Reverse engineering standard cell logic in the Intel 386 processor
The 386 processor (1985) was Intel's most complex processor at the time, with 285,000 transistors. Intel had scheduled 50 person-years to design the processor, but it was falling behind schedule. The design team decided to automate chunks of the layout, developing "automatic place and route" software.1 This was a risky decision since if the software couldn't create a dense enough layout, the chip couldn't be manufactured. But in the end, the 386 finished ahead of schedule, an almost unheard-of accomplishment.
In this article, I take a close look at the "standard cells" used in the 386, the logic blocks that were arranged and wired by software. Reverse-engineering these circuits shows how standard cells implement logic gates, latches, and other components with CMOS transistors. Modern integrated circuits still use standard cells, much smaller now, of course, but built from the same principles.
The photo below shows the 386 die with the automatic-place-and-route regions highlighted in red. These blocks of unstructured logic have cells arranged in rows, giving them a characteristic striped appearance. In comparison, functional blocks such as the datapath on the left and the microcode ROM in the lower right were designed manually to optimize density and performance, giving them a more solid appearance. As for other features on the chip, the black circles around the border are bond wire connections that go to the chip's external pins. The chip has two metal layers, a small number by modern standards, but a jump from the single metal layer of earlier processors such as the 286. The metal appears white in larger areas, but purplish where circuitry underneath roughens its surface. For the most part, the underlying silicon and the polysilicon wiring on top are obscured by the metal layers.
Die photo of the 386 processor with standard-cell logic highlighted in red.
Early processors in the 1970s were usually designed by manually laying out every transistor individually, fitting transistors together like puzzle pieces to optimize their layout. While this was tedious, it resulted in a highly dense layout. Federico Faggin, designer of the popular Z80 processor, describes finding that the last few transistors wouldn't fit, so he had to erase three weeks of work and start over. The closeup of the resulting Z80 layout below shows that each transistor has a different, complex shape, optimized to pack the transistors as tightly as possible.2
A closeup of transistors in the Zilog Z80 processor (1976). This chip is NMOS, not CMOS, which provides more layout flexibility. The metal and polysilicon layers have been removed to expose the underlying silicon. The lighter stripes over active silicon indicate where the polysilicon gates were. I think this photo is from the Visual 6502 project but I'm not sure.
Standard-cell logic is an alternative that is much easier than manual layout.3 The idea is to create a standard library of blocks (cells) to implement each type of gate, flip-flop, and other low-level component. To use a particular circuit, instead of arranging each transistor, you use the standard design. Each cell has a fixed height but the width varies as needed, so the standard cells can be arranged in rows. For example, the die photo below three cells in a row: a latch, a high-current inverter, and a second latch. This region has 24 transistors in total with PMOS above and NMOS below. Compare the orderly arrangement of these transistors with the Z80 transistors above.
Some standard cell circuitry in the 386. I removed the metal and polysilicon to show the underlying silicon. The irregular blotches are oxide that wasn't fully removed, and can be ignored.
The space between rows is used as a "wiring channel" that holds the wiring between the cells. The photo below zooms out to show four rows of standard cells (the dark bands) and the wiring in between. The 386 uses three layers for this wiring: polysilicon and the upper metal layer (M2) for vertical segments and the lower metal layer (M1) for horizontal segments.
Some standard-cell logic in the 386 processor.
To summarize, with standard cell logic, the cells are obtained from the standard cell library as needed, defining the transistor layout and the wiring inside the cell. However, the locations of each cell (placing) need to be determined, as well as how to arrange the wiring (routing). As will be seen, placing and routing the cells can be done manually or automatically.
Use of standard cells in the 386
Fairly late in the design process, the 386 team decided to use automatic place and route for parts of the chip. By using automatic place and route, 2,254 gates (consisting of over 10,000 devices) were placed and routed in seven weeks. (These numbers are from a paper "Automatic Place and Route Used on the 80386", co-written by Pat Gelsinger, now the CEO of Intel. I refer to this paper multiple times, so I'll call it APR386 for convenience.4) Automatic place and route was not only faster, but it avoided the errors that crept in when layout was performed manually.5
The "place" part of automatic place and route consists of determining the arrangement of the standard cells into rows to minimize the distance between connected cells. Running long wires between cells wastes space on the die, since you end up with a lot of unnecessary metal wiring. But more importantly, long paths have higher resistance, slowing down the signals. Placement is a difficult optimization problem that is NP-complete. Moreover, the task was made more complicated by weighting paths by importance and electrical characteristics, classifying signals as "normal", "fast", or "critical". Paths were also weighted to encourage the use of the thicker M2 metal layer rather than the lower M1 layer.
The 386 team solved the placement problem with a program called Timberwolf, developed by a Berkeley grad student. As one member of the 386 team said, "If management had known that we were using a tool by some grad student as a key part of the methodology, they would never have let us use it." Timberwolf used a simulated annealing algorithm, based on a simulated temperature that decreased over time. The idea is to randomly move cells around, trying to find better positions, but gradually tighten up the moves as the "temperature" drops. At the end, the result is close to optimal. The purpose of the temperature is to avoid getting stuck in a local minimum by allowing "bad" changes at the beginning, but then tightening up the changes as the algorithm progresses.
Once the cells were placed in their positions, the second step was "routing", generating the layout of all the wiring. A suitable commercial router was not available in 1984, so Intel developed its own. As routing is a difficult problem (also NP-complete), they took an iterative heuristic approach, repeatedly routing until they found the smallest channel height that would work. (Thus, the wiring channels are different sizes as needed.) Then they checked the R-C timing of all the signals to find any signals that were too slow. Designers could boost the size of the associated drivers (using the variety of available standard cells) and try the routing again.
Brief CMOS overview
The 386 was the first processor in Intel's x86 line to be built with a technology called CMOS instead of using NMOS. Modern processors are all built from CMOS because CMOS uses much less power than NMOS. CMOS is more complicated to construct, though, because it uses two types of transistors—NMOS and PMOS—so early processors were typically NMOS. But by the mid-1980s, the advantages of switching to CMOS were compelling.
The diagram below shows how an NMOS transistor is constructed. The transistor can be considered a switch between the source and drain, controlled by the gate. The source and drain regions (green) consist of silicon doped with impurities to change its semiconductor properties, forming N+ silicon. The gate consists of a layer of polysilicon (red), separated from the silicon by a very thin insulating oxide layer. Whenever polysilicon crosses active silicon, a transistor is formed. A PMOS transistor has similar construction except it swaps the N-type and P-type silicon, consisting of P+ regions in a substrate of N silicon.
Diagram showing the structure of an NMOS transistor.
The NMOS and PMOS transistors are opposite in their construction and operation. An NMOS transistor turns on when the gate is high, while a PMOS transistor turns on when the gate is low. An NMOS transistor is best at pulling its output low, while a PMOS transistor is best at pulling its output high. In a CMOS circuit, the transistors work as a team, pulling the output high or low as needed; this is the "Complementary" in CMOS. (The behavior of MOS transistors is complicated, so this description is simplified, just enough to understand digital circuits.)
One complication is that NMOS transistors are built on P-type silicon, while PMOS transistors are built on N-type silicon. Since the silicon die itself is N silicon, the NMOS transistors need to be surrounded by a tub or well of P silicon.6 The cross-section diagram below shows how the NMOS transistor on the left is embedded in a well of P-type silicon.
