Microcode inside the Intel 8087 floating-point chip: register exchange
In 1980, Intel introduced the 8087 floating-point chip, a co-processor that made floating-point operations up to 100 times faster. This chip was highly influential, and today most processors use the floating-point standard introduced by the 8087.
The 8087 uses complicated algorithms to accurately compute functions such as square roots, tangents, and exponentials. These algorithms are implemented inside the chip in low-level code called microcode. I'm part of a group, the Opcode Collective, that is reverse-engineering this microcode. In this post, I take a close look at the microcode for one of the 8087's instructions—FXCH—and explain how the microcode works. The FXCH (Floating-point Exchange) instruction exchanges two floating-point registers. You might expect this instruction to be trivial, but there's more going on than you might expect; the microcode uses 14 micro-instructions to implement the exchange instruction.
The Intel 8087 chip is packaged in a 40-pin DIP (dual in-line package).
To explore the microcode, I opened up an 8087 chip and created a high-resolution image with a microscope. The large microcode ROM occupies a central position, holding the micro-instructions that control the chip. The microcode engine on the left steps through the microcode, handling jumps and subroutine calls. The bottom half of the chip is the "datapath", the circuitry that performs floating-point calculations; it is split into a 16-bit datapath for the number's exponent and a 64-bit datapath for the number's fractional part (also known as the significand).
Die of the Intel 8087 floating-point unit chip, with main functional blocks labeled. The die is 5mm×6mm.  Click for a larger image.
This post focuses on the temporary registers and stack registers that are highlighted in red. The chip has two temporary registers and eight stack registers, each holding a number's exponent and fraction. Each register also has two tag bits that label the type of value in the register. The stack control circuitry at the right manages the stack, keeping track of the top-of-stack position as values are pushed onto the stack or popped off the stack.
The 8087's microcode
Executing an 8087 instruction such as arctan requires hundreds of internal steps to compute the result. These steps are implemented in microcode with micro-instructions specifying each step of the algorithm. (Keep in mind the two levels of instructions: the assembly language instructions used by a programmer and the undocumented low-level micro-instructions inside the chip.) The microcode ROM holds 1648 micro-instructions, implementing the 8087's instruction set. Each micro-instruction is 16 bits long and performs a simple operation such as moving data inside the chip, adding two values, or shifting data. I'm working with the Opcode Collective to reverse-engineer the micro-instructions and fully understand the microcode (link).
The 8087's micro-instructions are complicated, with many corner cases and ad hoc functions, but I'll provide a simplified overview. Each micro-instruction consists of 16 bits, as shown below. The first three bits specify the type of the micro-instruction, which controls the meaning of the remaining bits. The first type indicates a transfer operation, transferring data from one internal register to another. The two fields specify the source and destination for the data. The three unspecified bits are used for various special cases. Next is a shift operation, which uses the barrel shifter to shift a value left or right. The third type of micro-instruction uses the adder/subtractor. It can also be used in a loop for multiplication or division. Fourth are various arithmetic control micro-instructions that configure the adder, set rounding modes, and so forth. The far jump and far call micro-instructions perform a jump or subroutine call to a target micro-address in a fixed list. The condition field allows conditional jumps/calls based on numerous conditions, while the last bit inverts the condition. A local jump allows a conditional jump to a nearby micro-instruction. Finally, the miscellaneous micro-instructions range from returning from a subroutine or raising an exception to ending the microcode execution.
Structure of an 8087 micro-instruction.
How values are stored inside the 8087 chip
The 8087 supports a variety of data types: floating-point numbers of various sizes, integers, and binary-coded decimal. But internally, everything is stored as an 80-bit floating-point number. A number has three parts: a 64-bit significand (the fractional part), a 15-bit exponent, and a sign bit. The chip has two separate data paths: one for the significand, and one for the exponent and sign.
The chip has eight registers to store numbers during calculations, the top registers in the diagram below. However, the registers are organized in an unusual way: as a stack, with numbers pushed to the stack and popped from the stack. Instead of accessing, say, register #3, you might access the third register from the top of the stack, denoted ST(3); as values are pushed or popped, ST(3) changes. The stack-based architecture was intended to improve the instruction set, simplify compiler design, and make function calls more efficient, although it didn't work as well as hoped.
The register set of the 8087, as seen by the programmer. From 8086 Family Numerics Supplement.
Many 8087 instructions act on the top of the stack. For instance, the square root instruction replaces the value on the top of the stack with its square root. But what if you want to take the square root of a value in the middle of the stack? The solution is the FXCH instruction, the focus of this article. This instruction exchanges the value on the top of the stack with a specified stack position, providing access to values inside the stack.
One more feature of the 8087 is important to this discussion: each value in the register stack has an associated "tag" value, labeling it as valid, special, zero, or empty. A "normal" floating-point value is tagged as valid. If the floating-point value is infinity, Not a Number, or a denormalized value, then it is tagged as special. A zero value is tagged as zero. Finally, if a register is empty (e.g., its value has been popped off the stack), the register is tagged as empty. The 8087 uses tags to optimize performance and detect errors.1 For instance, if a programmer pops too many values from the stack and tries to read a stack register that is tagged empty, the 8087 raises an "invalid operation" exception.
