A look inside the chips that powered the landmark Polaroid SX-70 instant camera
The revolutionary Polaroid SX-701 camera (1972) was a marvel of engineering: the world's first instant SLR camera. This iconic camera was the brainchild of Dr. Edwin Land, a genius who co-founded Polaroid, invented polarized sunglasses, helped design the optics for the U-2 spy plane, and created a theory of color vision. The camera used self-developing film2 with square photos that came into view over a few minutes.3 The film was a complex sandwich of 11 layers of chemicals to develop a negative image and then form the visible color image. But the film was just one of the camera's innovations.
Edwin Land and the Polaroid SX-70 camera were featured on the cover of Life magazine, October 27, 1972.
The camera required complex new optics to support the intricate light path shown below. The components included a flat Fresnel mirror, aspherical lenses, and a moving mirror. These optics could focus from infinity down to a closeup of 10 inches. The optics are even more amazing when you consider that the camera folded flat, 3 cm thick and able to fit in a jacket pocket.
Diagram from Life magazine, Oct 1972, showing the light path through the camera.
But I'm going to focus on the camera's electronics, powered by a custom flat battery pack. When the shutter button is pressed, the camera carried out several tasks with precision timing. First, a solenoid closes the shutter, blocking the entry of light into the camera. Next, the motor is turned on, causing the camera's internal mirror to flip up to uncover the film. The solenoid is then de-energized, causing the shutter to open. The film exposure time depends on the light level; at the appropriate time, the solenoid closes the shutter again to stop exposure. Finally, the motor runs again to eject the film and reset the mirror.
I'm helping the openSX70 project by reverse-engineering the chips on the exposure control board. This board contains three surface-mount ICs: a chip to read the light intensity from a photodiode, a timer chip to control how long the shutter blades are open, and a power control IC to drive the motor and solenoids.4
The exposure control circuit board, manufactured by Texas Instruments. Photo from openSX70.
The development of this board was contentious, with Fairchild and Texas Instruments battling to supply the electronics for millions of cameras.5 The exposure control board went through three designs as Fairchild and Texas Instruments struggled to meet Polaroid's price target of just $5.75. First, Texas Instruments built a control board from a ceramic substrate with laser-trimmed resistors. The expensive components put the board way over budget at $100 so Polaroid used these boards only in prototype cameras. Fairchild's design was accepted by Polaroid even though its cost of $20 still exceeded the target. Fairchild's board was used from 1972 to 1973, but Texas Instruments fought back with an all-new design that cost only $4.10. This TI board was the long-term winner, and is the one I am examining in this post.
The optical chip
The exposure control board automatically adjusts the exposure time based on the amount of ambient light. Ambient light is measured by the optical chip, a package that combines a photodiode and a silicon die in one small package. The silicon die is protected by epoxy, but the larger photodiode is exposed so external light can fall on it.
The optical chip contains a photodiode and a silicon die in one package.
To measure the ambient light, the chip implements the integrator circuit below. The photodiode generates a small current that depends on the light level. This current is integrated over time using a capacitor until a threshold is reached. By opening the shutter during this interval, the film is exposed for the desired amount of time. (The film's exposure depends on the total amount of light received, which is the same value that the integration calculates.) The op-amp die outputs the voltage across the capacitor without draining the capacitor in the process.
The optical chip is essentially an integrator.
The photo below shows the silicon die under a microscope. The chip, made by Texas Instruments, is dominated by the zig-zags forming two interlocking JFET transistors. A JFET is a special type of transistor, used before MOSFETs became popular. These transistors have very low input currents, so they won't drain the capacitor as it charges. The interlocking layout ensures that both transistors are at the same temperature, so the circuit will stay accurate even if the chip heats up unevenly. The chip also contains NPN and PNP transistors, resistors, and a capacitor (the large pink square labeled 28710).
The optical chip. Photo from siliconPr0n, (CC BY 4.0).
By reverse-engineering the die, I created the schematic below. It is an op-amp, measuring the difference between two inputs (one tied to ground). The two JFET (Q12/Q13) transistors are configured as a standard differential pair circuit. A fixed current (from the current mirror Q8/Q6) is fed into the transistors, and whichever transistor has the higher input will pass almost all the current. The result is amplified by Q5 for the output. In addition to the op-amp circuitry, the chip contains a reset circuit to discharge the capacitor before use (Q1/Q2). (The internal capacitor C1 stabilizes the op-amp; the integration capacitor is external.)
Schematic of the optical chip. Click for a larger version.
The power driver chip
Next, the power chip drives solenoids and the motor to activate the camera's mechanisms. The high-current power transistors (the golden triangular shapes) take up most of this chip. Smaller transistors below form the control circuitry.
