate stereo decoder chip (TDA7040T)to generate the left and right channels. ↩
  14. A while ago, I wrote about the Rockwell RC4200 analog multiplier chip. It uses a completely different technique from the Gilbert cell, essentially adding logarithms to perform multiplication. ↩
  15. For a detailed explanation of the Gilbert cell, see Gilbert cell mixers. ↩
  16. The TDA7000's correlator determines if the radio is correctly tuned or not. The idea is to multiply the signal by the signal delayed by half a cycle (180º) and inverted. If the signal is valid, the two signals match, giving a uniformly positive product. But if the frequency is off, the delay will be off, the signals won't match, and the product will be lower. Likewise, if the signal is full of noise, the signals won't match.
    If the radio is mistuned, the audio is muted: the correlator provides the mute control signal. Specifically, when tuned properly, you hear the audio output, but when not tuned, the audio is replaced with a white noise signal, providing an indication that the tuning is wrong. The muting is accomplished with a Gilbert cell, but in a slightly unusual way. Instead of using differential inputs, the output audio is fed into one input branch and a white noise signal is fed into the other input branch. The mute control signal is fed into the upper transistors, selecting either the audio or the white noise. You can think of it as multiplying by +1 to get the audio and multiplying by -1 to get the noise. ↩
  17. The circuit to track the frequency is called a Frequency-Locked Loop; it is analogous to a Phase-Locked Loop, except that the phase is not tracked. ↩
  18. Some chips genuinely have transistors with multiple collectors, typically PNP transistors in current mirrors to produce multiple currents. Often these collectors have different sizes to generate different currents. NPN transistors with multiple emitters are used in TTL logic gates, while NPN transistors with multiple collectors are used in Integrated Injection Logic, a short-lived logic family from the 1970s. ↩
  19. The history of the TDA7000 is based on the IEEE Spectrum article Chip Hall of Fame: Philips TDA7000 FM Receiver. Although the article claims that "more than 5 billion TDA7000s and variants have been sold", I'm a bit skeptical since that is more than the world's population at the time. Moreover, this detailed page on the TDA7000 states that the TDA7000 "found its way into a very few commercially made products". ↩
  20. The TDA7000 was sold at stores such as Radio Shack; the listing below is from the 1988 catalog.
    The TDA7000 was listed in the 1988 Radio Shack Catalog.
  21. The TDA7000 is well documented, including the datasheet, application note, a technical review, an article, and Netherlands and US patents.
    The die photo is from IEEE Microchips that Shook the World and the history is from IEEE Chip Hall of Fame: Philips TDA7000 FM Receiver. The Cool386 page on the TDA7000 has collected a large amount of information and is a useful resource.
    The application note has a detailed block diagram, which makes reverse engineering easier:
    Block diagram of the TDA7000 with external components. From the TDA7000 application note 192
    If you're interested in analog chips, I highly recommend the book Designing Analog Chips, written by Hans Camenzind, the inventor of the famous 555 timer. The free PDF is here or get the book.