The eight stack registers are visible to the programmer, but the 8087 also has temporary registers that it uses internally. Two of these temporary registers are important for this article: tmpA and tmpB. Like the stack registers, each temporary register is an 80-bit register, along with two tag bits.
The FXCH microcode
In this section, I'll explain how the microcode for the FXCH exchange instruction works. This instruction exchanges the top-of-stack register with the register at a specified position in the stack. If either register is empty, the instruction will raise an "invalid operation" exception and replace the missing value(s) with the special value "Not a Number" (NaN).
The microcode for the instruction is below, consisting of 14 micro-instructions.2 The first micro-instruction is a transfer, where the source is the top of stack value ST(0) and the destination is the temporary A register. The source specification causes the 64 significand to be placed on the fraction bus, the 16-bit exponent and sign to be placed on the exponent bus, and the two tag bits to be sent to the tag circuitry. The destination tmpA causes the bus values to be stored into the temporary register. Thus, the bits in the micro-instruction cause the desired transfer to take place. The third micro-instruction is similar, but uses a register inside the stack, ST(i), with the index specified in the machine instruction.
FXCH entry point:
#0200 ST(0) -> tmpA           read top of stack
#0201 nop                     Wait a cycle
#0202 ST(i) -> tmpB           Read specified stack register
#0203 if !(tmpA or tmpB empty) jmp #0210 Jump if both registers exist
#0204 set invalid exception   Raise an invalid exception
#0205 if (unmasked) jmp #0213 If interrupt, end
#0206 if !(tmpA empty) jmp #0208 Check if tmpA is empty
#0207 NaN -> tmpA             If so, move NaN to tmpA
#0208 if !(tmpB empty) jmp #0210 Check if tmpB is empty
#0209 NaN -> tmpB             If so, move NaN to tmpB
The happy path and error path continue here:
#0210 tmpB -> ST(0)           Save tmpB to the top of stack
#0211 nop                     Wait a cycle
#0212 tmpA -> ST(i)           Save tmpA to the specified stack register
#0213 RNI                     End of routine: Run Next Instruction
#0214 nop                     Unused
#0215 nop                     Unused
#0216 nop                     Unused
Next, the relative jump at micro-address #0203 illustrates a different type of micro-instruction: the conditional jump. The micro-instruction specifies a condition, in this case, testing if either temporary register is empty. (That is, the hardware tests the tag bits associated with the temporary registers to see if either is the "empty" tag.) The micro-instruction has a bit set to invert the condition. Finally, the micro-instruction has an offset of +6, yielding the jump target #0210. The advantage of a relative offset over specifying a full micro-address is that the offset only requires six bits. (For more information on how conditions are evaluated, see my article Conditions in the Intel 8087 floating-point chip's microcode.)
If either register is empty, the next micro-instruction raises an "invalid" exception. As I'll explain in the next section, you can program the 8087 to either generate an interrupt on an exception or continue processing. The next instruction is a conditional jump that tests if the exception was "unmasked", indicating that an interrupt was generated. In this case, the microcode ends while the main 8086 processor handles the interrupt.
Assuming the interrupt was masked, the microcode now replaces empty values with the special Not a Number value, first checking tmpA and then tmpB. The source NaN causes circuitry to pull the exponent bus to all 1's and the fraction bus to all 0's, except for the top two bits. This particular bit pattern represents Not a Number.3
At micro-address #0210, the empty-register path and the normal path join up to store the temporary registers in the stack registers. This is where the actual exchange operation happens, since tmpA and tmpB are written to the opposite stack positions from where they were read. Finally, RNI (Run Next Instruction) indicates the end of the microcode routine. This stops the microcode engine and gets the 8087 ready for the next instruction.
The nop (no-operation) microcode instructions are interesting. Each pair of stack reads or writes has a nop in the middle, probably due to timing constraints on the registers. The end of the microcode routine has three nop instructions before the next microcode routine starts. These instructions appear to be wasted space in the microcode; maybe the FXCH microcode was shortened by three words during development, causing this gap.
Exceptions
The 8087 has a complicated exception system to handle a variety of problems. Exceptions fall into six categories: invalid operation, denormalized operation, zero divide, overflow, underflow, or precision. An invalid operation occurs, for instance, if you take the square root of a negative number or try to perform an operation on an empty register. An overflow exception occurs if a value is too large to be represented, while an underflow exception occurs if a value is too small. A zero divide exception happens if you divide by zero.4 A precision exception occurs if a number cannot be exactly represented as a floating-point number (which is extremely common). Finally, a denormalized exception occurs if a value is too close to zero to be represented with full accuracy.