The power driver chip. Photo from siliconPr0n, (CC BY 4.0).
My reverse-engineered schematic shows that the chip has three parts. First, a simple inverter. This probably interfaces the logic chip to the motor control board.
Schematic of the inverter in the power driver chip. Click for a larger version.
Second, a high-current driver. This uses the large power transistor at the left of the die. This probably drives a solenoid.
Schematic of the driver in the power driver chip.
Finally, a high-current driver with a separate circuit for the solenoid hold current. (That is, the solenoid is pulled into position with a high current, and then held in that position with a lower current.) This uses the large power transistors at the right of the die. There's a single large transistor underneath the main "triangle" of transistors; that transistor is for the hold current. This circuit uses separate power and ground pads from the rest of the chip.
Schematic of the driver/hold circuit in the power driver chip.
The driver circuits are more complex than I'd expect, using current sources and current mirrors. Maybe this design minimizes standby current use.
The logic chip
The camera is controlled by a complex logic chip that controlled the timing of the various mechanisms, running the motor and solenoids. It had to handle four different use cases: ejecting the protective cover sheet when a film package was inserted, taking a photo, taking a photo with the flash, and ejecting an empty film package.
This chip was constructed from Integrated Injection Logic (I2L), an obscure 1970s logic family featuring high density and low power. Because the camera ran off a battery in the film pack, minimizing power consumption was a critical factor. At the time, I2L was a good choice for dense, low-power circuitry, although it was soon overtaken by CMOS. Texas Instruments did a lot of development with I2L, including digital watch chips and the 76477 sound chip so it's not surprising that they chose I2L for the camera chip.
The logic chip. Photo from siliconPr0n, (CC BY 4.0).
I2L gates can be packed together at high density, as shown below. Each vertical gray rectangle is two transistors (one above the horizontal centerline and one below), corresponding to two gates. The chip has very little wasted space, especially compared to TTL logic, which was commonly used at the time but required multiple transistors and bulky resistors for each gate.
Closeup of the logic chip.
I2L is a bit tricky to understand since an I2L gate has one input and multiple outputs. How can that work? The schematic below shows an I2L gate, with one input and three outputs. Normally the current from the injector (ICC) turns on the output transistor, pulling the output low. But if the input is low, the output transistor turns off and the output will be high. Thus, the gate inverts the input. (You can think of the injector as a pull-up resistor on the input.)
Implementation of an I2L gate. Note that it has a single input and multiple outputs. Icc is the injected current. From "Integrated Injection Logic: A Bipolar LSI Technique".
Since the circuit above has a single input, it may seem to be just an inverter. But by wiring several signals together at the input, you get an AND gate "for free": if any signal is low, it will pull the wire low, and otherwise the signal is high. This is called "wired-AND". The wired-AND input to the I2L inverter results in a NAND gate.
One problem arises with wired-AND: if you connect an output to more than one wired-AND, everything gets shorted together. The solution is to have multiple outputs from the inverter. Thus, each I2L NAND gate has a single input and multiple identical outputs. In the diagram below, the outputs from various gates (A and B below) are connected together and fed to the input of an I2L gate, creating a NAND gate.
Diagram of a NAND gate implemented in Integrated Injection Logic (I2L). From "Integrated Injection Logic: A Bipolar LSI Technique".
The transistors in I2L have multiple collectors, which may seem strange, but the diagram below shows how they are constructed. Each collector has an N region (purple) with a P region (tan) below for the base, and another N region (green) at the bottom, forming an NPN transistor. The multiple collectors are built by creating multiple N regions. Physically, the injector PNP transistor is just a P region for the emitter, reusing the emitter and base's N and P regions; this makes the injector more compact than a "full" transistor.
Die photo and cross-section diagram of an I2L gate. The transistor base, collectors, and emitters are labeled along with the current injection.
I haven't reverse-engineered this chip yet. I believe that it contains an oscillator and a chain of flip flops for timing, as well as a comparator for the light level and some miscellaneous control logic.
While the electronics of the SX-70 camera aren't impressive by modern standards, they were cutting edge at the time. They made the SX-70 easy to operate by handling the exposure and timing automatically. Texas Instruments split the electronics across three chips: a precision JFET op-amp with a photodiode, a high-current power driver chip, and a complex logic chip using dense, low-power I2L logic.
Unfortunately, innovative technology wasn't enough for Polaroid. The company declined after competition from Kodak, the expensive failure of the Polavision instant home movie system, and the rise of digital cameras. Polaroid declared bankruptcy in 2001 and the company was broken up. The SX-70 has seen a resurgence in popularity, with film and cameras sold by polaroid.com, which acquired the Polaroid name in 2017.
