One interesting aspect of a computer's instruction set is its addressing modes, how the computer determines the
address for a memory access.
The Intel 8086 (1978) used the
ModR/M byte, a special byte following the opcode, to select the addressing mode.1
The ModR/M byte has persisted into the modern x86 architecture, so it's interesting to look at its roots and original implementation.
In this post, I look at the hardware and microcode in the 8086 that implements ModR/M2
and how the 8086 designers fit multiple addressing modes into the 8086's limited microcode ROM.
One technique was a hybrid approach that combined generic microcode with hardware logic that filled in the details for a particular instruction.
A second technique was modular microcode, with subroutines for various parts of the task.
I've been reverse-engineering the 8086 starting with the silicon die.
The die photo below shows the chip under a microscope.
The metal layer on top of the chip is visible, with the silicon and polysilicon mostly hidden underneath.
Around the edges of the die, bond wires connect pads to the chip's 40 external pins.
I've labeled the key functional blocks; the ones that are important to this discussion are darker and will be discussed in detail below.
Architecturally, the chip is partitioned into a Bus Interface Unit (BIU) at the top and an Execution Unit (EU) below.
The BIU handles bus and memory activity as well as instruction prefetching, while the Execution Unit (EU) executes instructions and microcode.
Both units play important roles in memory addressing.
8086 addressing modes
Let's start with an addition instruction, ADD
dst,src, which adds a source value to a destination value and stores the result in the destination.3
What are the source and destination? Memory? Registers? The addressing mode answers this question.
You can use a register as the source and another register as the destination.
The instruction below uses the AX
register as the destination and the BX
register as the source. Thus, it adds BX
to AX
and puts the result
in AX
ADD AX, BX Add the contents of the BX register to the AX register
A memory access is indicated with square brackets around the "effective address"4 to access.
For instance, [1234]
means the memory location with address 1234,
while [BP]
means the memory location that the BP
register points to.
For a more complicated addressing mode, [BP+SI+1234]
means the memory location is determined by adding the BP and SI registers to the constant 1234 (known as the displacement).
On the 8086, you can use memory for the source or the destination, but not both.
Here are some examples of using memory as a source:
ADD AX, [1234] Add the contents of memory location 1234 to AX register
ADD CX, [BP] Add memory pointed to by BP register to CX register
ADD DX, [BX+SI+1234] Source memory address is BX + SI + constant 1234
Here are examples with memory as the destination:
ADD [1234], AX Add AX to the contents of memory location 1234
ADD [BP], CX Add CX to memory pointed to by BP register
ADD [BX+SI+1234], DX Destination memory address is BX + SI + constant 1234
You can also operate on bytes instead of words, using a byte register and accessing a memory byte:
ADD AL, [SI+1234] Add to the low byte of AX register
ADD AH, [BP+DI+1234] Add to the high byte of AX register
As you can see, the 8086 supports many different addressing schemes.
To understand how they are implemented, we must first look at how instructions encode the addressing schemes in the ModR/M byte.
The ModR/M byte
The ModR/M byte follows many opcodes to specify the addressing mode.
This byte is fairly complicated but I'll try to explain it in this section.
The diagram below shows how the byte is split into three fields:5
mod
selects the overall mode, reg
selects a register, and r/m
selects either a register or memory mode.
I'll start with the register-register mode, where the mod
bits are 11 and the reg
and r/m
fields each select one of eight registers, as shown below.
The instruction ADD AX,BX
would use reg
=011 to select BX
and r/m
=000 to select AX
, so the ModR/M byte would be
11011000.
(The register assignment depends on whether the instruction operates on words, bytes, or segment registers.
For instance, in a word instruction, 001
selects the CX
register, while in a byte instruction, 001
selects the CL
register, the low byte of CX
The next addressing mode specifies a memory argument and a register argument. In this case, the mod
bits are 00, the reg
field specifies a
register as described above, and the r/m
field specifies a memory address according to the table below.
For example, the instruction ADD [SI],CX
would use reg
=001 to select CX
and r/m
=100 to select [SI]
00001100.
r/m | Operand Address |
000 | [BX+SI] |
001 | [BX+DI] |
010 | [BP+SI] |
011 | [BP+DI] |
100 | [SI] |
101 | [DI] |
110 | [BP] |
111 | [BX] |
The next mode, 01, adds an 8-bit signed displacement to the address. This displacement consists of one byte
following the ModR/M byte. This supports addressing modes such as [BP+5]
The mode 10 is similar except the displacement is two bytes long,
for addressing modes such as [BP+DI+0x1234]
The table below shows the meaning of all 256 values for the ModR/M byte.