What happens if an exception occurs? The 8087 allows the programmer to select exception behavior for each exception type. The first option is for an exception to trigger a CPU interrupt, so the software can handle the problem. For instance, the software could attempt to work around the problem, log an error, or simply terminate the program. Alternatively, the programmer can "mask" an exception. In this case, the 8087 continues the operation in a "reasonable" way. For instance, an overflowed value would be set to infinity, while an invalid value would be set to the special value: "Not a Number" (NaN). For a precision exception (e.g., 1/3), the value is rounded. The designers of the 8087 put a lot of effort into continuing after a masked exception in the best way; the manual has pages of details on all the special cases.5
Handling of exception conditions is split between microcode and hardware. For example, if the FXCH microcode detects an empty register, it executes a set invalid exception micro-instruction. This micro-instruction sets a latch indicating the invalid exception. The 8087's control register includes six mask bits, one for each type of exception, blocking interrupts for that exception type. The hardware combines the exception flip-flop signals with the mask bits in the control register and the exception flags in the status register to see if a new, unmasked interrupt has been triggered. If so, the 8087 circuitry sends an interrupt to the 8086 processor.
On the other hand, if the interrupt is masked, execution of the microcode continues. In the case of FXCH, the microcode replaces empty registers with the Not a Number value. Finally, the microcode routine ends with RNI (Run Next Instruction). This triggers many hardware activities, but the relevant one is copying the state of the exception flip-flops into the status register. This sets the exception bit if the programmer wants to check it. The exception flip-flops are cleared when the next 8087 instruction starts. Since the hardware manages the flip-flops, status register, control register, and interrupt line, the microcode can be simpler and smaller.
Extracting the microcode
The 8087's microcode ROM contains 26,368 bits, specifying 1648 16-bit micro-instructions. At the time, this was a very large ROM; in order to fit it on the die, Intel used a special type of ROM that held two bits per transistor, twice the capacity of a standard ROM. This ROM is semi-analog, using four sizes of transistors to produce four voltage levels. Comparators convert the voltage level to a pair of bits.
A close-up of the 8087's microcode ROM, showing 77 transistors. A transistor is formed where a vertical polysilicon line crosses a horizontal stripe of doped silicon.
To extract the microcode, I took high-resolution images of the ROM after dissolving the metal layer. Gloriouscow used a neural network to categorize the size of each transistor. (You can explore the full image and transistors here.) The next step was determining how to map the transistors to bits. You might expect that the grid of transistors corresponds to the grid of microcode bits. But due to various hardware optimizations, rows and columns are shuffled and mirrored, which I sorted out by studying the circuitry. The result was the microcode, expressed as a table of 0's and 1's.
The next step was assigning meaning to the microcode. For the 8086 processor, the patent provided a lot of detail on the structure of the microcode and the hardware, but the 8087 patent didn't explain the microcode. Instead, we figured out the micro-instructions through a combination of examining the circuitry, looking for patterns in the microcode, and thinking about how instructions might be implemented.
Microcode is usually complicated, and the 8087 is worse than most. The 8087 was on the edge of what was possible at the time, so the designers resorted to special cases and hacks where necessary. For instance, some conditional jumps have side effects such as updating registers. Other instructions set flip-flops that change the behavior of later operations. We're still working to completely understand the micro-instructions at the hardware level.
I plan to continue reverse-engineering the 8087 microcode; for updates, follow me on Bluesky (@righto.com), Mastodon (@[email protected]), or RSS. I've been working on this with the members of the "Opcode Collective", especially Smartest Blob and Gloriouscow, who converted the ROM images to microcode data and extensively analyzed the contents. See the 8087 repository on GitHub for more.
AI statement: Despite the presence of the em dash, no AI was used in the writing of this article (details).
  1. Tags are normally invisible to the programmer, but can be accessed through special operations. A programmer can access the 8087 tags by dumping the 8087's state to memory; the tags are stored in a 16-bit "tag word". ↩
  2. The raw 8087 microcode is available here, decoded by Smartest Blob. I've modified the microcode format for clarity. ↩
  3. The 8087 indicates a bad value with a special "Not a Number" (NaN) value. The system allows many different representations of NaN: any value with an exponent of all 1's, a nonzero significand (a zero significand indicates negative infinity), and either sign. For an invalid operation, the 8087 uses one particular NaN value, called real indefinite. For an internal 80-bit real number, this value has the top two bits of the significand set internally, and the rest zero, while the exponent bits and sign are all set. (See pages 87 (S-73) and 90 (S-76).) A 32-bit or 64-bit real uses a slightly different bit pattern for NaN; these number formats have an implied "1" bit for the significand, so only one bit of the significand is explicitly set for the real indefinite NaN. ↩
  4. Dividing by zero usually causes a zero divide exception, but 0 ÷ 0 causes an invalid operation exception, while infinity ÷ 0 is valid, yielding infinity. Just one reason why the microcode is so complicated. ↩
  5. For more information on the 8087's exceptions, see 8086 Family Numerics Supplement. The exception system is described on page 32 (S-18). The exception flags and exception masks are described on page 24 (S-10). The details of exception handling are described on page 89 (S-75). ↩
Reverse engineering circuitry in a Spacelab computer from 1980
Spacelab was a reusable laboratory that could be carried in the cargo bay of the Space Shuttle, providing lab space for astronauts and experiments. Spacelab was controlled by a French-built minicomputer, called the Mitra 125 MS. Unlike modern computers, this computer didn't contain a microprocessor chip. Instead, its 16-bit processor was constructed from several boards of chips. In this article, I reverse-engineer one of the processor boards, shown below, part of the computer's Arithmetic/Logic Unit (ALU).