Follow me on Twitter @kenshirriff for more posts. I also have an RSS feed. Thanks to JoaquĆ­n De Prada and Peter Kooiman of openSX70 for providing the chips and John McMaster for decapping them.
The openSX70 project is building extensions to the SX-70 camera.
For more about the SX-70, see the interesting and quirky 10-minute movie below, which markets the SX-70, explains how to use it, and discusses the internal operation. This movie was made in 1972 by the famous designers Ray and Charles Eames.
  1. The name SX-70 comes from its inventor Dr. Edwin Land. He numbered all his "special experiments" in a notebook and his instant picture experiment was number 70. Although the camera was 30 years after special experiment 70, he felt that it embodied the system he had envisioned in the mid-1940s. ↩
  2. Land introduced instant photography in 1947, and then color instant film in 1963, based on a peel-apart technology. The SX-70 eliminated the problems of the peel-apart instant photos. As Polaroid said, “No pulling the picture packet out of the camera, no timing the development process, no peeling apart of the negative and positive results, no waste material to dispose of, no coating of the print, no print mount to attach, no chance for double exposure, no chance to forget to remove the film cover sheet and spoil a picture, no exposure settings to make, no flash settings to remember, no batteries to replace.”  ↩
  3. Although Polaroid photos develop in a minute or so without any user intervention, shaking the photo was a common custom. "Shaking the Polaroid" was the theme of a 1998 Polaroid ad. Outkast's 2003 song Hey Ya! featured the refrain "Shake it like a Polaroid picture". ↩
  4. I haven't investigated all the chips in the SX-70. The motor control module contains a linear control IC and power transistors. The camera also takes a flashbar with five flashbulbs. The flash circuit has another chip that checks the bulbs to find an unused bulb. ↩
  5. "The Battle for the SX-70 Camera", IEEE Spectrum, May 1989 discusses in detail the battle between Fairchild and Texas Instruments to win the Polaroid contract.
    The internal circuitry of the camera is described in "Behind the Lens of the SX-70", IEEE Spectrum, Dec 1973. This circuitry, however, is for the earlier Fairchild version and the implementation is considerably different from the Texas Instruments circuitry that I examined. The Fairchild implementation is also described in "Camera Electronics, A New Approach", WESCON 1973. ↩
Yamaha DX7 chip reverse-engineering, part 6: the control registers
The Yamaha DX7 digital synthesizer (1983) was the classic synthesizer in 1980s pop music. It uses a technique called FM synthesis to produce complex, harmonically-rich sounds. In this blog post, I look inside its custom "OPS" sound chip and explain the control registers for this chip. By reverse-engineering the circuitry, I found a few undocumented test functions. (This post covers some fairly obscure details of the DX7; you might prefer my previous DX7 posts1 starting with "DX7 reverse-engineering".)
Die photo of the YM21280 chip with the main functional blocks labeled. Click this photo (or any other) for a larger version.
The die photo above shows the DX7's OPS sound synthesis chip under the microscope, showing its complex silicon circuitry. Unlike modern chips, this chip has just one layer of metal, visible as the whitish lines on top. Around the edges, you can see the 64 bond wires attached to pads; these connect the silicon die to the chip's 64 pins. In this blog post, I'm focusing on the control registers, highlighted in red. I'll outline the other functional blocks briefly. Each of the 96 oscillators has a phase accumulator used to generate the frequency. The sine and exponential functions are implemented with lookup tables in ROMs. Other functional blocks apply the envelope, hold configuration data, and buffer the output values.
The DX7 synthesizer. Photo by rockheim (CC BY-NC-SA 2.0).
The DX7 generates sounds digitally using a technique called FM synthesis. Each note has six oscillators (called "operators") that can be combined in different ways (called "algorithms"). An algorithm is represented by a diagram (below), where an oscillator modulates the oscillator below, as shown by the lines. For instance, in algorithm 1 below, oscillator 6 modulates oscillator 5 which modulates 4 which modulates 3. Oscillator 2 modulates oscillator 1. The output is taken from the bottom oscillators (1 and 3). Meanwhile, oscillator 6 modulates itself, controlled by a user-selectable feedback level. With 32 different algorithms, the DX7 can generate a wide variety of sounds. In the DX7 synthesizer, all 16 notes must use the same algorithm. But from my reverse-engineering, it appears that the chip supports different algorithms for each note, even though the synthesizer doesn't make use of this.
Four of the 32 "algorithms" that can be selected on the DX7.
To the programmer of the DX7 firmware, the sound chip appears to have two write-only registers that control the chip. The diagram below shows the layout of the chip's s two registers, as described by Anthony Richardson. The desired algorithm and feedback are written to address 1.2 Address 0 has bits to turn the "key sync" feature3 on and off. As for the Mute and Test Register Select bits, my investigation provides some explanation.