Simplified structure of the CMOS circuits.
For proper operation, the silicon that surrounds transistors needs to be connected to the appropriate voltage through "tap" contacts.7 For PMOS transistors, the substrate is connected to power through the taps, while for NMOS transistors the well region is connected to ground through the taps. The chip needs to have enough taps to keep the voltage from fluctuating too much; each standard cell typically has a positive tap and a ground tap.
The actual structure of the integrated circuit is much more three-dimensional than the diagram above, due to the thickness of the various layers. The diagram below is a more accurate cross-section. The 386 has two layers of metal: the lower metal layer (M1) in blue and the upper metal layer (M2) in purple. Polysilicon is colored red, while the insulating oxide layers are gray.
Cross-section of CHMOS III transistors. From A double layer metal CHMOS III technology, image colorized by me.
This complicated three-dimensional structure makes it harder to interpret the microscope images. Moreover, the two metal layers obscure the circuitry underneath. I have removed various layers with acids for die photos, but even so, the images are harder to interpret than those of simpler chips. If the die photos look confusing, don't be surprised.
A logic gate in CMOS is constructed from NMOS and PMOS transistors working together. The schematic below shows a NAND gate with two PMOS transistors in parallel above and two NMOS transistors in series below. If both inputs are high, the two NMOS transistors turn on, pulling the output low. If either input is low, a PMOS transistor turns on, pulling the output high. (Recall that NMOS and PMOS are opposites: a high voltage turns an NMOS transistor on while a low voltage turns a PMOS transistor on.) Thus, the CMOS circuit below produces the desired output for the NAND function.
A CMOS NAND gate.
A CMOS NAND gate.
The diagram below shows how this NAND gate is implemented in the 386 as a standard cell.9 A lot is going on in this cell, but it boils down to four transistors, as in the schematic above. The yellow region is the P-type silicon that forms the two PMOS transistors; the transistor gates are where the polysilicon (red) crosses the yellow region.8 (The middle yellow region is the drain for both transistors; there is no discrete boundary between the transistors.) Likewise, the two NMOS transistors are at the bottom, where the polysilicon (red) crosses the active silicon (green). The blue lines indicate the metal wiring for the cell. I thinned these lines to make the diagram clearer; in the actual cell, the metal lines are as thick as they can be without touching, so they cover most of the cell. The black circles are contacts, connections between the metal and the silicon or polysilicon. Finally, the well taps are the opposite type of silicon, connected to the underlying silicon well or substrate to keep it at the proper voltage.
A standard cell for NAND in the 386.
Wiring to a cell's inputs and output takes place at the top or bottom of the cell, with wiring in the channels between rows of cells. The polysilicon input and output lines are thickened at the top and bottom of the cell to allow connections to the cell. The wiring between cells can be done with either polysilicon or metal. Typically the upper metal layer (M2) is used for vertical wiring, while the lower metal layer (M1) is used for horizontal runs. Since each standard cell only uses M1, vertical wiring (M2) can pass over cells. Moreover, a cell's output can also use a vertical metal wire (M2) rather than the polysilicon shown. The point is that there is a lot of flexibility in how the system can route wires between the cells. The power and ground wires (M1) are horizontal so they can run from cell to cell and a whole row can be powered from the ends.
The photo below shows this NAND cell with the metal layers removed by acid, leaving the silicon and the polysilicon. You can match the features in the photo with the diagram above. The polysilicon appears green due to thin-film effects. At the bottom, two polysilicon lines are connected to the inputs.
Die photo of the NAND standard cell with the metal layers removed. The image isn't as clear as I would like, but it was very difficult to remove the metal without destroying the polysilicon.
The photo below shows how the cell appears in the original die. The two metal layers are visible, but they hide the polysilicon and silicon underneath. The vertical metal stripes are the upper (M2) wiring while the lower metal wiring (M1) makes up the standard cell. It is hard to distinguish the two metal layers, which makes interpretation of the images difficult. Note that the metal wiring is wide, almost completely covering the cell, with small gaps between wires. The contacts are visible as dark circles. Is hard to recognize the standard cells from the bare die, as the contact pattern is the only distinguishing feature.
Die photo of the NAND standard cell showing the metal layer.
One of the interesting features of the 386's standard cell library is that each type of logic gate is available in multiple drive strengths. That is, cells are available with small transistors, large transistors, or multiple transistors in parallel. Because the wiring and the transistor gates have capacitance, a delay occurs when changing state. Bigger transistors produce more current, so they can switch the values on a wire faster. But there are two disadvantages to bigger transistors. First, they take up more space on the die. But more importantly, bigger transistors have bigger gates with more capacitance, so their inputs take longer to switch. (In other words, increasing the transistor size speeds up the output but slows the input, so overall performance could end up worse.) Thus, the sizes of transistors need to be carefully balanced to achieve optimum performance.10 With a variety of sizes in the standard cell library, designers can make the best choices.
The image below shows a small NAND gate. The design is the same as the one described earlier, but the transistors are much smaller. (Note that there is one row of metal contacts instead of two or three.) The transistor gates are about half as wide (measured vertically) so the NAND gate will produce about half the output current.11
Die photo of a small NAND standard cell with the metal removed.
Since the standard cells are all the same height, the maximum size of a transistor is limited. To provide a larger drive strength, multiple transistors can be used in parallel. The NAND gate below uses 8 transistors, four PMOS and four NMOS, providing twice as much current.
A large NAND gate as it appears on the die, with the metal removed. The left side is slightly obscured by some remaining oxide.
The diagram below shows the structure of the large NAND gate, essentially two NAND gates in parallel. Note that input 1 must be provided separately to both halves by the routing outside the cell. Input 2, on the other hand, only needs to be supplied to the cell once, since it is wired to both halves inside the cell.
A diagram showing the structure of the large NAND gate.
Inverters are also available in a variety of drive strengths, from very small to very large, as shown below. The inverter on the left uses the smallest transistors, while the inverter on the right not only uses large transistors but is constructed from six inverters in parallel. One polysilicon input controls all the transistors.
A small inverter and a large inverter.
A more complex standard cell is XOR. The diagram below shows an XOR cell with large drive current. (There are smaller XOR cells). As with the large NAND gate, the PMOS transistors are doubled up for more current. The multiple input connections are handled by the routing outside the cell. Since the NMOS transistors don't need to be doubled up, there is a lot of unused space in the lower part of the cell. The extra space is used for a very large tap contact, consisting of 24 contacts to ground the well.
The structure of an XOR cell with large drive current.
XOR is a difficult gate to build with CMOS. The cell above implements it by combining a NOR gate and an AND-NOR gate, as shown below. You can verify that if both inputs are 0 or both inputs are 1, the output is forced low as desired. In the layout above, the NOR gate is on the left, while the AND-NOR gate has the AND part on the right. A metal wire down the center connects the NOR output to the AND-NOR input. The need for two sub-gates is another reason why the XOR cell is so large.
Schematic of the XOR cell.
I'll describe one more cell, the latch, which holds one bit and is controlled by a clock signal. Latches are heavily used in the 386 whenever a signal needs to be remembered or a circuit needs to be synchronous. The 386 has multiple types of standard cell latches including latches with set or reset controls and latches with different drive strengths. Moreover, two latches can be combined to form an edge-triggered flip-flop standard cell.
