Solving a math problem of Schrödinger (Part II)
What's the better way to solve a math problem? A few lines of code, or a bunch of mathematical thought? I wanted to solve the following math problem: how many 12-digit numbers can you make from the digits 1 through 5 if each digit must appear at least once. In Part I, I described how to use Python or Arc to solve this problem. Now, in the eagerly-awaited Part II, I'll describe how to solve it using Exponential Generating Functions. This turned out to involve more mathematics than I expected, although it's mostly just algebra.
The exponential generating function solution
My old combinatorics textbook describes how to solve all sorts of combinatorial problems. Section 3.2.13 has a somewhat similar sequence problem: how many sequences of 1,2, or 3 of length l, in which no symbol occurs exactly p times. This approach can be generalized to the problem we're solving.
For our specific problem, we want to exclude solutions where a digit appears 0 times, but we'll stick with the generalized approach of excluding solutions where a digit appears exactly p times, and then we'll set p to 0 later. We'll let d be the range of each digit (e.g. if the digits are 1 through 5, then d=1). And n will be the total number of digits in the sequence (e.g. n=12 in our original problem).
Generating functions are way too complex to explain here, but I'll try to give a quick overview. The idea is that if you have c things of size n, you represent this by cx^n. For instance, if you roll a die, you can get 1 through 6, so the generating function would be x+x^2+x^3+x^4+x^5+x^6. If you roll a die twice, you would square that. If you want to figure out how many ways to roll a 9, you'd extract the coefficient of x^9 (which is represented as [x^9]). If you multiply out the polynomial, you'll find that the coefficient of x^9 is 4, corresponding to the 4 ways to roll a 9 (6+3, 5+4, 4+5, 3+6).
In these polynomials, x is just a placeholder, not a genuine variable; you never actually evaluate the polynomial. It's almost like magic the way the answer pops out of the formulas.
One source of more information on generating functions is Cut the knot: generating functions.
First, we create the generating function for a single digit, say 1. If the digit appears zero times, we represent it by term x^0. If it appears 1 time, we have x^1. If it appears twice, we have x^2/2!. (We divide by 2! because there are 2! equivalent ways the digit can appear twice.) Likewise, if it appears three times, we represent it by x^3/3!. We end up with x^0 + x^1 + x^2/2! + x^3/3! + x^4/4! + ... Now for the crazy part. This is the series expansion of e^x, so we replace this with e^x. Finally we subtract x^p/p!, which is the "forbidden" case. We end up with the generating function e^x - x^p/p!.
If we have d choices for each digit, we multiply together d copies of the generating function, which is of course raising it to the power of d:
To get our solution, if we want to find how many solutions are n digits long, we simply extract the coefficient of x^n/n! from the above generating function, and that gives us the value we want:
Next step: how do we evaluate the above? First, let's expand the right half using the standard binomial formula:
Now we'll take a quick detour through some generating function facts, which I will present without proof.
Important generating function facts
Extracting the coefficient of x^n in an exponential gives you:
Unless n=0. Then you're looking for the coefficient of x^n in 1. This is simply 1 if n=0, and 0 otherwise.
Or unless n<0. Then the result is 0.
Second important generating function fact: if you're looking for the coefficient of, say, x^9 in an expression multiplied by x^3, then you can look instead for the coefficient of x^6 in the expression, if you use the appropriate scaling:
Solving one term of the summation
Now let's extract our desired coefficient from one term of the summation.
If n<kp, then the coefficient is 0.
If d != k, then from the second important fact, the value is:
If k = d, then the exponential drops out and the value is 0 if n != kp (i.e. n != dp), and otherwise:
Putting the summation together
Let's first assume n != dp. Then we can skip the k=d term, and we get:
where limit = min(d-1, n/p) (or d-1 if p=0). This ensures that n-kp >=0.
On the other hand, if n = dp, then we need to handle the k=d term.
Note that if n=dp, then n-kp>0, so we don't need to add an extra upper limit on k.
Solving the original problem
In the original problem, no value is allowed to appear zero times, so the forbidden count p=0. Then the solution simplifies to
Thus, the number of sequences of length 12 consisting of the digits 1 through 5, with each digit appearing at least once, is given by n=12 and d=5:
Happily, this is the same result we got in Part I.
Implementing this in Python
Implementing the above formula is straightforward:
from math import factorial
def solve(d, n, p):
  total = 0
  for k in range(0, d):
    if n-k*p < 0: break
    total += (pow(-1, k) * choose(d, k) *
              factorial(n) / factorial(n-k*p) *
              pow(d-k, n-k*p) / pow(factorial(p), k))
  if n == d*p:
    total += pow(-1, d) * factorial(n) / pow(factorial(p), d)
  return total
Since I didn't entirely trust the mathematics above, I also implemented a totally brute-force solution that generates and tests all the sequences of the given length:
import itertools
def bruteforce(d, n, p):
  total = 0
  for seq in itertools.product(range(0, d), repeat=n):
    ok = 1
    for i in range(0, d):
      if len([x for x in seq if x==i]) == p:
        ok = 0
        break
    total += ok
  return total
The mathematical solution and the brute force solution agree on the cases I tested, which increased my confidence that I didn't mess up the math. The brute force solution is, of course, too slow to use except for fairly small values.
The mathematical solution involved more mathematics than I was expecting. The resulting solution isn't quite as clean as I'd hoped, due to various corner cases that need to be handled. But it can be implemented fairly easily, and also lets us solve a more general problem than the original problem.