The Mitra 125 MS computer, built by CIMSA, with one of the ALU/register cards shown.
Spacelab consisted of a pressurized cylindrical laboratory that held experiments, computers, and work areas for researchers. A tunnel connected the laboratory to the Shuttle, allowing researchers to move between the Shuttle and Spacelab. Spacelab also supported up to five unpressurized "pallets" that were exposed to space, holding experiments such as telescopes and sensors. The illustration below shows the tunnel, the Spacelab laboratory, and a pallet installed in the Shuttle's cargo bay.1
Illustration of the Spacelab-3 mission. From NASA.
Because Spacelab was a European project, it used a European computer, the Mitra 125 MS. The Mitra line started in 1971 when a French company called CII introduced the Mitra 15 minicomputer, a 16-bit computer that used magnetic core memory. Mitra is a French acronym2 that translates as "Mini-machine for Real-Time and Automatic Computing." As the name suggests, Mitra was both small and designed for real-time computing, making it suitable for controlling experiments. The Mitra 15 was a popular computer, with almost 8000 units sold.
In 1975, CII produced a successor called the Mitra 125. The Mitra 125 improved on the Mitra 15 by adding memory management, I/O processors, higher performance, and additional instructions. Spacelab used the Mitra 125 MS minicomputer,3 a militarized variant of the Mitra 125 that was produced by a company called CIMSA. A Spacelab mission had three of these computers: the Subsystem Computer controlled and managed Spacelab itself, while the Experiment Computer handled the experiments. A Backup Computer could take over if either computer failed.1 These computers were part of Spacelab's Command and Data Management Subsystem, which controlled experiments and collected data.4
The three computers were normally mounted in the Spacelab laboratory underneath the Work Bench Rack (details). The computers were controlled through a keyboard and a color CRT display, called the Data Display System (DDS). The computer installation and a DDS are visible in the photo below.
This photo shows astronauts inside Spacelab (but not in space). The Spacelab computers were mounted under the Work Bench (right arrow). The Data Display System (left arrow) provided the interface to the computers. Photo is STS-51B Crew Portrait, 1984.
For some Spacelab missions, the laboratory was omitted entirely, providing more room for experiment pallets. In this case, the computers were mounted in a small pressurized cylinder called the igloo. The researchers remained in the Shuttle, controlling experiments through two Data Display Systems that were mounted in the Shuttle's rear flight deck (photo).
The 74181 ALU chip
The Spacelab computer didn't use a microprocessor chip. Instead, like most minicomputers at the time, it was built from simple integrated circuits that were combined to implement the computer's circuitry. Unlike modern CMOS integrated circuits, these chips contained bipolar transistors, which were fast, but large and power-hungry, a technology known as TTL (transistor-transistor logic). Electronics hobbyists of a certain age will recall the popular 7400 series of TTL chips. The Spacelab computer was built from the military grade of these chips, the 5400 series.
The most complex chip in the computer was probably the '181 Arithmetic/Logic Unit (ALU) chip, containing about 170 transistors. The arithmetic/logic unit is the heart of a computer, performing arithmetic operations as well as Boolean logic operations. In 1970, Texas Instruments put a complete 4-bit arithmetic/logic unit on a single chip, called the 74181. Since the chip was fast, compact, and inexpensive, it was widely used, providing the ALU in computers from the popular PDP-11 and Xerox Alto to the powerful VAX-11/780 "superminicomputer".
The 74181 provides a full set of binary logical operations, including AND, OR, XOR, and complement. For arithmetic, it includes addition, subtraction, incrementing, and decrementing.5 Inconveniently, the 74181 doesn't support shifting right. Moreover, multiplication and division were much too complicated to be included in the 74181. Instead, a processor implemented multiplication and division through repeated addition or subtraction, combined with shifting. Likewise, floating-point operations were way beyond the capability of the 74181, but a processor could use the 74181 when performing the steps of a floating-point operation.
Although the 74181 only handled four bits, multiple 74181 chips could be combined to handle larger words, such as 16 bits or 32 bits. To handle carries, the chips could be chained together, with the carry-out from one chip fed into the carry-in of the next chip. This approach was simple but slow, since the carry had to "ripple" through all the chips before the answer could be obtained. The carry process could be sped up by using a carry-lookahead chip called the 74182, which speeds up addition by computing the carries from four 74181 chips (i.e., 16 bits) in parallel.