Address | Bit 7 | Bit 6          | Bit 5        | Bit 4 | Bit 3 | Bit 2 | Bit 1 | Bit 0 |
0       | Mute  | Clear Key Sync | Set Key Sync | Test Register Select                  |
1       | Algorithm Select (0..31)                              | Feedback Level (0..7) |
(The functionality above is pretty limited, so you might wonder how the synthesizer controls which notes are played. Most of the synthesizer functions are controlled through a second custom chip, the envelope generator chip (EGS). Note and envelope data is written to registers in the EGS chip, which then sends frequency and amplitude data to the sound chip over a special bus.)
The diagram below shows the main components of the register circuitry. The large block at the bottom is the A-register, which holds the algorithm/feedback entries, as 16 8-bit values.4 The most puzzling feature of the A-register is its size; it holds 16 entries, one for each note, but the DX7 uses the same algorithm/feedback setting for all 16 notes. The second puzzling feature is that although the chip appears to have two 8-bit registers, the implementation is one 9-bit register, and one 5-bit register. Moreover, the 5-bit register can only be modified by writing through the 9-bit register.
Main functional blocks of the register circuitry.
The chip has one address pin (called "DS") which selects between the two registers. When a byte is written to the chip, to either address, the 8 bits along with DS (the address bit) are stored in the 9-bit latches. If DS is 0 (i.e. write to the control address 0), the bits are decoded to perform any special functions, and the lower 5 bits are loaded into the 5-bit register on the right. If DS is 1 (i.e. write to the algorithm/feedback address 1), the 8-bit algorithm/feedback value is stored into the A register, in a location controlled by the 5-bit register.
Updating the algorithm/feedback
The algorithm/feedback A-register register holds data for 16 notes. It can be updated in two ways. The first way, used by the DX7, updates all entries with the same value. The second way updates a single entry, allowing different notes to have different algorithms. Both cases involve a write to address 0, followed by writing the algorithm/feedback byte to address 1.
To update all entries, address 0 must be written with a value with the bit pattern 0??1?0?? (where ? indicates a "don't care" bit that can be 0 or 1).5 This pattern triggers a circuit that constantly loads the value in the data latch into the storage register.
The DX7's CPU controls the OPS chip in this way. Specifically, an update of the algorithm and feedback is performed by writing either 0x30 (if sync is on) or 0x50 (if sync is off) to address 0, and then writing the algorithm/feedback byte to address 1.2
The second update path will change the algorithm and feedback for a single note. (The DX7 does not use this feature.) is triggered by writing the bit pattern 0??0nnnn, where nnnn specifies one of the 16 notes.
The implementation of this is a bit tricky because the chip uses shift registers for storage, not RAM. The A-register consists of 8 shift registers (one for each bit), each with 16 stages (one for each note). An entry can only be updated when it is shifted out the end of the shift register, and a new value can be inserted. (This is unlike RAM, where an arbitrary entry can be written.) To update an entry in the shift register, a 4-bit comparator circuit (below) compares the number of the current note with the number of the desired note in the control register. When there is a match, the new value is written to the shift register.
The 4-bit comparator determines when the shift register is at the desired note position. It is built from four exclusive-NOR gates.
Special command sequences
The logic circuitry recognizes several bit patterns when they are written to address 0, and causes special actions when they are detected. These are not used by the DX7; I think they were used for testing the chip during manufacturing to make tests more predictable and faster.
1???????: Setting the top bit triggers several special actions. Earlier analysis has labeled this bit as "Mute", but I suspect it is more of a "Test Reset" function, resetting the chip to a known state so tests will be predictable. This bit clears the phase accumulators. This bit disables the scale factors, so the output data is unshifted. It also bypasses the output latch, which may output digital note data at a higher rate.
1??????1: In addition to the previous action, this pattern resets the counters that count through the operators and notes, controlling the actions of the chip. This is probably used start testing the chip from a known state, so the outputs can be compared with expected values.
1?????1?: This causes the low-order bits of the phase register to generate the waveform, rather than the high-order bits. I think this is used for testing so the low-order bits can be examined more directly to find flaws. It also will increase the frequencies by a factor of 1024, which may help run through waveforms faster for testing.
By looking inside the chip and reverse-engineering the silicon circuits, I learned some details about the internal registers. One interesting discovery is that the chip appears to support separate algorithms for each voice, even though the synthesizer doesn't use this feature. I also uncovered some test functionality.
The Yamaha YM21280 OPS integrated circuit package with the metal lid removed, revealing the silicon die.