The schematic below shows the basic latch circuit, the most common type in the 386. On the right, two inverters form a loop. This loop can stably hold a 0 or 1 value. On the left, a PMOS transistor and an NMOS transistor form a transmission gate. If the clock is high, both transistors will turn on and pass the input through. If the clock is low, both transistors will turn off and block the input. The trick to the latch is that one inverter is weak, producing just a small current. The consequence is that the input can overpower the inverter output, causing the inverter loop to switch to the input value. The result is that when the clock is high, the latch will pass the input value through to the output. But when the clock is low, the latch will hold its previous value. (The output is inverted with respect to the input, which is slightly inconvenient but reduces the size of the latch.)
Schematic of a latch.
The standard cell layout of the latch (below) is complicated, but it corresponds to the schematic. At the left are the PMOS and NMOS transistors that form the transmission gate. In the center is the weak inverter, with its output to the left. The weak transistors are in the middle; they are overlapped by a thick polysilicon region, creating a long gate that produces a low current.12 At the right is the inverter that drives the output. The layout of this circuit is clever, designed to make the latch as compact as possible. For example, the two inverters share power and ground connections. Notice how the two clock lines pass from top to bottom through gaps in the active silicon so each line only forms one transistor. Finally, the metal line in the center connects the transmission gate outputs and the weak inverter output to the other inverter's input, but asymmetrically at the top so the two inverters don't collide.
The standard cell layout of a latch.
To summarize, I examined many (but not all) of the standard cells in the 386 and found about 70 different types of cells. These included the typical logic gates with various drive strengths: inverters, buffers, XOR, XNOR, AND-NOR, and 3- and 4-input logic gates. There are also transmission gates including ones that default high or low, as well as multiplexers built from transmission gates. I found a few cells that were surprising such as dual inverters and a combination 3-input and 2-input NAND gate. I suspect these consist of two standard cells that were merged together, since they seem too specialized to be part of a standard cell library.
The APR386 paper showed six of the standard cells in the 386 with the diagram below. The small and large inverters are the same as the ones described above, as is the NAND gate NA2B. The latch is similar to the one described above, but with larger transistors. The APR386 paper also showed a block of standard cells, which I was able to locate in the 386.13
Examples of standard cells, from APR386. The numbers are not defined but may indicate input and output capacitance. (Click for a larger version.)
Intel's standard cell line
Intel productized its standard cells around 1986 as a 1.5 µm library using Intel's CMOS technology (called CHMOS III).14 Although the library had over 100 cell types, it was very limited compared to the cells used inside the 386. The library included logic gates, flip-flops, and latches as well as scalable registers, counters, and adders. Most gates only came in one drive strength. Even inverters only came in "normal" and "high" drive strength. I assume these cells are the same as the ones used in the 386, but I don't have proof. The library also included larger devices such as a cell-compatible 80C51 microcontroller and PC peripheral chips such as the 8259 programmable interrupt controller and the 8254 programmable interval timer. I think these were re-implemented using standard cells.
Intel later produced a 1.0 µm library using CHMOS IV, for use "both by ASIC customers and Intel's internal chip designers." This library had a larger collection of drive strengths. The 1.0 µm library included the 80C186 and associated peripheral chips.
Layout techniques in the 386
In this section, I'll look at the active silicon regions, making the cells themselves more visible. In the photos below, I dissolved the metal and polysilicon, leaving the active silicon. (Ignore the irregular greenish shapes; these are oxide that wasn't fully removed.)
The photo below shows the silicon for three rows of standard cells using automatic place and route. You can see the wide variety of standard cell widths, but the height of the cells is constant. The transistor gates are visible as the darker vertical stripes across the silicon. You may be able to spot the latch in each row, distinguished by the long, narrow transistors of the weak inverters.
Three rows of standard cells that were automatically placed and routed.
In the first row, the larger PMOS transistors are on top, while the smaller NMOS transistors are below. This pattern alternates from row to row, so the second row has the NMOS transistors on top and the third row has the PMOS transistors on top. The height of the wiring channel between the cells is variable, made as small as possible while fitting the wiring.
The 386 also contains regions of standard cells that were apparently manually placed and routed, as shown in the photo below. Using standard cells avoids the effort of laying out each transistor, so it is still easier than a fully custom layout. These cells are in rows, but the rows are now double rows with channels in between. The density is higher, but routing the wires becomes more challenging.
Three rows of standard cells that were manually placed and routed.
For critical circuitry such as the datapath, the layout of each transistor was optimized. The register file, for example, has a very dense layout as shown below. As you can see, the density is much higher than in the previous photos. (The three photos are at the same scale.) Transistors are packed together with very little wasted space. This makes the layout difficult since there is little room for wiring. For this particular circuit, the lower metal layer (M1) runs vertically with signals for each bit while the upper metal layer (M2) runs horizontally for power, ground, and control signals.15
The point of this is that the 386 uses a variety of different design techniques, from dense manual layout to much faster automated layout. Different techniques were used for different parts of the chip, based on how important it was to optimize. For example, circuits in the datapath were typically repeated 32 times, once for each bit, so manual effort was worthwhile. The most critical functional blocks were the microcode ROM (CROM), large PLAs, ALU, TLB (translation lookaside buffer), and the barrel shifter.16
Standard cell logic and automatic place and route have a long history before the 386, back to the early 1970s, so this isn't an Intel invention.17 Nonetheless, the 386 team deserves the credit for deciding to use this technology at a time when it was a risky decision. They needed to develop custom software for their placing and routing needs, so this wasn't a trivial undertaking. This choice paid off and they completed the 386 ahead of schedule. The 386 ended up being a huge success for Intel, moving the x86 architecture to 32-bits and defining the dominant computer architecture for the rest of the 20th century.
If you're interested in standard cell logic, I wrote about standard cell logic in an IBM chip. I plan to write more about the 386, so follow me on Twitter @kenshirriff or RSS for updates. I'm also on Mastodon occasionally as @[email protected]. Thanks to Pat Gelsinger and Roxanne Koester for providing helpful papers.
  1. The decision to use automatic place and route is described on page 13 of the Intel 386 Microprocessor Design and Development Oral History Panel, a very interesting document on the 386 with discussion from some of the people involved in its development. ↩
  2. Circuits that had a high degree of regularity, such as the arithmetic/logic unit (ALU) or register storage were typically constructed by manually laying out a block to implement a bit and then repeating the block as needed. Because a circuit was repeated 32 times for the 32-bit processor, the additional effort was worthwhile. ↩
  3. An alternative layout technique is the gate array, which doesn't provide as much flexibility as a standard cell approach. In a gate array (sometimes called a master slice), the chip had a fixed array of transistors (and often resistors). The chip could be customized for a particular application by designing the metal layer to connect the transistors as needed. The density of the chip was usually poor, but gate arrays were much faster to design, so they were advantageous for applications that didn't need high density or produced a relatively small volume of chips. Moreover, manufacturing was much faster because the silicon wafers could be constructed in advance with the transistor array and warehoused. Putting the metal layer on top for a particular application could then be quick. Similar gate arrays used a fixed arrangement of logic gates or flip-flops, rather than transistors. Gate arrays date back to 1967. ↩
  4. The full citation for the APR386 paper is "Automatic Place and Route Used on the 80386" by Joseph Krauskopf and Pat Gelsinger, Intel Technology Journal, Spring 1986. I was unable to find it online. ↩
  5. Once the automatic place and route process had finished, the mask designers performed some cleanup along with compaction to squeeze out wasted space, but this was a relatively minor amount of work.