The Mitra's ALU/register boards
The Spacelab computer used eight '181 ALU chips to implement a 32-bit adder.6 (Specifically, these chips are the 54S181, a variant of the 74181: "54" indicates that the chips handle the military temperature range, and "S" indicates that the chip is built from high-speed Schottky logic.) However, the ALU boards required numerous additional chips. Depending on the instruction, eight different inputs could be selected for the ALU. Chips called multiplexers selected the desired value, requiring 32 multiplexer chips. Three 32-bit registers provided storage for ALU inputs and outputs, requiring 24 chips. Two 54S182 carry-lookahead chips provided fast carry computation. Finally, some simple logic chips (inverters and NAND gates) tied things together.
Due to the number of chips required, the ALU/register circuitry was spread across three boards, as shown below. (I reverse-engineered the board on the right.7) The '181 chips are immediately visible as they are much larger than the other chips; they have 24 pins, compared to 14 or 16 pins for the other chips. The first board has two '181 chips, while the last two boards each have three '181 chips. The last two boards are similar, but not identical.
The three ALU/register boards from the Spacelab computer.
Click this image (or any other) for a larger version.
The three ALU/register boards from the Spacelab computer. Click this image (or any other) for a larger version.
Finding a 32-bit ALU was a surprise to me, since the computer is a 16-bit computer. The expanded ALU was probably implemented to improve performance. Multiplying two 16-bit numbers yields a 32-bit result, so a 32-bit ALU makes multiplication faster. Moreover, the computer supports 32-bit floating-point numbers, so the 32-bit ALU presumably makes floating-point operations faster.
The diagram below shows the architecture of the computer's 32-bit ALU system. In the middle is the ALU itself, operating on two 32-bit operands: A and B. At the left, multiplexers ("mux") select one of four values for A and one of four values for B. At the right, the output of the ALU can be stored in three 32-bit registers, or sent to the rest of the computer via the bus. The first two registers are shift registers, allowing the value to be shifted left or right, while the third register simply holds the value in flip-flops. The first two registers are connected by buses to the rest of the computer, while the value of the third register can only be accessed by using it for another arithmetic operation.8 I suspect that the shift registers are used for multiplication and division to shift the arguments at each step.
Block diagram of the ALU/register board.
The inputs to the multiplexers provide flexibility. For instance, you can add register 1 to a number from the bus, or add register 2 shifted to the right to register 3. (Note that this shifting is implemented by wiring the inputs to the multiplexer shifted left or right, completely separate from the shift register's shifting.) The "all 1's" input is either a zero input (with negative logic), or -1 (in two's-complement). The B input can be taken from the bus, allowing the value to come from memory or from a general-purpose register. The mix input is a jumble of signal lines, register bits, a shift register input, and a pull-up with no apparent pattern. I describe a few more mysteries in the footnote;9 presumably, the mysteries would be resolved if I reverse-engineered the whole computer.
The functions of the multiplexers, ALU chips, and registers depend on what instruction is being executed. Specifically, the computer's microcode engine generates control signals for the computer, including the ALU/register boards. Some of these control signals select which multiplexer inputs are used. Other control signals select the ALU's function. Finally, control signals select which register receives the ALU's output.
The board that I reverse engineered implements 12 of the 32 bits of the ALU and registers. The image below shows the role of each chip on the board. The three 4-bit ALU chips are indicated 2, 1, and 0. Each ALU chip has two multiplexer chips to select the four A input bits and two multiplexer chips to select the four B input bits.10 Thus, there are 12 multiplexer chips on the board. The three 12-bit registers A, B, and C are each implemented with three 4-bit chips. Three hex inverter chips and a 4-input NAND chip complete the board.11
The ALU/register board with the chips labeled.
These printed-circuit boards (PCBs) have some interesting features. In most electronics, circuit boards have holes only where they are needed, but the Spacelab boards have holes in a fixed grid pattern. (IBM used similar boards in its System/360 computers in the 1960s.12) A hole can hold an IC pin or other component. Or a hole can be used as a via, connecting PCB traces on different layers. Another interesting feature of the boards is the vertical metal bars underneath the integrated circuits. These bars carry heat away from the integrated circuits.
The PCB traces are more visible on the back of the board (below). The traces are thin enough that two traces can pass between a pair of holes. Note the yellow "bodge" wires, correcting errors on the circuit board. I assume that these errors were fixed for the computers used in flight.
Back of an ALU/register board. This is a different board from the one I reverse engineered, since I wanted to show the yellow wires.
Each board has a 96-pin connector at the bottom, which plugs into the computer's motherboard. Note the three cylindrical pins sticking out of the connector. These pins are keyed to ensure that a board can only be plugged into the correct slot. That is, each pin has a metal tab oriented in one of six directions. On the motherboard, the connectors have corresponding notches. If the tabs and the notches don't match up, the board can't be plugged in.