I plan to continue investigating the DX7's circuitry, so follow me on Twitter @kenshirriff for updates. I also have an RSS feed. Thanks to Jacques Mattheij and Anthony Richardson for providing the chip and discussion.6
Disclaimer: I figured out the behavior described in this post studying the die. It hasn't been tested on an actual DX7 so I don't guarantee that it is correct.
  1. My previous posts on the DX7: DX7 reverse-engineering, The exponential ROM, The log-sine ROM, How algorithms are implemented, and The output circuitry. ↩
  2. Looking at the ROM shows how the synthesizer's CPU communicates with the OPS chip. Since the DX7 ROM code has been disassembled, you can view the code that writes to the sound chip here. ↩↩
  3. Oscillator Key Sync is a feature of the DX7. According to the manual, Operator Key Sync "enables you to set the operator so its 'oscillator' begins at the start of the sine wave cycle each time you play a note. When Oscillator Key Sync is off, the sine wave continues so that subtle differences will occur even when you play the note repeatedly." ↩
  4. The DX7/9 Service Manual shows the "A-register" holding the algorithm and feedback level, so I'll use that name. ↩
  5. The bit pattern 0??1?0?? looks a bit random. I don't know why this pattern was chosen. The first two bits can be explained, but I don't see a purpose for the last 0 bit. ↩
  6. For more information on the DX7 internals, see DX7 Technical Analysis, DX7 Hardware, OPLx decapsulated, and the video Emulating the DX7 the hard way. ↩
Yamaha DX7 chip reverse-engineering, part V: the output circuitry
The Yamaha DX7 digital synthesizer (1983) was the classic synthesizer in 1980s pop music. It uses a technique called FM synthesis to produce complex, harmonically-rich sounds. In this blog post, I look inside its custom sound chip and explain how the chip's output circuitry works. You might expect it's just a digital output fed into a digital-to-analog converter, but there's much more to it than just that.
The composite die photo above shows the DX7's OPS sound synthesis chip under the microscope, revealing its complex silicon circuitry. Unlike modern chips, this chip has just one layer of metal, visible as the whitish lines on top. Around the edges are the 64 bond wires attached to pads; these connect the silicon die to the chip's 64 pins. The three blocks in red are the focus of this post. The output buffers hold the 16-bit digital values for the 16 notes. The output is controlled by a counter and PLA (Programmable Logic Array). The synthesizer's digital-to-analog conversion uses a sample-and-hold circuit, controlled by the "S/H ctrl" block.
I've discussed the chip's other functional blocks in earlier posts1, so I'll just give a brief summary here. Each of the 96 oscillators has a phase accumulator used to generate the frequency. The oscillators are combined using the operator computation circuitry in the middle of the chip, under the control of the algorithm ROM. The signal synthesis uses sine and exponential functions, implemented with lookup tables in ROMs.
The Yamaha DX7 synthesizer with its 61-key keyboard and digital controls. Photo by rockheim (CC BY-NC-SA 2.0).
The synthesizer's output circuitry
Before I dive into the details of the chip, I'll explain the synthesizer's output circuit. The heart of the synthesizer is the OPS (Operator S) sound chip that digitally generates the notes. It provides digital values to the digital-to-analog converter (D/A). The resulting analog signal goes through a low-pass filter (LPF). The volume is controlled by a foot pedal and the synthesizer's volume control. Finally, the signal is amplified for the line and headphone outputs.
Block diagram of the output circuit. Based on the DX7/9 Service Manual.
The digital-to-analog conversion is more complex than you might expect. The process starts with the digital-to-analog converter (DAC) chip2 that takes a 12-bit digital value from the sound chip and converts it to an analog value in the range 0 to 15 volts.3 The multiplexer allows the overall synthesizer volume to be controlled by MIDI, but with just 8 levels.
Schematic of the volume control and DAC circuit. Based on the DX7 schematics.
The DAC provides 12 bits of resolution, but an additional circuit (below) provides approximately two more bits. This scaler circuit divides the analog signal by 1, 2, 4, or 8, using a resistor network and IC switch. The scaler is controlled by the sound chip through the scale factor signals SF0-SF3. The scaler adds more dynamic range to the digital value; the result is similar to a floating-point value with a sign bit, 11-bit mantissa, and two-bit exponent.4
The scaler divides the voltage by 1, 2, 4, or 8. Based on the DX7 schematics.
Next, the signal goes to a sample-and-hold circuit that samples the analog voltage at a point in time and holds it in a capacitor, kind of like an analog memory. An op-amp buffers the capacitor's voltage so it can be "read" without draining the capacitor. There are two hold circuits, used in alternation, so the last two samples are stored and summed to form the circuit's output.5 The SH1 and SH2 control signals load the analog value into a capacitor, using IC52 as a switch. Finally, the output from the sample-and-hold circuit is filtered,6 the volume is adjusted,7 and the signal is amplified for the output (circuitry not shown).