    While manual optimization has benefits, it can also be overdone. When the manufacturing process improved, the 80386 moved from a 1.5 µm process to a 1 µm process. The layout engineers took advantage of this switch to optimize the standard cell circuitry, manually squeezing out some extra space. Unfortunately, optimizing one block of a die doesn't necessarily make the die smaller, since the size is constrained by the largest blocks. The result is that the optimized 80386 has blocks of empty space at the bottom (visible as black rectangles) and the standard-cell optimization didn't provide any overall benefit. (As the Pentium Pro chief architect Robert Colwell explains, "Removing the state of Kansas does not make the perimeter of the United States any smaller.")
    Comparison of the 1.5 µm die and the 1 µm die at the same scale. Photos courtesy of Antoine Bercovici.
    At least compaction went better for the 386 than for the Pentium. Intel performed a compaction on the Pentium shortly before release, attempting to reduce the die size. The engineers shrunk the floating point divider, removing some lookup table cases that they proved were unnecessary. Unfortunately, the proof was wrong, resulting in floating point errors in a few cases. This caused the infamous Pentium FDIV bug, a problem that became highly visible to the general public. Replacing the flawed processors cost Intel 475 million dollars. And it turned out that shrinking the floating point divider had no effect on the overall die size.
    Coincidentally, early models of the 386 had an integer multiplication bug, but Intel fixed this with little cost or criticism. The 386 bug was an analog issue that only showed up unpredictably with a combination of argument values, temperature, and manufacturing conditions. ↩
  6. This chip is built on a substrate of N-type silicon, with wells of P-type silicon for the NMOS transistors. Chips can be built the other way around, starting with P-type silicon and putting wells of N-type silicon for the PMOS transistors. Another approach is the "twin-well" CMOS process, constructing wells for both NMOS and PMOS transistors. ↩
  7. The bulk silicon voltage makes the boundary between a transistor and the bulk silicon act as a reverse-biased diode, so current can't flow across the boundary. Specifically, for a PMOS transistor, the N-silicon substrate is connected to the positive supply. For an NMOS transistor, the P-silicon well is connected to ground. A P-N junction acts as a diode, with current flowing from P to N. But the substrate voltages put P at ground and N at +5, blocking any current flow. The result is that the bulk silicon can be considered an insulator, with current restricted to the N+ and P+ doped regions. If this back bias gets reversed, for example, due to power supply fluctuations, current can flow through the substrate. This can result in "latch-up", a situation where the N and P regions act as parasitic NPN and PNP transistors that latch into the "on" state. This shorts power and ground and can destroy the chip. The point is that the substrate voltages are very important for the proper operation of the chip. ↩
  8. I'm using the standard CMOS coloring scheme for my diagrams. I'm told that Intel uses a different color scheme internally. ↩
  9. The schematic below shows the physical arrangement of the transistors for the NAND gate, in case it is unclear how to get from the layout to the logic gate circuit. The power and ground lines are horizontal so power can pass from cell to cell when the cells are connected in rows. The gate's inputs and outputs are at the top and bottom of the cell, where they can be connected through the wiring channels. Even though the transistors are arranged horizontally, the PMOS transistors (top) are in parallel, while the NMOS transistors (bottom) are in series.
    Schematic of the NAND gate as it is arranged in the standard cell.
  10. The 1999 book Logical Effort describes a methodology for maximizing the performance of CMOS circuits by correctly sizing the transistors. ↩
  11. Unfortunately, the word "gate" is used for both transistor gates and logic gates, which can be confusing. ↩
  12. You might expect that these transistors would produce more current since they are larger than the regular transistors. The reason is that a transistor's current output is proportional to the gate width divided by the length. Thus, if you make the transistor bigger in the width direction, the current increases, but if you make the transistor bigger in the length direction, the current decreases. You can think of increasing width as acting as multiple transistors in parallel. Increasing length, on the other hand, makes a longer path for current to get from the source to the drain, weakening it. ↩
  13. The APR386 paper discusses the standard-cell layout in detail. It includes a plot of a block of standard-cell circuitry (below).
    A block of standard-cell circuitry from APR386.
    After carefully studying the 386 die, I was able to find the location of this block of circuitry (below). The two regions match exactly; they look a bit different because the M1 metal layer (horizontal) doesn't show up in the plot above.
    The same block of standard cells on the 386 die.
  14. Intel's CHMOS III standard cells are documented in Introduction to Intel Cell-Based Design (1988). The CHMOS IV library is discussed in Design Methodology for a 1.0µ Cell-based Library Efficiently Optimized for Speed and Area. The paper Validating an ASIC Standard Cell Library covers both libraries. ↩
  15. For details on the 386's register file, see my earlier article. ↩
  16. Source: "High Performance Technology Circuits and Packaging for the 80386", Jan Prak, Proceedings, ICCD Conference, Oct. 1986. ↩
  17. I'll provide more history on standard cells in this footnote. RCA patented a bipolar standard cell in 1971, but this was a fixed arrangement of transistors and resistors, more of a gate array than a modern standard cell. Bell Labs researched standard cell layout techniques in the early 1970s, calling them Polycells, including a 1973 paper by Brian Kernighan. By 1979 A Guide to LSI Implementation discussed the standard cell approach and it was described as well-known in this patent application. Even so, Electronics called these design methods "futuristic" in 1980.
    Standard cells became popular in the mid-1980s as faster computers and improved design software made it practical to produce semi-custom designs that used standard cells. Standard cells made it to the cover of Digital Design in August 1985, and the article inside described numerous vendors and products. Companies like Zymos and VLSI Technology (VTI) focused on standard cells. Traditional companies such as Texas Instruments, NCR, GE/RCA, Fairchild, Harris, ITT, and Thomson introduced lines of standard cell products in the mid-1980s.  ↩
Reverse engineering CMOS, illustrated with a vintage Soviet counter chip
I recently came across an interesting die photo of a Soviet1 chip, probably designed in the 1970s. This article provides an introductory guide to reverse-engineering CMOS circuits, using this chip as an example. Although the chip looks like a tangle of lines at first, its large features and simple layout make it possible to understand its circuits. I'll first explain how to recognize the individual transistors. Groups of transistors are connected in standard patterns to form CMOS gates, multiplexers, flip-flops, and other circuits. Once these building blocks are understood, reverse-engineering the full chip becomes practical. The chip turned out to be a 4-bit CMOS counter, a copy of the Motorola MC14516B.
Die photo of the К561ИЕ11 chip on a wafer. Image courtesy of Martin Evtimov. Click this image (or any other) for a larger version.
The photo above shows the tiny silicon die under a microscope. Regions of the silicon are doped with impurities to change the silicon's electrical properties. This doping also causes regions of the silicon to appear greenish or reddish, depending on how a region is doped. (These color changes will turn out to be useful for reverse engineering.) On top of the silicon, the whitish metal layer is visible, forming the chip's connections. This chip uses metal-gate transistors, an old technology, so the metal layer also forms the gates of the transistors. Around the outside of the chip, the 16 square bond pads connect the chip to the outside world. When installed in a package, the die has tiny bond wires between the pads and the lead frame, the metal structure that connects to the chip's pins.