The mod
bits are colored red, the reg
bits green, and the r/m
bits blue.
Note the special case "disp16" to support a 16-bit fixed address.
The register combinations for memory accesses may seem random but they were designed to support the needs of high-level
languages, such as arrays and data structures.
The idea is to add a base register, an index register, and/or a fixed displacement to determine the address.6
The base register can indicate the start of an array, the index register holds the offset in the array, and the displacement provides the
offset of a field in the array entry.
The base register is BX
for data or BP
for information on the stack.
The index registers are SI
(Source Index) and DI
(Destination Index).7
Some addressing features are handled by the opcode, not the ModR/M byte.
For instance, the ModR/M byte doesn't distinguish between
ADD AX,[SI]
and ADD [SI],AX
Instead, the two
variants are distinguished by bit 1 of the instruction, the D
or "direction" bit.8
Moreover, many instructions have one opcode that operates on words and another that operates on bytes, distinguished by bit 0 of
the opcode, the W
or word bit.
The D
and W
bits are an example of orthogonality in the 8086 instruction set,
allowing features to be combined in various combinations.
For instance, the addressing modes combine 8 types of offset computation with three sizes of displacements and 8 target registers.
Arithmetic instructions combine these addressing modes with eight ALU operations,
each of which can act on a byte or a word, with two possible memory directions.
All of these combinations are implemented with one block of microcode, implementing a large instruction set with a small amount of microcode.
(The orthogonality of the 8086 shouldn't be overstated, though; it has many special cases and things that don't quite fit.)
An overview of 8086 microcode
Most people think of machine instructions as the basic steps that a computer performs.
However, many processors (including the 8086) have another layer of software underneath: microcode.
With microcode, instead of building the control circuitry from complex logic gates, the control logic is largely replaced with code.
To execute a machine instruction, the computer internally executes several simpler micro-instructions, specified by the microcode.
The 8086 uses a hybrid approach: although it uses microcode, much of the instruction functionality is implemented with gate logic.
This approach removed duplication from the microcode and kept the microcode small enough for 1978 technology.
In a sense, the microcode is parameterized.
For instance, the microcode can specify a generic Arithmetic/Logic Unit (ALU) operation and a generic register.
The gate logic examines the instruction to determine which specific operation to perform and the appropriate register.
A micro-instruction in the 8086 is encoded into 21 bits as shown below.
Every micro-instruction has a move from a source register to a destination register, each specified with 5 bits.
The meaning of the remaining bits depends on the type field.
A "short jump" is a conditional jump within the current block of 16 micro-instructions.
An ALU operation sets up the arithmetic-logic unit to perform an operation.
Bookkeeping operations are anything from flushing the prefetch queue to ending the current instruction.
A memory operation triggers a bus cycle to read or write memory.
A "long jump" is a conditional jump to any of 16 fixed microcode locations (specified in an external table called the Translation ROM).
Finally, a "long call" is a conditional subroutine call to one of 16 locations.
For more about 8086 microcode, see my microcode blog post.
Some examples of microcode for addressing
In this section, I'll take a close look at a few addressing modes and how they are implemented in microcode.
In the next section, I'll summarize all the microcode for addressing modes.
A register-register operation
Let's start by looking at a register-to-register instruction, before we get into the complications of memory accesses: ADD BX,AX
which adds AX
to BX
, storing the result in BX
. This instruction has the opcode value 01 and ModR/M value C3 (hex).
Before the microcode starts, the hardware performs some decoding of the opcode.
The Group Decode ROM (below) classifies an instruction into multiple categories:
this instruction contains a D bit, a W bit, and an ALU operation, and has a ModR/M byte.
Fields from the opcode and ModR/M bytes are extracted and stored in various internal registers.
The ALU operation type (ADD
) is stored in the ALU opr
register.
From the ModR/M byte,
the reg
register code (AX
) is stored in the N
register, and the r/m
register code
(BX
) is stored in the M
register.
(The M
and N
registers are internal registers that are invisible to the programmer; each holds a 5-bit register code that specifies a register.9)
This diagram shows the Group Decode ROM. The Group Decode ROM is more of a PLA (programmable logic array) with two layers of NOR gates. Its input lines are at the lower left and its outputs are at the upper right.