The sample-and-hold circuit. IC52 looks complicated because it uses pairs of switches in parallel. Based on the DX7 schematics.
To summarize, the sound chip interacts with the output circuitry in three ways. The 12-bit digital value (DA1-DA12) is most important as it specifies the output value for each voice. The scale factor signals (SF0-SF3) are also a key contributor to the signal. The sound chip also provides the sample-and-hold control signals (SH1 and SH2).
Time-division multiplexing
The DX7 has 16 voices, so it can play 16 notes at once. Each note is produced by an "algorithm" that combines 6 oscillators in a particular way, so there are 96 oscillators in total. An oscillator can modulate the frequency of another oscillator to generate complex sounds with FM synthesis.
The chip performs all its processing sequentially, one oscillator at a time, rather than computing the notes in parallel. Internally, the chip has one "operator" calculation circuit to combine oscillators. As shown below, the chip starts by processing operator 6 for note 1, then operator 6 for note 2, and so forth through note 16. Then it processes operator 5 for notes 1 through 16. Finally it processes operator 1 for notes 1 through 16, generating the output sound values. It takes a bit over 20 µs to compute all 16 notes in a complete processing cycle.
Timing diagram of sound production. This time interval corresponds to 49.096 kHz. From the DX7/9 Service Manual.
You might expect the chip to combine the 16 notes into a single digital output. However, the sound chip outputs the 16 notes sequentially, using a technique called time-division multiplexing. Each time interval (~20µs) is divided into 16 intervals and one note is output from the chip per interval. (Note that these intervals don't line up with the intervals in the diagram above.) Thus, digital values are output at 786 kilohertz, 16 times the underlying frequency, and the DAC chip converts them to analog at this rate.
As an example, consider two notes that are sine waves with different frequencies. The digital output would look like the image below. You might think that this signal is unusable since it jumps around wildly from point to point.
Output data with two multiplexed sine waves. (Theoretical, not actual DX7 data.)
However, applying a low-pass filter smooths out the waveform (essentially summing nearby points). The result is the waveform below, which shows the sum of the two sine waves.8 The point is that time-division multiplexing data may look strange, but the analog circuitry's filtering creates a "normal" waveform.
Output data after filtering with a 16 kHz low-pass filter.
Output buffer
Inside the chip, the output buffer stores values for the 16 notes as they are generated, and outputs them in sequence. Rather than RAM, the chip uses shift registers for storage. The shift registers are arranged in a loop of 16 stages, one stage for each note. On each clock cycle, the values in the shift register move to the next stage. The output value is fed back into the shift register's input so the value is retained. Alternatively, a new value can be stored in the shift register. Shift registers provided an efficient way to store data, but they cannot be accessed arbitrarily; instead, data must be processed as it becomes available.
The schematic below shows how one stage of the shift register is implemented. The chip uses a two-phase clock. In the first phase, clock ϕ1 goes high, turning on the first transistor. The input signal goes through the inverter, through the transistor, and the voltage is stored in the capacitor (kind of like DRAM). In the second phase, clock ϕ2 goes high, turning on the second transistor. The value stored in the capacitor goes through the second inverter, through the second transistor, and to the output, where it enters the next shift register stage.
Schematic of one stage of the shift register.
The die photo below shows the output buffer, with the 16 shift-register loops arranged in columns. These hold the 16-bit sound values (four scale factor bits and 16 data bits.) Each shift register is 16 stages long to hold the 16 notes. In the next sections, I'll discuss the bit shifters, the logic, and the output latches.
Closeup of the die, showing the output buffer circuitry.
The scale factor: pseudo floating point
The DX7 uses a 12-bit digital-to-analog converter chip, but the scaling circuit (discussed earlier) will scale the voltage by 1, 2, 4, or 8, which adds more resolution. This isn't quite equivalent to 14-bit resolution; it's more like a floating-point number with a sign, 11-bit mantissa, and 2-bit exponent. This provides more resolution for low signals and reduces signal noise.
Inside the chip, scaling is implemented with a shifter that shifts the data bits by 0 to 3 bit positions. (This is unrelated to the shift registers that hold data.) The shifter (below) is implemented as eleven chevron-shaped logic gates; each gate selects one of four potential bits for each mantissa position.
A data sample is shifted 0 to 4 bits by this shifter circuit.
The operator circuitry generates data as 15 bits (2's complement, so one of the bits provides the sign). The output from the chip is 12 bits, so three bits must be discarded. Normally these are the low-order bits, but by using the shifter, high-order zero bits can be discarded instead, and the external scaler counteracts this. The result is more bits of precision in the output.