According to the Russian datasheet,2 the chip has 319 "elements", presumably counting the semiconductor devices. The chip has a handful of diodes to protect the inputs, so the total transistor count is a bit over 300. This transistor count is nothing compared to a modern CMOS processor with tens of billions of transistors, of course, but most of the circuit principles are the same.
CMOS is a low-power logic family now used in almost all processors.3 CMOS (complementary MOS) circuitry uses two types of transistors, NMOS and PMOS, working together. The diagram below shows how an NMOS transistor is constructed. The transistor can be considered a switch between the source and drain, controlled by the gate. The source and drain regions (red) consist of silicon doped with impurities to change its semiconductor properties, forming N+ silicon. The gate consists of an aluminum layer, separated from the silicon by a very thin insulating oxide layer.4 (These three layers—Metal, Oxide, Semiconductor—give the MOS transistor its name.) This oxide layer is an insulator, so there is essentially no current flow through the gate, one reason why CMOS is a low-power technology. However, the thin oxide layer is easily destroyed by static electricity, making MOS integrated circuits sensitive to electrostatic discharge.
Structure of an NMOS transistor.
A PMOS transistor (below) has the opposite configuration from an NMOS transistor: the source and drain are doped to form P+ regions, while the underlying bulk silicon is N-type silicon. The doping process is interesting, but I'll leave the details to a footnote.5
Structure of a PMOS transistor.
The NMOS and PMOS transistors are opposite in their construction and operation; this is the "Complementary" in CMOS. An NMOS transistor turns on when the gate is high, while a PMOS transistor turns on when the gate is low. An NMOS transistor is best at pulling its output low, while a PMOS transistor is best at pulling its output high. In a CMOS circuit, the transistors work as a team, pulling the output high or low as needed. The behavior of MOS transistors is complicated, so this description is simplified, just enough to understand digital circuits.
If you buy an MOS transistor from an electronics supplier, it comes as a package with three leads for the source, gate, and drain. The source and drain are connected differently inside the package and are not interchangeable in a circuit. In an integrated circuit, however, the transistor is symmetrical and the source and drain are the same. For that reason, I won't distinguish between the source and the drain in the following discussion. I will use the symmetrical symbols below for NMOS and PMOS transistors; the inversion bubble on the PMOS gate symbolizes that a low signal activates the PMOS transistor.
Symbols for NMOS and PMOS transistors.
One complication is that NMOS transistors are built on P-type silicon, while PMOS transistors are built on N-type silicon. Since the silicon die itself is N silicon, the NMOS transistors need to be surrounded by a tub or well of P silicon.6 The cross-section diagram below shows how the NMOS transistor on the right is embedded in the well of P-type silicon. Constructing two transistor types with opposite behaviors makes manufacturing more complex, one reason why CMOS took years to catch on. CMOS was invented in 1963 at Fairchild Semiconductor, but RCA was the main proponent of CMOS, commercializing it in the late 1960s. Although RCA produced a CMOS microprocessor in 1974, mainstream microprocessors didn't switch to CMOS until the mid-1980s with chips such as the Motorola 68020 (1984) and the Intel 386 (1986).
Cross-section of CMOS transistors.
For proper operation, the silicon that surrounds transistors needs to be connected to the appropriate voltage through "tap" contacts.7 For PMOS transistors, the substrate is connected to power through the taps, while for NMOS transistors the well region is connected to ground through the taps. When reverse-engineering, the taps can provide important clues, indicating which regions are NMOS and which are PMOS. As will be seen below, these voltages are also important for understanding the circuitry of this chip.
The die photo below shows two transistors as they appear on the die. The appearance of transistors varies between different integrated circuits, so a first step of reverse engineering is determining how they look in a particular chip. In this IC, a transistor gate can be distinguished by a large rectangular region over the silicon. (In other metal-gate transistors, the gate often has a "bubble" appearance.) The interactions between the metal wiring and the silicon can be distinguished by subtle differences. For the most part, the metal wiring passes over the silicon, isolated by thick insulating oxide. A contact between metal and silicon is recognizable by a smaller oval region that is slightly darker; wires are connected to the transistor sources and drains below. MOS transistors often don't have discrete boundaries; as will be seen later, the source of one transistor can overlap with the drain of another.
Two transistors on the die.
Distinguishing PMOS and NMOS transistors can be difficult. On this chip, P-type silicon appears greenish, and N-type silicon appears reddish. Thus, PMOS transistors appear as a green region surrounded by red, while NMOS is the opposite. Moreover, PMOS transistors are generally larger than NMOS transistors because they are weaker. Another way to distinguish them is by their connection in circuits. As will be seen below, PMOS transistors in logic gates are connected to power while NMOS transistors are connected to ground.
Metal-gate transistors are a very old technology, mostly replaced by silicon-gate transistors in the 1970s. Silicon-gate circuitry uses an additional layer of polysilicon wiring. Moreover, modern ICs usually have more than one layer of metal. The metal-gate IC in this post is easier to understand than a modern IC, since there are fewer layers to analyze. The CMOS principles are the same in modern ICs, but the layout will appear different.
Implementing an inverter in CMOS
The simplest CMOS gate is an inverter, shown below. Although basic, it illustrates most of the principles of CMOS circuitry. The inverter is constructed from a PMOS transistor on top to pull the output high and an NMOS transistor below to pull the output low. The input is connected to the gates of both transistors.
A CMOS inverter is constructed from a PMOS transistor (top) and an NMOS transistor (bottom).
Recall that an NMOS transistor is turned on by a high signal on the gate, while a PMOS transistor is the opposite, turned on by a low signal. Thus, when the input is high, the NMOS transistor (bottom) turns on, pulling the output low. When the input is low, the PMOS transistor (top) turns on, pulling the output high. Notice how the transistors act in opposite (i.e. complementary) fashion.
How the inverter functions.
An inverter on the die is shown below. The PMOS and NMOS transistors are indicated by red boxes and the transistors are connected according to the schematics above. The input is connected to the gates of the two transistors, which can be distinguished as larger metal rectangles. On the right, two contacts connect the transistor drains to the output. The power and ground connections are a bit different from most chips since the metal lines appear to not go anywhere. The short metal line labeled "power" connects the PMOS transistor's source to the substrate, the reddish silicon that surrounds the transistor. As described earlier, the substrate is connected to the chip's power. Thus, the transistor receives its power through the substrate silicon. This approach isn't optimal, due to the relatively high resistance of silicon, but it simplifies the wiring. Similarly, the ground metal connects the NMOS transistor's source to the well that surrounds the transistor, P-type silicon that appears green. Since the well is grounded, the transistor has its ground connection.
An inverter on the die.
Some inverters look different from the layout above. Many of the chip's inverters are constructed as two inverters in parallel to provide twice the output current. This gives the inverter more "fan-out", the ability to drive the inputs of a larger number of gates.8 The diagram below shows a doubled inverter, which is essentially the previous inverter mirrored and copied, with two PMOS transistors at the top and two NMOS transistors at the bottom. Note that there is no explicit boundary between the paired transistors; their drains share the same silicon. Consequently, each output contact is shared between two transistors, rather than being duplicated.
An inverter consisting of two inverters in parallel.
Another style of inverter drives the chip's output pins. The output pins require high current to drive external circuitry. The chip uses much larger transistors to provide this current. Nonetheless, the output driver uses the same inverter circuit described earlier, with a PMOS transistor to put the output high and an NMOS transistor to pull the output low. The photo below shows one of these output inverters on the die. To fit the larger transistors into the available space, the transistors have a serpentine layout, with the gate winding between the source and the drain. The inverter's output is connected to a bond pad. When the die is mounted in a package, tiny bond wires connect the pads to the external pins.