A close-up of the connector, showing the keying. Also note that the zig-zag pin numbering on the left changes to an irregular number on the right. Unexpectedly, pin 52 is between pins 49 and 51, for example,
The boards in the Spacelab computer are dense, tightly packing integrated circuits to minimize the size of the computer. However, the boards are considerably less dense than American aerospace computers. In particular, the Spacelab computer used the same integrated circuit packages that were used in consumer electronics: through-hole DIPs (dual in-line packages with two rows of pins). In contrast, IBM's line of 4 Pi aerospace computers used "flat-pack" integrated circuits that were considerably smaller and thinner (details). As a result, IBM's double-sided circuit boards could hold 156 integrated circuits compared to 30 on a single-sided Mitra board of roughly the same size.
A brief history of the French computer industry leading up to this computer
Bull is one of France's earliest computing companies, created in 1931. Bull initially sold punch-card equipment, competing with IBM. By the 1960s, Bull was a major computer company with products such as the transistorized Gamma 60 computer, a large-scale mainframe that was said to be the first system specifically designed for parallel and multiprogramming. Unfortunately, Bull had difficulty competing with IBM, its stock collapsed, and Bull was acquired by General Electric in 1964, forming Bull-GE. The collapse and controversial takeover were a blow to the French computer industry, and the incident was dubbed the Affaire Bull. To make things worse, GE soon canceled two of Bull's computers, focusing instead on GE's computer line.
The Affaire Bull was not only an affront to French pride, but an indication that France was largely dependent on the US for computer technology. A second incident revealed the critical military consequences of France's weakness. In the early 1960s, France was attempting to improve its nuclear strength by develop a hydrogen bomb. The mathematics of fusion is computationally intense, so France attempted to buy powerful American computers: the CDC 6600 supercomputer and the IBM 360/92.13 However, the US government blocked the export of these computers to France in an attempt to limit nuclear proliferation.
These problems led French president Charles de Gaulle to decide that France needed a strong computer industry of its own. In 1966, he developed a plan for computing (Plan Calcul)14, where the French government would reorganize the computer industry, picking companies to lead in each sector from minicomputers to semiconductors.
In the minicomputer sector, the government created a company called CII by combining three French computer companies: SEA, CAE, and SETI. CII was primarily owned by a large French company called Thomson-CSF (now Thales).15 CII played a key role in the Spacelab computer, since CII developed the Mitra line of computers. In the mid-1970s, CII and the American company Honeywell merged, with the computer division spun off to form a new company called SEMS, with majority shareholder Thomson. Another Thomson subsidiary, CIMSA, focused on military electronics and produced the militarized versions of the Mitra line. In particular, CIMSA produced the computer for Spacelab.16
France's Plan Calcul is generally viewed as a failure. Despite expensive subsidies, the French computer industry remained weak and unable to escape American dominance. When Giscard d'Estaing was elected president of France in 1974, he ended Plan Calcul. There are various interpretations, such as the failure of government planning versus the free market, but my view is that in the 1960s and 1970s, IBM crushed most challengers in the computer industry, both American and foreign, so Plan Calcul didn't have a chance. As for Bull, the company went through a dizzying sequence of American takeovers and nationaizations by France.17 Just two months ago (March 2026), the company was reacquired by the French government.
Replacement by the IBM AP-101SL computer
Since Spacelab was a European project, using a European computer was a point of pride. Unfortunately, the French computers were eventually replaced by IBM computers due to performance needs and undoubtedly political factors.
During the Space Shuttle program, the computers on the Shuttle and in Spacelab became obsolete as computer technology rapidly advanced. Although the computers were originally considered powerful, their performance and memory capacity became problems over time. The Space Shuttle's IBM AP-101 computers were upgraded to IBM AP-101S computers, first flying in 1991. The AP-101S was half the size, three times faster, and had more than twice the memory, using semiconductor memory instead of magnetic core memory.
The Spacelab computer system needed a similar upgrade, and in 1991, the CIMSA computers on Spacelab were replaced with IBM AP-101SL computers. The AP-101SL was based on the Shuttle's upgraded AP-101S computer, but modified to support the Mitra's hardware architecture, instruction set, and I/O capabilities. The packaging of IBM's computer was slightly changed to match the dimensions of the CIMSA computer and to use an external heat exchanger rather than an internal heat exchanger.
The IBM AP-101SL Spacelab computer. The circuit boards are much larger than the original Spacelab computer boards or the original AP-101B boards. Note the flat-pack ICs on the boards. Photo courtesy of Kyle Owen.
Changing the Shuttle's 32-bit AP-101S computer to run the 16-bit Mitra instruction set was easier than you might expect, since the AP-101S already supported multiple instruction sets: a 32-bit instruction set derived from the IBM System/360 and a 16-bit instruction set called 1750A that was an Air Force Standard. Because the AP-101S implemented its instructions in microcode—low-level software that specified the steps of a machine instruction—the instruction set could be modified by updating the microcode.