The shifter is controlled by the logic circuitry to the left of the buffer, which controls the amount of shift based on the number of leading zeros. (For a negative number, leading 1's.) With 5 leading zeros, the number is shifted left by 3 positions. With 4 leading zeros, the number is shifted by 2 positions. With 3 leading zeros, the number is shifted by 1 position. With 2 or fewer leading zeros, the number is unshifted.
Note that the circuit leaves two leading zeros when it shifts, so it's "wasting" two potential bits of precision. I assume this is because the scaler won't be perfectly linear (due to the resistor imperfections9), so you want to avoid switching scale levels for large signals (which don't really need the extra bits).10
The output latches
As mentioned earlier, the 16 notes are output individually, spaced across the interval. This timing doesn't line up with the timing of the output buffer, which shifts to a new note every clock cycle. To fix the timing, two 16-bit latches sit between the output buffer and the output pins. While one latch outputs the current note, the other latch grabs the next note as it is shifted out of the shift register. At the appropriate time, the latches swap roles; the second latch outputs the note while the first latch waits for the next note.
The timing for the latches is fairly tricky to make sure the note data is loaded into the right latch at the right time. These latches are controlled by the chip's master counter, which is the subject of the next section.
To summarize, the sound chip runs at 4.7 MHz. Data values are produced at this rate (but intermittently) and stored into the output buffer. The output latches provide data values to the DAC chip at 786 kHz for an overall audio rate of 49096 Hertz.
Keeping track of 96 clock cycles: the chip's counter and timing PLA
One complete cycle of the sound chip takes 96 clock cycles: processing all 16 notes through the 6 operators that form an algorithm. Because data can only be accessed when it exits a shift register, everything must be timed so the right data is available at the right time. A critical part of the chip is the counter that keeps track of the current note number and operator number to keep everything synchronized.
On the right of the die photo below is the counter, consisting of seven toggle flip flops: four to count the note number (0-15) and three to count the algorithm number (0-5). On the left is the PLA that defines what happens for particular time slices. (A Programmable Logic Array (PLA) is similar to a ROM, but implements arbitrary logic.) The PLA has 39 columns, each one implementing an AND gate triggered by a particular counter output, corresponding to a particular operator and note. Below the PLA is some logic; mostly buffers with a few gates.
The chip's main counter, along with the control PLA.
Of the PLA's 39 columns, the 32 columns on the left control the data output latches,11 two columns control loading data values into the output buffer, one generates the chip's sync output signal, three reset the operator count, and the last increments the operator count.12
Sample-and-hold
The chip outputs two signals to control the sample-and-hold circuitry, SH1 and SH2. These signals are activated in alternation to take an analog sample of each digital output.
The sound chip on the DX7 schematic has three missing pins, indicated in red.
The sound chip has three unused pins next to the SH1 and SH2 pins; the DX7 schematic doesn't show pins 6-8. I traced the chip's internal circuitry and found that these pins, in conjunction with the sample-and-hold pins, count out the 16 samples. It appears that the chip is designed to sample-and-hold all 16 notes individually, so the synthesizer could have had separate outputs for all 16 notes.13
Moreover, the chip has data buffers to hold separate algorithm algorithms for the 16 notes. This would let the chip drive 16 independent voices, each with a separate algorithm. My conclusion is that the sound chip supports much more flexibility than is used in the DX7 synthesizer.
The DX7 generates sounds digitally and then converts the digital values to the analog output. This process turns out to be more complicated than one would expect, with circuitry inside the chip interacting with synthesizer circuitry to scale and adjust the signal. My hope is that my analysis of this process will help DX7 emulators to achieve more accuracy. Looking at the chip's internal circuitry reveals the floating-point format of the output data as well as the function of the three unused pins.