An output driver is an inverter, built with much larger transistors.
NOR and NAND gates
Other logic gates are constructed using the same concepts as the inverter, but with additional transistors. In a NOR gate, the PMOS transistors on top are in series, so the output will be pulled high if all inputs are 0. The NMOS transistors on the bottom are in parallel, so the output will be pulled low if any input is 1. Thus, the circuit implements the NOR function. Again, note the complementary action: the PMOS transistors pull the output high, while the NMOS transistors pull the output low. Moreover, the PMOS transistors are in series, while the NMOS transistors are in parallel. The circuit below is a 3-input NOR gate; different numbers of inputs are supported similarly. (With just one input, the circuit becomes an inverter, as you might expect.)
A 3-input NOR gate implemented in CMOS.
For any gate implementation, the input must be either pulled high by the PMOS side, or pulled low by the NMOS side. If both happen simultaneously for some input, power and ground would be shorted, possibly destroying the chip. If neither happens, the output would be floating, which is bad in a CMOS circuit.9 In the NOR gate above, you can see that for any input the output is always pulled either high or low as required. Reverse engineering tip: if the output is not always pulled high or low, you probably made a mistake in either the PMOS circuit or the NMOS circuit.10
The diagram below shows how a 3-input NOR gate appears on the die.11 The transistor gates are the thick vertical metal rectangles; PMOS transistors are on top and NMOS below. The three PMOS transistors are in series between power on the left and the output connection on the right. As with the inverter, the power and ground connections are wired to the bulk silicon, not to the chip's power and ground lines.
A 3-input NOR gate as it is implemented on the die. The "extra" PMOS transistor on the left is part of a different gate.
The layout of the NMOS transistors is more complicated because it is difficult to wire the transistors in parallel with just one layer of metal. The output wire connects between the first and second transistors as well as to the third transistor. An unusual feature is the connection of the second and third NMOS transistors to ground is done by a horizontal line of doped silicon (reddish "silicon path" indicated by the dotted line). This silicon extends from the ground metal to the region between the two transistors. Finally, note that the PMOS transistors are much larger than the NMOS transistors. This is both because PMOS transistors are inherently less efficient and because transistors in series need to be lower resistance to avoid degrading the output signal. Reverse-engineering tip: It's often easier to recognize the transistors in series and then use that information to determine which transistors must be in parallel.
A NAND gate is implemented by swapping the roles of the series and parallel transistors. That is, the PMOS transistors are in parallel, while the NMOS transistors are in series. For example, the schematic below shows a 4-input NAND gate. If all inputs are 1, the NMOS transistors will pull the output low. If any input is a 0, the corresponding PMOS transistor will pull the output high. Thus, the circuit implements the NAND function.
A 4-input NAND gate implemented in CMOS.
The diagram below shows a four-input NAND gate on the die. In the bottom half, four NMOS transistors are in series, while in the top half, four PMOS transistors are in parallel. (Note that the series and parallel transistors are switched compared to the NOR gate.) As in the NOR gate, the power and ground are provided by metal connections to the bulk silicon (two connections for the power). The parallel PMOS circuit uses a "silicon path" (green) to connect each transistor to the output without intersecting the metal. In the middle, this silicon has a vertical metal line on top; this reduces the resistance of the silicon path. The NMOS transistors are larger than the PMOS transistors in this case because the NMOS transistors are in series.
A four-input NAND gate as it appears on the die.
Complex gates
More complex gates such as AND-NOR (AND-OR-INVERT) can also be constructed in CMOS; these gates are commonly used because they are no harder to build than NAND or NOR gates. The schematic below shows an AND-NOR gate. To understand its construction, look at the paths to ground through the NMOS transistors. The first path is through A, B, and C. If these inputs are all high, the output is low, implementing the AND-INVERT side of the gate. The second path is through D, which will pull the output low by itself, implementing the OR-INVERT side of the gate. You can verify that the PMOS transistors pull the output high in the necessary circumstances. Observe that the D transistor is in series on the PMOS side and in parallel on the NMOS side, again showing the complementary nature of these circuits.
An AND-NOR gate.
An AND-NOR gate.
The diagram below shows this AND-NOR gate on the die, with the four inputs A, B, C, and D, corresponding to the schematic above. This gate has a few tricky layout features. The biggest surprise is that there is half of another gate (a 3-input NOR gate) in the middle of this gate. Presumably, the designers found this arrangement efficient since the other gate also uses inputs A, B, and C. The output of the other gate (D) is an input to the gate we're examining. Ignoring the other gate, the AND-NOR gate has the NMOS transistors in the first column, on top of a reddish band, and the PMOS transistors in the third column, on top of a greenish band. Hopefully you can recognize the transistor gates, the large rectangles connected to A, B, C, and D. Matching the schematic above, there are three NMOS transistors in series on the left, connected to A, B, and C, as well as the D transistor providing a second path between ground and the output. On the PMOS side, the A, B, and C transistors are in parallel, and then connected through the D transistor to the output. The green "silicon path" on the right provides the parallel connection from transistors A and B to transistors C and D. Most of this path is covered by two long metal regions, reducing the resistance. But in order to cross under wires B and C, the metal has a break where the green silicon provides the connection.
An AND-NOR gate on the die.
As with the other gates, the power is obtained by a connection to the bulk silicon, bridging the red and green regions. If you look closely, there is a green band ("silicon path") down from the power connection and joining the main green region between the B and C transistors, providing power to those transistors through the silicon. The NMOS transistors, on the other hand, have ground connections at the top and bottom. For this circuit, ground is supplied through solid metal wires at the top and the bottom, rather than a connection to the bulk silicon.
A few principles help when reverse-engineering logic gates. First, because of the complementary nature of CMOS, the output must either be pulled high by the PMOS transistors or pulled low by the NMOS transistors. Thus, one group or the other must be activated for each possible input. This implies that the same inputs must go to both the NMOS and PMOS transistors. Moreover, the structures of the NMOS and PMOS circuits are complementary: where the NMOS transistors are parallel, the PMOS transistors must be in series, and vice versa. In the case of the AND-NOR circuit above, these principles are helpful. For instance, you might not spot the "silicon paths", but since the PMOS half must be complementary to the NMOS half, you know that those connections must exist.
Even complex gates can be reverse-engineered by breaking the NMOS transistors into series and parallel groups, corresponding to AND and OR terms. Note that MOS transistors are inherently inverting, so a single gate will always end with inversion. Thus, you can build an AND-OR-AND-NOR gate for instance, but you can't build an AND gate as a single circuit.
Transmission gate
Another key circuit is the transmission gate. This acts as a switch, either passing a signal through or blocking it. The schematic below shows how a transmission gate is constructed from two transistors, an NMOS transistor and a PMOS transistor. If the enable line is high (i.e. low to the PMOS transistor) both transistors turn on, passing the input signal to the output. The NMOS transistor primarily passes a low signal, while the PMOS transistor passes a high signal, so they work together. If the enable line is low, both transistors turn off, blocking the input signal. The schematic symbol for a transmission gate is shown on the right. Note that the transmission gate is bidirectional; it doesn't have a specific input and output. Examining the surrounding circuitry usually reveals which side is the input and which side is the output.