I compared the circuit boards in an AP-101S with the boards in an AP-101SL to quantify the changes. The semiconductor memory boards and power supplies were essentially identical. The CPU boards had minor changes. Unsurprisingly, the I/O boards were completely different, and the complex I/O Processor (IOP) in the Shuttle's AP-101S was omitted. For more on the IBM AP-101 line, see my History of IBM's 4 Pi computers.
The Spacelab computer provides an interesting look at how computers were built before microprocessors took over. The components of a computer, such as the ALU, registers, and control circuitry, were constructed from simple chips. Since each chip didn't do much, the computer required 36 boards full of chips. Even so, the computer was compact enough to go into space. By modern standards, these computers aren't much—each computer had a memory capacity of just 128 KB of magnetic core memory—but they played a critical part in the space program.
I'm not going to reverse-engineer the full computer, but I may write some more about it. For updates, follow me on Bluesky (@righto.com), Mastodon (@[email protected]), or RSS.
Credits: Thanks to Steve Jurvetson for providing the Spacelab computer for examination. Thanks to Poul-Henning Kamp for comments.
  1. For details on Spacelab, see Spacelab News Reference. ↩↩
  2. To avoid cluttering the main article, I'll summarize the French acronyms and companies in this footnote.
    • CAE: Compagnie européenne d'automatisme électronique (European Electronic Automation Company). A French computer company founded in 1960, selling versions of American computers such as TRW's RW-300. Part of the 1966 merger that formed CII.
    • CII: Compagnie internationale d'informatique (International Computer Company): the company that created the Mitra line of minicomputers. CII also sold computers designed by the American company SDS (Scientific Systems), which was bought by Xerox in 1969 and became XDS (Xerox Data Systems). XDS was shut down in 1975, costing Xerox hundreds of millions of dollars.
    • CIMSA: Compagnie d'informatique militaire, spatiale et aéronautique (Military, Space, and Aeronautical Computing Company): the company that manufactured the Spacelab computer.
    • CSF: Compagnie Générale de Télégraphie Sans Fil (General Wireless Telegraphy Company). A radio company dating back to 1918. It merged with Thomson in 1968 to form Thomson-CSF.
    • MATRA: Mécanique Aviation Traction (Mechanics-Aviation-Traction). An electronics company that was the contractor for Spacelab's data systems.
    • Mitra: Mini-machine pour l'Informatique Temps Réel et Automatique ("Mini-machine for Real-Time and Automatic Computing"). A line of minicomputers.
    • SEA: Société d'électronique et d'automatisme (Electronics and Automation Company): a French computer manufacturer, started in 1947 and merged into CII in 1966.
    • SEMS: Société Européenne de Mini-informatique et de Systèmes (European Society for Minicomputers and Systems). A subsidiary of Thomson, created by the French government in 1976 during the merger of CII and Honeywell. SEMS took over the manufacturing of Mitra computers from CII.
    • SETI: Société européenne de traitement de l'information (European Information Processing Society). SETI was a French computer company formed in 1961. The American computer company Packard Bell owned a quarter of SETI, and SETI sold the desk-sized Packard Bell 250 computer.
  3. On the ground, the Spacelab project used Mitra 125 S computers that were functionally identical to the Mitra 125 MS (details). ↩
  4. Spacelab's Command and Data Management Subsystem (CDMS) is surprisingly complicated because of the data communication paths between Spacelab, the Shuttle, and the ground. Moreover, multiple units store, encode, and decode data. In the CDMS block diagram below, I've highlighted the three computers; they are just a small part of the CDMS. See Section 3.5 of Spacelab News Reference or The Command and Data Management System of Spacelab for details on CDMS.
    A block diagram of Spacelab's Command and Data Management Subsystem. From The Command and Data Management System of Spacelab. Click for a larger version.
  5. I reverse-engineered the 74181 ALU chip in this article and explained the motivation for its quirky set of operations in this article. ↩
  6. Another board in the Spacelab computer has four 74S181 chips implementing a 16-bit ALU. My guess is that this board is part of the I/O processor. The board has the cryptic label "HMSG". ↩
  7. My reverse-engineering process was straightforward but tedious. I used a multimeter to beep out the connections between the integrated circuits as well as the connections to the connector. (Unlike many systems that I look at, these boards didn't have conformal coating, which made beeping out the connections practical.) I created a schematic in KiCad from this data; this schematic was "physical", with the layout of the chips and pins matching their physical location on the board. Next, I converted the integrated circuit symbols from physical rectangles to logical symbols. Finally, I moved the symbols around on the schematic to make a reasonable schematic. (I had to go back and beep out more connections as I discovered errors or missing connections.) Theoretically, I could reverse-engineer the entire computer, but reverse-engineering one of the 36 boards is enough for me. ↩
  8. My full reverse-engineered schematic of the ALU/register board is below. Click for a larger version.
    Schematic of the ALU/register board.