Once the preliminary decoding is done, the microcode below for this ALU instruction is executed.10
(There are three micro-instructions, so the instruction takes three clock cycles.)
Each micro-instruction contains a move and an action.
First, the register specified by M
(i.e. BX
) is moved to the ALU's temporary A register (tmpA
Meanwhile, the ALU is configured to perform the appropriate operation on tmpA
; XI
indicates that the ALU operation is specified by the instruction bits, i.e. ADD
The second instruction moves the register specified by N
(i.e. AX
) to the ALU's tmpB
register.
The action NX
indicates that this is the next-to-last micro-instruction so
the microcode engine can start processing the next machine instruction.
The last micro-instruction stores the ALU's result (Σ
) in the register indicated by M
(i.e. BX
The status flags are updated because of the F
WB,RNI
(Run Next Instruction) indicates that this is the end and the microcode engine can process the next machine instruction.
The WB
prefix would skip the actions if a memory writeback were pending (which is not the case).
move action
M → tmpA XI tmpA ALU rm↔r: BX to tmpA
N → tmpB WB,NX AX to tmpB
Σ → M WB,RNI F result to BX, run next instruction.
This microcode packs a lot into three micro-instructions.
Note that it is very generic: the microcode doesn't know what ALU operation is being performed or which registers are being used.
Instead, the microcode deals with abstract registers and operations, while the hardware fills in the details using bits from the instructions.
The same microcode is used for eight different ALU operations. And as we'll see, it supports multiple addressing modes.
Using memory as the destination
Memory operations on the 8086 involve both microcode and hardware.
A memory operation uses two internal registers: IND
(Indirect) holds the memory address, while OPR
(Operand) holds the word that is read or written.
A typical memory micro-instruction is R DS,P0
, which starts a read from the Data Segment
with a "Plus 0" on the IND
register afterward. The Bus Interface Unit carries out this operation by adding the segment register
to compute the physical address, and then running the memory bus cycles.
With that background, let's look at the instruction ADD [SI],AX
, which adds AX
to the memory location indexed by SI
As before, the hardware performs some analysis of the instruction (hex 01 04).
In the ModR/M byte, mod=00 (memory, no displacement), reg=000 (AX), and R/M=100 ([SI]).
The N
register is loaded with the code for AX
as before.
The M
register, however, is loaded with OPR
(the memory data register) since the Group Decode ROM determines that the instruction has a memory addressing mode.
The microcode below starts in an effective address microcode subroutine for the [SI]
mode.
The first line of the microcode subroutine computes the effective address simply by loading the tmpA
register with SI
. It jumps to the micro-routine EAOFFSET
which ends up at EALOAD
(for reasons that will be described below), which loads the value from memory.
Specifically, EALOAD
puts the address in IND
, reads the value from memory, puts the value into tmpB
, and returns from the subroutine.
SI → tmpA JMP EAOFFSET [SI]: put SI in tmpA
tmpA → IND R DS,P0 EALOAD: read memory
OPR → tmpB RTN
M → tmpA XI tmpA ALU rm↔r: OPR to tmpA
W DS,P0 RNI writes result to memory
Microcode execution continues with the ALU rm↔r
routine described above, but with a few differences.
The M
register indicates OPR
, so the value read from memory is put into tmpA
As before, the N
register specifies AX
, so that register is put into tmpB
In this case, the WB,NX
determines that the result will be written back to memory so it skips the NXT
operation.
The ALU's result (Σ
) is stored in OPR
as directed by M
The WB,RNI
is skipped so microcode execution continues.
The W DS,P0
micro-instruction writes the result (in OPR
) to the memory address in IND
At this point, RNI
terminates the microcode sequence.
A lot is going on here to add two numbers! The main point is that the same microcode runs as in the register case, but the results are different due to
the M
register and the conditional WB
code.
By running different subroutines, different effective address computations can be performed.
Using memory as the source
Now let's look at how the microcode uses memory as a source, as in the instruction ADD AX,[SI]
This instruction (hex 03 04) has the same
ModR/M byte as before, so the N
register holds AX
and the M
register holds OPR
However, because the opcode has the D bit set, the M
and N
registers are swapped when accessed.
Thus, when the microcode uses M
, it gets the value AX
from N
, and vice versa. (Yes, this is confusing.)
The microcode starts the same as the previous example, reading [SI]
into tmpB
and returning to the ALU code.