A transmission gate is constructed from two transistors. The transistors and their gates are indicated. The schematic symbol is on the right.
The photo below shows how a transmission gate appears on the die. It consists of a PMOS transistor at the top and an NMOS transistor at the bottom. Both the enable signal and the complemented enable signal are used, one for the NMOS transistor's gate and one for the PMOS transistor.
A transmission gate on the die, consisting of two transistors.
The inverter and transmission gate are both two-transistor circuits, but they can be easily distinguished for reverse engineering. One difference is that an inverter is connected to power and ground, while the transmission gate is unpowered. Moreover, the inverter has one input, while the transmission gate has three inputs (counting the control lines). In the inverter, both transistor gates have the same input, so one transistor turns on at a time. In the transmission gate, however, the gates have opposite inputs, so the transistors turn on or off together.
One useful circuit that can be built from transmission gates is the multiplexer, a circuit that selects one of two (or more) inputs. The multiplexer below selects either input inA or inB and connects it to the output, depending if the selection line selA is high or low respectively. The multiplexer can be built from two transmission gates as shown. Note that the select lines are flipped on the second transmission gate, so one transmission gate will be activated at a time. Multiplexers with more inputs can be built by using more transmission gates with additional select lines.
Schematic symbol for a multiplexer and its implementation with two transmission gates.
The die photo below shows a block of transmission gates consisting of six PMOS transistors and six NMOS transistors. The labels on the metal lines will make more sense as the reverse engineering progresses. Note that the metal layer provides much of the wiring for the circuit, but not all of it. Much of the wiring is implicit, in the sense that neighboring transistors are connected because the source of one transistor overlaps the drain of another.
A block of transistors implementing multiple transmission gates.
While this may look like an incomprehensible block of zig-zagging lines, tracing out the transistors will reveal the circuitry (below). The wiring in the schematic matches the physical layout on the die, so the schematic is a bit of a mess. With a single layer of metal for wiring, the layout becomes a bit convoluted to avoid crossing wires. (The only wire crossing in this image is in the upper left for wire X; the signal uses a short stretch of silicon to pass under the metal.)
Schematic of the previous block of transistors.
Looking at the PMOS and NMOS transistors as pairs reveals that the circuit above is a chain of transmission gates (shown below). It's not immediately obvious which wires are inputs and which wires are outputs, but it's a good guess that pairs of transmission gates using the opposite control lines form a multiplexer. That is, inputs A and C are multiplexed to output B, inputs C and E are multiplexed to output D, and so forth. As will be seen, these transmission gates form multiplexers that are part of a flip-flop.
The transistors form six transmission gates.
Latches and flip-flops
Flip-flops and latches are important circuits, able to hold one bit and controlled by a clock signal. Terminology is inconsistent, but I'll use flip-flop to refer to an edge-triggered device and latch to refer to a level-triggered device. That is, a flip-flop will grab its input at the moment the clock signal goes high (i.e. it uses the clock edge), store it, and provide it as the output, called Q for historical reasons. A latch, on the other hand, will take its input, store it, and output it as long as the clock is high (i.e. it uses the clock level). The latch is considered "transparent", since the input immediately appears on the output if the clock is high.
The distinction between latches and flip-flops may seem pedantic, but it is important. Flip-flops will predictably update once per clock cycle, while latches will keep updating as long as the clock is high. By connecting the output of a flip-flop through an inverter back to the input, you can create a toggle flip-flop, which will flip its state once per clock cycle, dividing the clock by two. (This example will be important shortly.) If you try the same thing with a transparent latch, it will oscillate: as soon as the output flips, it will feed back to the latch input and flip again.
The schematic below shows how a latch can be implemented with transmission gates. When the clock is high, the first transmission gate passes the input through to the inverters and the output. When the clock is low, the second transmission gate creates a feedback loop for the inverters, so they hold their value, providing the latch action. Below, the same circuit is drawn with a multiplexer, which may be easier to understand: either the input or the feedback is selected for the inverters.
A latch implemented from transmission gates. Below, the same circuit is shown with a multiplexer.
An edge-triggered flip-flop can be created by combining two latches in a primary/secondary arrangement. When the clock is low, the input will pass into the primary latch. When the clock switches high, two things happen. The primary latch will hold the current value of the input. Meanwhile, the secondary latch will start passing its input (the value from the primary latch) to its output, and thus the flip-flop output. The effect is that the flip-flop's output will be the value at the moment the clock goes high, and the flip-flop is insensitive to changes at other times. (The primary latch's value can keep changing while the clock is low, but this doesn't affect the flip-flop's output.)
Two latches, combined to form a flip-flop.
The flip-flops in the counter chip are based on the above design, but they have two additional features. First, the flip-flop can be loaded with a value under the control of a Preset Enable (PE) signal. Second, the flip-flop can either hold its current value or toggle its value, under the control of a Toggle (T) signal. Implementing these features requires two more multiplexers in the primary latch as shown below. The first multiplexer selects either the inverted output or uninverted output to be fed back into the flip flop, providing the selectable toggle action. The second multiplexer is the latch's standard clocked multiplexer. The third multiplexer allows a "preset" value to be loaded directly into the flip-flop, bypassing the clock. (The preset value is inverted, since there are three inverters between the preset and the output.) The secondary latch is the same as before, except it provides the inverted and non-inverted outputs as feedback, allowing the flip-flop to either hold or toggle its value. This circuit illustrates how more complex flip-flops can be created from the building blocks that we've seen.
Schematic of the toggle flip-flop.
The gray letters in the schematic above match the earlier multiplexer diagram, showing how the three multiplexers were implemented on the die. The other multiplexer and the inverters are implemented in another block of circuitry. I won't explain that circuitry in detail since it doesn't illustrate any new principles.
Routing in silicon: cross-unders
With just one metal layer for wiring, routing of signals on the chip is difficult and requires careful planning. Even so, there are some cases where one signal must cross another. This is accomplished by using silicon for a "cross-under", allowing a signal to pass underneath metal wiring. These cross-unders are avoided unless necessary because silicon has much higher resistance than metal. Moreover, the cross-under requires additional space on the die.
Three cross-unders on the die.
The images above show three cross-unders. In each one, signals are primarily routed in the metal layer, but a signal passes under the metal using a doped silicon region (which appears green). The first cross-under simply lets one signal cross under the second. The second image shows a signal branching as well as crossing under two signals. The third image shows a cross-under distributing a horizontal signal to the upper and lower halves of the chip, while crossing under multiple horizontal signals. Note the small oval contact between the green silicon region and the horizontal metal line, connecting them. It is easy to miss the small contact and think that the vertical signal is simply crossing under the horizontal signal, rather than branching.
About the chip
The focus of this article is the CMOS reverse engineering process rather than this specific chip, but I'll give a bit of information about the chip. The die has the Cyrillic characters ИЕ11 at the top indicating that the chip is a К561ИЕ11 or К564ИЕ11.12 The Soviet Union came up with a standardized numbering system for integrated circuits in 1968. This system is much more helpful than the American system of semi-random part numbers. In this part number, the 5 indicates a monolithic integrated circuit, while 61 or 64 is the series, specifically commercial-grade or military-grade clones of 4000 series CMOS logic. The character И indicates a digital circuit, while ИЕ is a counter. Thus, the part number systematically indicates that the integrated circuit is a CMOS counter.