  9. A few mysteries remain in the ALU/register board. The three registers probably act as an accumulator, a temporary register, and an extra register for multiplication/division, but it's not clear which register is which. I don't understand why the inputs are organized as they are; for instance, you can't add register 1 to register 2 shifted. The mix input seems very random; maybe these signals are part of a self test? On the board, I expected to see 12 bits out of a uniform 32-bit ALU. However, the top two 4-bit "nibbles" have different control lines and different zero-detection from the third. Perhaps this is because the Mitra floating-point numbers have 24 bits of mantissa and 8 bits of exponent. It would make sense for the ALU/register board to handle these parts separately. Another mystery is that the board has a circuit to test two hardwired bits and two external bits to see if they are all 0 or all 1, for some reason. ↩
  10. The multiplexer chips are dual 4-to-1 multiplexers. Thus, two multiplexer chips are required to support four bits. ↩
  11. The chips in the Spacelab computer use a variety of part number systems. A few chips have standard industry part numbers such as "SNJ5483" (equivalent to a 7483 adder). Most of the chips are labeled with military part numbers such as JM38510/07801 BJB, using the MIL-M-38510 standard. These part numbers can be cross-referenced using the MIL-HDBK-983 handbook. Other chips, like the ones below, have Fairchild part numbers that are a mystery to me. The first line is presumably the part number, "929 567" and "929 705", but I can't find these numbers anywhere. If you know what these numbers mean, please let me know! (07263 is the CAGE code for Fairchild, and the last line is the date code.)
    Two Fairchild ICs with mysterious part numbers.
    The ALU/register board that I examined uses the following JM38510 part numbers, which I have converted to standard parts:
    /01403 = 54153 dual 4-1 multiplexer
    /07003 = 54S04 hex inverter
    /07006 = 54S20 4-input NAND
    /07601 = 54S194 4-bit shift register
    /07801 = 54S1814-bit ALU
    /30107 = 54LS175 quad flip-flop ↩
  12. The photo below compares an IBM board (top) with a Spacelab board (bottom), both from the early 1980s. It's interesting how similar the boards are. Both use a 0.1" grid of holes, unlike most printed-circuit boards, which only use holes where needed. Both boards are multi-layer with integrated circuits on one side. The IBM board is denser; the chips are spaced 0.1" apart rather than 0.3" apart.
    An IBM computer board (top) and a board from the Spacelab computer (bottom).
    I don't know which IBM system used this board, but it was a commercial system, not an aerospace system. This board is a bit unusual for IBM, since most of the chips are standard DIPs rather than the square metal cans that IBM typically used. ↩
  13. The US blocked computer exports to France with NSAM 294, a 1964 National Security Action Memorandum. The US later allowed sales of the CDC 6600 and IBM 360/91 computers to France on the condition that France not use the computers for atomic weapon development, a condition that France apparently violated. See A.E.C. Bids Industry Avoid Sales Aiding French Tests (1964) and Paris Promises Not to Use Equipment for Atomic Weapons (1966). The CDC 6600 supercomputer executed up to 10 million instructions per second (MIPS) while the IBM 360/91 executed about 17 MIPS. (In comparison, a 1995 Pentium Pro or a 2012 cell phone is faster than these computers.) In 1971, Henry Kissinger was still blocking computer exports to France, as shown in this transcript. (One confusing issue in these articles is that IBM announced the 360/92 computer in 1964, but renamed it as the 360/91 before it shipped in 1967.) ↩
  14. Some contemporary articles on Plan Calcul are France Entering Computer Battle: Starts All-French Company to Compete (New York Times, 1967) and France: First the Bomb, Then the "Plan Calcul" (Science, 1967). See History of Computing in France: A Brief Sketch for an overview of the French computer industry. ↩
  15. Thomson has a complicated history. In 1883, two Americans, Thomson and Houston, started the Thomson-Houston Electric Company. A decade later, this company became General Electric, with a French subsidiary: Thomson Houston International. After various mergers, the French subsidiary became Thomson-CSF, a major defense and electronics firm.
    In a sense, Thomson-Houston both created and destroyed GE. The Thomson-Houston Electrical Company became GE, but the French subsidiary of Thomson-Houston ended up being a key part of GE's collapse almost a century later. Specifically, the French rail transport company Alsthom (later Alstom) was formed from the French heavy engineering subsidiary of Thomson-Hudson in 1928; the "thom" in "Alsthom" comes from "Thomson". In 2014, General Electric acquired Alstom for $10.1 billion. The acquisition was a disaster, and in 2018, GE wrote off $23 billion. This loss, along with other financial problems, led to GE's announcement in 2021 that it would break up into three companies. ↩
  16. One more company should be mentioned: MATRA. MATRA was the contractor for Spacelab's data systems, so the Spacelab computer was produced under a contract from MATRA. People often confuse Mitra (the name of the computer line) with MATRA. ↩
  17. Due to financial difficulties, Bull was acquired by General Electric in 1964, then was acquired by Honeywell, nationalized by France, partnered with NEC, acquired Zenith, privatized by France, and acquired by Atos. Less than two months ago, France acquired Bull, continuing the series of reorganizations. ↩