I plan to continue investigating the DX7's circuitry, so follow me on Twitter @kenshirriff for updates. I also have an RSS feed. Thanks to Jacques Mattheij and Anthony Richardson for providing the chip and discussion.14
  1. My previous posts on the DX7: DX7 reverse-engineering, The exponential ROM, The log-sine ROM, and How algorithms are implemented. ↩
  2. The DAC chip is the BA9221, a 12-bit D/A converter that produces an output current based on a 2's-complement input value. A datasheet is here. The DAC receives an input voltage reference. This voltage reference can be one of 8 values selected by a multiplexer. This allows the overall volume to be set via MIDI, but only with 3-bit resolution (see the DX7 ROM code here). The volume is an exponential function (so linear in decibels) except that 0 is off. Also see this DAC discussion and this StackExchange discussion.) ↩
  3. The output from the DAC is centered around 7.5 volts. In other words. a digital value 0 corresponds to 7.5 volts, with positive digital value above 7.5 volts and negative digital values below 7.5 volts. I would have expected the signals to be centered around 0 volts, which is what the DAC datasheet shows. I think strictly positive voltages were used because they work better with the TC4066 and TC4066 integrated circuits switches (IC 41 for scaling and IC 52 for sample-and-hold respectively). The DX7 converts the signals to zero-centered voltages for the low-pass filter. ↩
  4. The amplitude scaler is built from an R-2R resistor ladder, similar to a DAC circuit. However, the attenuator only has 4 useful values, not the 16 levels you might expect with four control lines, because only one control line can be activated at a time. Combinations of control lines do not yield useful outputs. For example, if the top switch is on, you get the maximum output regardless of the other switches. Other switch combinations are non-monotonic. Thus, the scaler only provides two additional bits of resolution, not four. ↩
  5. The benefit of keeping two samples is not clear to me. One theory is that this reduces intermodulation distortion between the voices, the effect of one signal on another. With one "solid" sample and one changing sample, the effect of the changing sample will be reduced. Another, more speculative, possibility is that the circuitry was originally designed for stereo, holding one sample for each channel. ↩
  6. The filter is a sharp low-pass filter around 16 kHz using a Sallen-Key topology. ↩
  7. The volume is controlled by an external volume pedal and a volume control on the synthesizer. The signal also passes through a relay, which cuts the output when the synthesizer is being reset (presumably to avoid random noise).
    The external volume pedal has an interesting circuit. The pedal is essentially a variable resistor, so you might expect the output signal to pass through it. Instead, the pedal is connected to a photocoupler with an LED and a cadmium sulfide photocell inside. The output signal passes through the photocell and is attenuated as controlled by the LED. I think the motivation behind using a cadmium sulfide photocell instead of a phototransistor is that the photocell is completely resistive, so there is no nonlinear distortion of the signal. ↩
  8. Time-division multiplexing and filtering isn't perfect, and will contribute some artifacts to the output. In particular, there will be some aliasing, where high frequencies turn into lower frequencies. The low-pass filter will eliminate most of the high frequencies—I believe the DX7's filter is at 16 kHz—but it's not perfect and will add its own color to the sound. Two notes could also interact differently based on their relative positions in the time slice. These artifacts probably contribute to the DX7's characteristic sound. You could consider the artifacts desirable if you're trying to duplicate the DX7 sound. ↩
  9. The scale resistors are marked on the schematic with Ⓑ, which probably indicates they are higher-precision resistors. Assuming they are 1% resistors, a 1% error in a large signal would be much more error than the benefit of additional bits of precision. For smaller signals, the additional bits reduce the quantization noise, which is probably more important than the nonlinearity error from scaling. ↩
  10. There's an interesting timing issue for the scale calculation. The scaling logic requires about 3 clock cycles to determine the scale factor, so the straightforward implementation would shift a voice based on the amplitude of an earlier voice. The solution is that the 5 bits for scale calculation are pulled out of the operator shift register six stages (3 clock cycles) earlier. Thus, these shift registers have two output; the "early" output gives the scale factor circuitry time to work. ↩
  11. The output buffer has two latches, used by alternating notes. Each latch has one control line to latch a data value and one control line to output the latched value, so there are four control lines in total. Curiously, it appears that the notes aren't output sequentially; the order is 1, 13, 5, 11, 3, 15, 7, 10, 2, 14, 6, 12, 4, 16, 8, 9. I don't know if there's a motivation for this; it's also possible that I'm misinterpreting the circuit. ↩
  12. A few notes on the PLA outputs in case anyone looks at them more closely. Because signals get delayed through multiple shift registers and clock cycles, things don't happen on the cycle you'd expect. For instance, SYNC is generated 6 cycles before the end. Likewise, loading of the output buffer is triggered midway through operator 6, about 26 cycles later than operator 1 started generating outputs. Most PLA columns are triggered for a specific voice and operator value. The exception is the last column, which increments the operator regardless of the operator value. Curiously, there are three counter reset lines. One resets near the end of operator 1 (as you'd expect). The other two reset near the end of the two invalid operator values (there are 6 operators but 8 possible bit values). Presumably this keeps the synth from starting up in a bad state. Below the PLA are some gates. These are mostly buffering and clock synchronization. ↩
  13. Someone with a DX7 could probe the three unused pins and verify that they count out the notes. ↩
  14. For more information on the DX7 internals, see DX7 Technical Analysis, DX7 Hardware, OPLx decapsulated, and the video Emulating the DX7 the hard way. ↩