However, since the meaning of M
and N
are reversed, the AX value goes into tmpA
while the memory value goes into tmpB
(This switch doesn't matter for addition, but would matter for subtraction.)
An important difference is that there is no writeback to memory, so WB,NX
starts processing the next machine instruction.
In the last micro-instruction, the result is written to M
, indicating the AX
register. Finally, WB,RNI
runs the next machine instruction.
OPR → tmpB RTN
M → tmpA XI tmpA ALU rm↔r: AX to tmpA
N → tmpB WB,NX OPR to tmpB
Σ → M WB,RNI F result to AX, run next instruction.
The main point is that the same microcode handles memory as a source and a destination, simply by setting the D
bit.
First, the D
bit reverses the operands by swapping M
and N
Second, the WB
conditionals prevent the writeback to memory that happened in the previous case.
Using a displacement
The memory addressing modes optionally support a signed displacement of one or two bytes.
Let's look at the instruction ADD AX,[SI+0x1234]
In hex, this instruction is 03 84 34 12, where the last two bytes are the displacement, reversed because the 8086 uses little-endian numbers.
The mod bits are 10, indicating a 16-bit displacement, but the other bits are the same as in the previous example.
Microcode execution again starts with the [SI]
subroutine.
However, the jump to EAOFFSET
goes to [i]
this time, to handle the displacement offset. (I'll explain how, shortly.)
This code loads the offset as two bytes from the instruction prefetch queue (Q
) into the tmpB
register.
It adds the offset to the previous address in tmpA
and puts the sum Σ in tmpA
, computing the effective address. Then it jumps to EAFINISH
(EALOAD
From there, the code continues as earlier, reading an argument from memory and computing the sum.
Q → tmpBL JMPS MOD1 12 [i]: load from queue, conditional jump
Q → tmpBH
Σ → tmpA JMP EAFINISH 12:
OPR → tmpB RTN
For the one-byte displacement case,
the conditional MOD1
will jump over the fetch of the second displacement byte.
When the first byte is loaded into the low byte of tmpB
, it was sign-extended into the high byte.14
Thus, the one-byte displacement case uses the same microcode but ends up with a sign-extended 1-byte displacement in tmpB
The Translation ROM
Now let's take a closer look at the jumps to EAOFFSET
, EAFINISH
, and the effective address subroutines, which use something called the Translation ROM.
The Translation ROM converts the 5-bit jump tag in a micro-instruction into a 13-bit microcode address.
It also provides the addresses of the effective address subroutines.
As will be seen below, there are some complications.11
The Translation ROM as it appears on the die. The metal layer has been removed to expose the silicon and polysilicon underneath. The left half decodes the inputs to select a row. The right half outputs the corresponding microcode address.
The effective address micro-routines
Register calculations
The Translation ROM has an entry for the addressing mode calculations such as [SI]
and [BP+DI]
, generally indicated by the r/m
bits,
the three low bits of the ModR/M byte.
Each routine computes the effective address and puts it into the ALU's temporary A register and jumps to EAOFFSET
, which adds any
The microcode below shows the four simplest effective address calculations, which just load the appropriate register into tmpA
SI → tmpA JMP EAOFFSET [SI]: load SI into tmpA
DI → tmpA JMP EAOFFSET [DI]: load SI into tmpA
BP → tmpA JMP EAOFFSET [BP]: load BP into tmpA
BX → tmpA JMP EAOFFSET [BX]: load BX into tmpA
For the cases below, an addition is required, so the registers are loaded into the ALU's temporary A and temporary B registers.
The effective address is the sum (indicated by Σ), which is moved to temporary A.12
These routines are carefully arranged in memory so [BX+DI]
and [BP+SI]
each execute one micro-instruction and then jump into
the middle of the other routines, saving code.13
BX → tmpA [BX+SI]: get regs
SI → tmpB 1:
Σ → tmpA JMP EAOFFSET
BP → tmpA [BP+DI]: get regs
DI → tmpB 4:
BX → tmpA JMPS 4 [BX+DI]: short jump to 4
BP → tmpA JMPS 1 [BP+SI]: short jump to 1
The EAOFFSET
and EAFINISH
targets
After computing the register portion of the effective address, the routines above jump to
EAOFFSET
, but this is not a fixed target.
Instead, the Translation ROM selects one of three target microcode addresses based on the instruction and the ModR/M byte:
If there's a displacement, the microcode jumps to [i]
to add the displacement value.