The 561ИЕ11 turns out to be a copy of the Motorola MC14516 binary up/down counter.13 Conveniently, the Motorola datasheet provides a schematic (below). I won't explain the schematic in detail, but a quick overview may be helpful. The chip is a four-bit counter that can count up or down, and the heart of the chip is the four toggle flip-flops (red). To count up, a flip-flop is toggled if there is a carry from the lower bits, while counting down toggles a flip-flop if there is a borrow from the lower bits. (Much like base-10 long addition or subtraction.) The AND/NOR gates at the bottom (blue) look complex, but they are just generating the toggle signal T: toggle if the lower bits are all-1's and you're counting up, or if the lower bits are all-0's and you're counting down. The flip-flops can also be loaded in parallel from the P inputs. Additional logic allows the chips to be cascaded to form arbitrarily large counters; the carry-out pin of one chip is connected to the carry-in of the next.
Logic diagram of the MC14516 up/down counter chip, from the datasheet.
I've labeled the die photo below with the pin functions and the functional blocks. Each quadrant of the chip handles one bit of the counter in a roughly symmetrical way. This quadrant layout accounts for the pin arrangement which otherwise appears semi-random with bits 3 and 0 on one side and bits 2 and 1 on the other, with inputs and output pins jumbled together. The toggle and carry logic is squeezed into the top and middle of the chip. You may recognize the large inverters next to each output pin. When reverse-engineering, look for large transistors next to pads to determine which pins are outputs.
The die with pins and functional blocks labeled.
This article has discussed the basic circuits that can be found in a CMOS chip. Although the counter chip is old and simple, later chips use the same principles. An important change in later chips is the introduction of silicon-gate transistors, which use polysilicon for the transistor gates and for an additional wiring layer. The circuits are the same, but you need to be able to recognize the polysilicon layer. Many chips have more than one metal layer, which makes it very hard to figure out the wiring connections. Finally, when the feature size approaches the wavelength of light, optical microscopes break down. Thus, these reverse-engineering techniques are only practical up to a point. Nonetheless, many interesting CMOS chips can be studied and reverse-engineered.
For more, follow me on Twitter @kenshirriff or RSS for updates. I'm also on Mastodon as @[email protected]. Thanks to Martin Evtimov for providing the die photos.
  1. I'm not sure of the date and manufacturing location of the chip. I think the design is old, from the Soviet Union. (Motorola introduced the MC14516 around 1972 but I don't know when it was copied.) The wafer is said to be scrap from a Ukrainian manufacturer so it may have been manufactured more recently. The die has a symbol that might be a manufacturing logo, but nobody on Twitter could identify it.
    A symbol that appears on the die.
  2. For more about this chip, the Russian databook can be downloaded here; see Volume 5 page 501. ↩
  3. Early CMOS microprocessors include the 8-bit RCA 1802 COSMAC (1974) and the 12-bit Intersil 6100 (1974). The 1802 is said to be the first CMOS microprocessor. Mainstream microprocessors didn't switch to CMOS until the mid-1980s. ↩
  4. The chip in this article has metal-gate transistors, with aluminum forming the transistor gate. These transistors were not as advanced as the silicon-gate transistors that were developed in the late 1960s. Silicon gate technology was much better in several ways. First, silicon-gate transistors were smaller, faster, more reliable, and used lower voltages. Second, silicon-gate chips have a layer of polysilicon wiring in addition to the metal wiring; this made chip layouts about twice as dense. ↩
  5. To produce N-type silicon, the silicon is doped with small amounts of an element such as phosphorus or arsenic. In the periodic table, these elements are one column to the right of silicon so they have one "extra" electron. The free electrons move through the silicon, carrying charge. Because electrons are negative, this type of silicon is called N-type. Conversely, to produce P-type silicon, the silicon is doped with small quantities of an element such as boron. Since boron is one column to the left of silicon in the periodic table, it has one fewer free electrons. A strange thing about semiconductor physics is that the missing electrons (called holes) can move around the silicon much like electrons, but carrying positive charge. Since the charge carriers are positive, this type of silicon is called P-type. For various reasons, electrons carry charge better than holes, so NMOS transistors work better than PMOS transistors. As a result, PMOS transistors need to be about twice the size of comparable NMOS transistors. This quirk is useful for reverse engineering, since it can help distinguish NMOS and PMOS transistors.
    The amount of doping required can be absurdly small, 20 atoms of boron for every billion atoms of silicon in some cases. A typical doping level for N-type silicon is 1015 atoms of phosphorus or arsenic per cubic centimeter, which sounds like a lot until you realize that pure silicon consists of 5×1022 atoms per cubic centimeter. A heavily doped P+ region might have 1020 dopant atoms per cubic centimeter, one atom of boron per 500 atoms of silicon. (Doping levels are described here.) ↩
  7. The bulk silicon voltage makes the boundary between a transistor and the bulk silicon act as a reverse-biased diode, so current can't flow across the boundary. Specifically, for a PMOS transistor, the N-silicon substrate is connected to the positive supply. For an NMOS transistor, the P-silicon well is connected to ground. A P-N junction acts as a diode, with current flowing from P to N. But the substrate voltages put P at ground and N at +5, blocking any current flow. The result is that the bulk silicon can be considered an insulator, with current restricted to the N+ and P+ doped regions. If this back bias gets reversed, for example, due to power supply fluctuations, current can flow through the substrate. This can result in "latch-up", a situation where the N and P regions act as parasitic NPN and PNP transistors that latch into the "on" state. This shorts power and ground and can destroy the chip. The point is that the substrate voltages are very important for proper operation of the chip. ↩
  8. Many inverters in this chip duplicate the transistors to increase the current output. The same effect could be achieved with single transistors with twice the gate width. (That is, twice the height in the diagrams.) Because these transistors are arranged in uniform rows, doubling the transistor height would mess up the layout, so using more transistors instead of changing the size makes sense. ↩
  9. Some chips use dynamic logic, in which case it is okay to leave the gate floating, neither pulled high nor low. Since the gate resistance is extremely high, the capacitance of a gate will hold its value (0 or 1) for a short time. After a few milliseconds, the charge will leak away, so dynamic logic must constantly refresh its signals before they decay.
    In general, the reason you don't want an intermediate voltage as the input to a CMOS circuit is that the voltage might end up turning the PMOS transistor partially on while also turning the NMOS transistor partially on. The result is high current flow from power to ground through the transistors. ↩
  10. One of the complicated logic gates on the die didn't match the implementation I expected. In particular, for some inputs, the output is neither pulled high nor low. Tracing the source of these inputs reveals what is going on: the gate takes both a signal and its complement as inputs. Thus, some of the "theoretical" inputs are not possible; these can't be both high or both low. The logic gate is optimized to ignore these cases, making the implementation simpler. ↩
  11. This schematic explains the physical layout of the 3-input NOR gate on the die, in case the wiring isn't clear. Note that the PMOS transistors are wired in series and the NMOS transistors are in parallel, even though both types are physically arranged in rows.
    The 3-input NOR gate on the die. This schematic matches the physical layout.
  12. The commercial-grade chips and military-grade chips presumably use the same die, but are distinguished by the level of testing. So we can't categorize the die as 561-series or 564-series. ↩
  13. Motorola introduced the MC14500 series in 1971 to fill holes in the CD4000 series. For more about this series, see A Strong Commitment to Complementary MOS. ↩