If there is no displacement but a memory read, the microcode otherwise jumps to EALOAD
to load the memory contents.
If there is no displacement and no memory read should take place, the microcode jumps to EADONE
In other words, the microcode jump is a three-way branch that is implemented by the Translation ROM and is transparent to the microcode.
For a displacement, the [i]
immediate code below loads a 1-byte or 2-byte displacement into the tmpB
register and adds it to the tmpA
register,
as described earlier.
At the end of a displacement calculation, the microcode jumps to the EAFINISH
tag, which is another branching target.
Based on the instruction, the Translation ROM selects one of two microcode targets: EALOAD
to load from memory, or EADONE
to skip the load.
Q → tmpBL JMPS MOD1 12 [i]: get byte(s)
Q → tmpBH
Σ → tmpA JMP EAFINISH 12: add displacement
The EALOAD
microcode below reads the value from memory, using the effective address in tmpA
. It puts the result in tmpB
The RTN
micro-instruction returns to the microcode that implements the original machine instruction.
tmpA → IND R DS,P0 EALOAD: read from tmpA address
OPR → tmpB RTN store result in tmpB, return
The EADONE
routine puts the effective address in IND
, but it doesn't read from the memory location.
This supports machine instructions such as MOV
(some moves) and LEA
(Load Effective Address) that don't read from memory
tmpA → IND RTN EADONE: store effective address in IND
To summarize, the microcode runs different subroutines and different paths, depending on the addressing mode, executing the appropriate code.
The Translation ROM selects the appropriate control flow path.
Special cases
There are a couple of special cases in addressing that I will discuss in this section.
Supporting a fixed address
It is common to access a fixed memory address, but the standard addressing modes use a base or index register.
The 8086 replaces the mode of [BP]
with no displacement with 16-bit fixed addressing.
In other words, a ModR/M byte with the pattern 00xxx110
is treated specially.
(This special case is the orange disp16
line in the ModR/M table earlier.)
This is implemented in the Translation ROM which has additional rows to
detect this pattern and execute the immediate word [iw]
microcode below instead.
This microcode fetches a word from the instruction prefetch queue (Q
) into the tmpA
register, a byte at a time.
It jumps to EAFINISH
instead of EAOFFSET
because it doesn't make sense to add another displacement.
Q → tmpAL [iw]: get bytes
Q → tmpAH JMP EAFINISH
Selecting the segment
Memory accesses in the 8086 are relative to one of the 64-kilobyte segments: Data Segment, Code Segment, Stack Segment, or Extra Segment.
Most addressing modes use the Data Segment by default.
However, addressing modes that use the BP
register use the Stack Segment by default.
This is a sensible choice since the BP
(Base Pointer) register is intended for accessing values on the stack.
This special case is implemented in the Translation ROM.
It has an extra output bit that indicates that the addressing mode should use the Stack Segment.
Since the Translation ROM is already decoding the addressing mode to select the right microcode routine, adding
one more output bit is straightforward.
This bit goes to the segment register selection circuitry, changing the default segment.
This circuitry also handles prefixes that change the segment.
Thus, segment register selection is handled in hardware without any action by the microcode.
I hope you have enjoyed this tour through the depths of 8086 microcode.
The effective address calculation in the 8086 uses a combination of microcode and logic circuitry to implement
a variety of addressing methods.
Special cases make the addressing modes more useful, but make the circuitry more complicated.
This shows the CISC (Complex Instruction Set Computer) philosophy of x86, making the instructions complicated but
highly functional. In contrast, the RISC (Reduced Instruction Set Computer) philosophy takes the opposite approach,
making the instructions simpler but allowing the processor to run faster.
RISC vs. CISC was a big debate of the 1980s, but isn't as relevant nowadays.
People often ask if microcode could be updated on the 8086. Microcode was hardcoded into the ROM, so it could not be changed.
This became a big problem for Intel with the famous Pentium floating-point division bug.
The Pentium chip turned out to have a bug that resulted in rare but serious errors when dividing.
Intel recalled the defective processors in 1994 and replaced them at a cost of $475 million.
Starting with the Pentium Pro (1995), microcode could be patched at boot time, a useful feature that persists in modern CPUs.
I've written multiple posts on the 8086 so far and
plan to continue reverse-engineering the 8086 die so
follow me on Twitter @kenshirriff or RSS for updates.
I've also started experimenting with Mastodon recently as @[email protected].
